04-13-2018, 11:18 PM | #1 |
Front end problem, clunk, snap, pop. Name that part?
I have a front end issue,
Every bump I hit on the front left makes a clunk/pop. When I turn it clunk/snap/crack/pops also. Feels like am arm. Like a sway bar or something. Heres a big clue: When I brake and turn to the left slightly, the entire wheel feels like it is folding over and the car skids with very little brake effort. I've felt bad Tension rods before and this isn't it. It doesn't clack when you press the brake, there is no braking slop or movement when braking straight. Name that part pls Stuff I changed alrdy just this month: Strut mounts struts (AGX new) control arm bushings ES sway bay / end links SIKKY ball joints MOOG Tension rods OEM stock height, stock springs (it isnt the spring) stock brakes too If I can fix this, I can finally align the car, put tires on it, brakes, and get on with my life. sheesh! |
04-14-2018, 07:10 AM | #3 |
Checked your wheel bearings? The best advice I can give would be to jack up the car do a visual inspection and try to find anything loose.
¯\_(ツ)_/¯ |
04-14-2018, 07:35 AM | #4 |
So, I have been under this car, on a lift, and on jack stands, three or four times. Prying and pulling, hanging on parts. Nothing feels like is loose. I probably overtightened every bolt under the car looking for a loose bolt. Its to the point where I am thinking an arm or bushing of the rack, engine cradle, steering shaft itself, is loose and I am just not prying in the right spot. So I need kind of a guide, or other ideas to check, or change, I am not sure really.
My next is to literally zip tie a camera in there and drive it. Cause its a LOUD *BANG!* *POP* CRUNCH* , like, I should see this thing move easily. |
04-14-2018, 09:14 AM | #5 |
Broken/missing brake caliper bolt?
NismotronicSA - Speed-Density Tuning for Nissans |
04-14-2018, 12:24 PM | #6 |
re-read nevermind
MRP Manufacturing |
04-14-2018, 12:37 PM | #7 |
It’s interesting that your car does this with a pretty much OEM strut/spring. When I first got my coilovers, I lowered them to the floor and the spring was just sitting loosely in between the collars, and it helped the problem a lot when I tightened the collars to a position where the spring couldn’t move.
But my car still makes the noise. I think it has something to do as well with my steering rack. |
04-14-2018, 09:53 PM | #8 |
Today I put it on the lift for a third time and REALLY pulled the wheel around. It looks like the tension rods ARE a bit shot after all, those being the 'new' ones I installed to test this issue. So I will order an actual brand new set of TC rods (right this second) and update thread when they are in.
The whole wheel folding in this is kind of a clue. I think the TC rod holds the wheel from doing that. Not sure but its worth a shot. |
04-24-2018, 07:47 PM | #9 |
New tension rods, didn't change anything.
So thats: Stuff I changed alrdy just this month: Strut mounts NEW struts (AGX new) control arm bushings NEW ES sway bay / end links NEW sikky ball joints NEW moog Tension rods good OEM and New pillowball tried both stock height, stock springs (it isnt the spring) stock brakes too Whats left? Seam welds. How do I access seam welds? The engine bay showing me glues, is it under the wheel well or under the fender? NEver messed with them but I guess that sall thats left |
04-24-2018, 10:24 PM | #11 |
I checked every bolt I could see. Probably overtightened all of them checking.
Its got to be the car where it connects to the strut. the welds I guess, are broken, I've heard of it happening. Just no idea where it happens, what it looks like, how to fix it. |
05-05-2018, 01:09 AM | #12 |
So today I said enough is enough.
I jacked up the front, took the tire off, took the strut out, removed the tension rod, and pulled on the control. Its the sway bar link. Easy fix, I loose it and held up the control arm with my knee to get the stud nice and straight, and re-tighten it. and its good now, the front is silent like it should be. Sikky sent me a new end link for the other side that looks bigger than the one that was making noise. So I think they revised it at some point. i am going to ask them send me another newer updated larger thicker size end link to put it that matches the other one. Also as an aside, the tire kind of folding over was apparently me not knowing how to adjust a tension rod properly, and the OEM bushings on the non-adjusting rod were just weak and 20 years old. The easy to lock up brakes was just the tire. The front left tire was 10 years old. It just wouldn't wear out so I kept it from car to car, but I finally put both new fronts on the car and it stops much better that than terrible tire had me thinking it was. Last edited by Kingtal0n; 05-05-2018 at 10:07 AM.. |
