Old 12-17-2018, 06:29 AM   #1
Charleyr1
Charleyr1 is an unknown quantity at this point
Evo 8 recaros into s13
The only threads I found on this were a few years old and a few said they made them work but never explained how. The seat isn’t a standard recaro bolt and my head is about 3 inches from the roof. The seat sits extremely high regardless. I need it to sit a few inches lower. What can I get to achieve this? Standard rails will not fit
Charleyr1 is offline   Reply With Quote
Old 12-17-2018, 07:03 AM   #2
TheRealSy90
TheRealSy90's Avatar
There's a website that sells lowering brackets for the Evo 8/9 seats. They're intended to be used with the seats as mounted in the Evo. Not sure if they'll work for your application but it's worth checking into.
Such a good signature.
Old 12-17-2018, 07:55 AM   #3
Charleyr1
Thanks for the info. I just looked into it an unfortunately it’s only for the evo. A thread from 2011 said something about using a modified wedge seat rail but I couldn’t find any more info besides that
Old 12-17-2018, 08:52 AM   #4
TheRealSy90
Right it's for the evo seat rails I wasn't sure what your mounting method was.
Old 12-17-2018, 09:14 AM   #5
Charleyr1
Stock s13 mounting points. Looking at the brackets they have the front might work but the rear won’t in the factory location. For $125 they want for them I don’t want to work off of these might work. I’m not even sure what rails I have now, I bought them used. Maybe modified stock rails idk. I fudged up and threw away my stock seats before sitting in the car so I’m kind of in a bind now.
Old 12-17-2018, 09:34 AM   #6
jedi03
i have seen them in other cars...iirc you just redrill the rails you want to use to fit the bolt pattern under the seat
Old 12-17-2018, 09:53 AM   #7
Charleyr1
So basically just order whatever the lowest rail I can find and redrill them for the seats? These also have sliders in them. I wonder if I take the sliders out will it drop the seat more. I would like it to be 4inches lower than what it sits now
