Old 07-22-2016, 10:15 AM   #1
OutlawLui
OutlawLui's Avatar
OutlawLui is a well-known jackass
SR Sr20 wont turn over after sitting 2 months
Sr wont start after sitting 2 months
History;
daily for 3 years after swap. Ran fine, let it sit for about 2 months. now wont start
1. after letting it sit for 2 months while i upgraded some parts i installed a new odyssey PC925 battery, went to turn on the car, and no go
2.Starter started sticking, and would only turn, every 6-8 cranks
3. bypassed starter signal wire, cranked but engine still would not turn over
4. checked relays and fuses. Found Melted EGI PUMP relay
5. checked ecu (code #62) and found pin 36 (Ignition switch) was burned, so i soldered it back
6.Added a gallon of fresh fuel...cranked engine, still nothing.
7. Switched out ignitor chip-nothing
8. Checked CAS- all wires working, signal wire working
9. Checked Spark -all 4 coils sending spark *checked with grounded spark plug
10. Checked injectors-took fuel rail off of manifold. all injectors firing
11. Tried starting fluid while cranking it-still wont turn over
To Do/Check list;
-Check compression
-get new spark plugs
-check engine harness
-try new ecu
-Set car on fire
Any ideas on what to try next or check would be helpful
OutlawLui is offline   Reply With Quote
Old 07-23-2016, 12:25 AM   #2
cotbu
cotbu's Avatar
Set engine to TDC and reinstall cas
Is it cranking strong?
Crank with the throttle wide open.
If you mean ether, as starting fluid? timing off or there is no air or compression.
Sent from my SM-N910T using Tapatalk
Old 07-23-2016, 04:51 AM   #3
rawgarage
Banned from the Marketplace
Trader Rating: (75)
Feedback Score: 75 reviews
Jump to set car on fire
Old 07-23-2016, 11:43 AM   #4
zurud
zurud is an unknown quantity at this point
set car on fire . use flame thrower
zurud is offline   Reply With Quote
Old 07-23-2016, 03:08 PM   #5
ultimateirving
ultimateirving's Avatar
sat for two months and was the battery disconnected? was the battery dead when you went to start?
Z32 with lq4 swap
Old 07-23-2016, 07:52 PM   #6
jedi03
Probably low crank amps
Old 07-23-2016, 10:03 PM   #7
rawgarage
Trader Rating: (75)
New battery bet it kicks over and purrrrs
Old 07-24-2016, 05:50 PM   #8
OutlawLui
OutlawLui's Avatar
Finally turned over, used starting fluid again with wide open throttle as u said and fought it a couple times till it finally stayed on
No battery, i removed it before letting the car sit since terminals had crazy build up
-now the starter only works wth bypass switch though
