11-16-2015, 09:23 PM | #1 |
S13 Overheating Diagnosis Help
So I Recently replaced the radiator, the upper and lower hoses, and a couple other Hoses and every time I would install the thermostat the car would over heat. So without the thermostat it wouldn't overheat so I ran it a few weeks without it and it was running perfectly fine and now it's overheating again. What else could it possibly be? I also heard a high pitch whistle noise coming out from under the intake manifold. Any suggestions on what to look for? Thanks!
11-19-2015, 01:55 PM | #2 |
Leak, blown gasket or just not sufficient cooling of the coolant, because no thermostat
Sent from my SM-N910T3 using Tapatalk
11-26-2015, 10:26 PM | #5 |
yeah make sure you bleed all the air out of the cooling system. you can also do a pressure test and check your compression to see if you have a blown head gasket. you're experiencing the same symptoms i had when i finally discovered my head gasket was blown :/
12-09-2015, 03:14 AM | #6 |
Mine is doing the same thing, but ive bled the system 4 times already. Have new POS radiator, new water pump, new hoses, and new thermostat, and its still running hot, after i bled the system today it ran cooler for longer but after a little while the temps start to rise again, any possibility air is somehow getting in or did i just not get it all out?
Btw, i have no coolant overflow tank, just a line routed under the passenger headlight temporarily.
20 till 3:00 = ღ |
12-09-2015, 07:50 AM | #7 | |
Trader Rating: (37)
Feedback Score: 37 reviews
Welp......
I like my bikes how I like my b¡tches...naked! 2014 Triumph Street Triple |
12-09-2015, 07:52 AM | #8 |
Are yall using cheap waterpumps? Aftermarket cheap waterpumps have usually the wrong sized blades, they are usually shorter and fatter. Causes cooling issues
Sent from my SM-G900V using Tapatalk |
cooling system, ka24de, overheating |
