Old 09-01-2017, 07:54 PM   #1
Pimpnyou204
Pimpnyou204 is an unknown quantity at this point
92 super clean built ka24de
No need to sell but trying to purchase a house and this would obviously help a good chunk. Car was built by and tuned by Jackson Performance and Billet Design Motorsports. Not really gonna wiggle on the price, not really interested in a trade either can remove a few items but im not gonna piece a well built and put together car. Car hit the dyno made 369 on only 10lbs. Didn’t have the boost solenoid at the time so left as on the rigged wastegate. Car set at 18lbs right now and can handle gobs more. This thing only really needs some much larger injectors and its ready for E85 and 30 lbs. I have a top mount rail I will include and the car has a flex fuel sensor already installed. Put the origin type 4 overs on (75mm) haven’t been painted yet been to lazy to get it done. AC is all in the car and works broke a line or compressor. Again haven’t had time to fill and find the leak. And no your not driving it with an empty pocket.
Asking 14K as is and the extra parts. Not really interested in a trade.
Head
Stage 3 Brian crower head-
BC0212 272 cams 10.19 lift
BC dual valve springs and retainers
supertech valve seals
Block
CP pistons 89.5 .020 over bore
Manley rods
M11 (stock M10) ARP head studs
Polished crank
AEM EMS V2
New OEM lower and upper timing chain
New water pump
New oil pump
Quest 125A alternator
New distributer
Powder coated intake manifold
All new sensors throughout
Wiring specialties tucked KA harness
CX racing top mount turbo manifold
GTX3071R turbo
Tial wastegate
AEM boost solenoid
Stock intake manifold
Five-O 750CC injectors
Tial BoV
ISR Radiator and E fans
EMUSA intercooler
Aeromotive FPR
Driveshaft shop steel driveshaft
J30 dif
B&M short shifter
Parts shop max ebrake and wildwood master cylinder
Z32 front brakes and
S14 rear brakes
17/16 Z32 Master cylinder
Pro sport
Oil temp
Oil pressure
Boost
Fuel pressure
Water temp
AEM Wideband
Parts shop max LCA and tension rod comboParts shop max LCA and tension rod combo
BC br type coil overs with swift springs
new rack an pinnion
new isis sway bar an bushings
new front isis 5 lug hubs
extended front studs
rebuilt an powder coated black 300zx brakes with new pads an rotors
Rear subframe was removed cleaned an painted an new bushings were installed
new oe axles, new poly bushings installed in rear knucles an powder coated black
isis rear toe arms
isis rear traction arms
new oem rear lower control arms
isis rear camber arms
Interior is 9.5-10 nothing is missing an nothing is faded half of it was bought brand new from nissan an its all black
dash board is refinished an all other panels that were not replaced brand new small crank
new parts in the interior (wiper an head lamp switches, center console, ash tray, head lamp pivot switch, electronic mirror switch, power outlet/ cig lighter, all rear carpet in the hatch, center a.c vent, power window finishers an cluster clear cover.)
Carpet is single cam loop style carpet also 180sx front seats
battery is in the back
nrg quick release black and black grip royal steering wheel.
http://zilvia.net/f/attachment.php?a...1&d=1504317171
Pimpnyou204 is offline   Reply With Quote
Old 09-01-2017, 08:00 PM   #2
Pimpnyou204
http://zilvia.net/f/attachment.php?a...1&d=1504317585
Old 09-11-2017, 01:49 PM   #3
Pimpnyou204
work D9R (white) 18x10.5 + 15 and 18x9.5 +12. come with 225/40/18 and 235/45/18 Hankook ventus RS3. Tires are easily 90% left driven at most 1000 miles.
Old 09-14-2017, 06:02 PM   #4
Pimpnyou204
Back up top
Old 09-15-2017, 12:19 PM   #5
Malong954
Malong954 is an unknown quantity at this point
Seen the car at Jackson when mine was getting work done. Looks good man! GLWS. Free bump.
Malong954 is offline   Reply With Quote
Old 09-23-2017, 04:13 PM   #6
Pimpnyou204
Appreciate the vouch man
Old 10-08-2017, 02:23 PM   #7
Pimpnyou204
Car is sold thanks
