Old 08-21-2012, 05:07 PM   #601
kaking
kaking is making a name for him/her selfkaking is making a name for him/her self
Look what just showed up....Ecessive ;-)
Uploaded with ImageShack.us
kaking is offline   Reply With Quote
Old 08-21-2012, 06:08 PM   #602
kaking
Anyone ever run a high mount setup with stock twins/intake setup?
Old 08-21-2012, 07:15 PM   #603
Flicktitty
Flicktitty's Avatar
Flicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to behold
Send a message via AIM to Flicktitty
Looking forward to seeing how those mounts work. I'd be leary of a high mount setup with as much cooling issues the JZ swapped S-Chassis cars have
2JZ-GTE Swapped S13 Coupe - 1994 Supra Turbo
Flicktitty is offline   Reply With Quote
Old 08-22-2012, 08:31 AM   #604
2muchboost
Trader Rating: (33)
2muchboost is an unknown quantity at this point
Feedback Score: 33 reviews
Have any of you used any reflective/protective material on the firewall of your projects? I was interested in installing some of this material on the firewall to prevent excess heat from going through the firewall.
Open to suggestions and ideas.
BTW, I wasnt able to take pix but the mounts worked perfectly during mock up. I will be dropping the setup back in after I come back from vacation and finish up a few work projects. I will take pictures at that point.
2muchboost is offline   Reply With Quote
Old 08-22-2012, 08:32 AM   #605
2muchboost
Trader Rating: (33)
Deftec whats your setup....or did i miss the info already?
Old 08-22-2012, 04:50 PM   #606
Deftec
Deftec is making his/her stupidity well-knownDeftec is making his/her stupidity well-knownDeftec is making his/her stupidity well-knownDeftec is making his/her stupidity well-knownDeftec is making his/her stupidity well-known
2jz with r154/1jz bellhousing.
http://i98.photobucket.com/albums/l258/Deftec/signew-1.jpg
Deftec is offline   Reply With Quote
Old 08-22-2012, 05:10 PM   #607
florante rea
florante rea's Avatar
Trader Rating: (43)
florante rea is a glorious beacon of lightflorante rea is a glorious beacon of lightflorante rea is a glorious beacon of lightflorante rea is a glorious beacon of lightflorante rea is a glorious beacon of lightflorante rea is a glorious beacon of lightflorante rea is a glorious beacon of lightflorante rea is a glorious beacon of lightflorante rea is a glorious beacon of lightflorante rea is a glorious beacon of lightflorante rea is a glorious beacon of light
Feedback Score: 43 reviews
Send a message via AIM to florante rea Send a message via Yahoo to florante rea
Any other compatible sway bars beside sikky? i have tanabes and just wondering if i can use those.
fdrea
florante rea is offline   Reply With Quote
Old 08-22-2012, 05:12 PM   #608
JDM SPUG
JDM SPUG is an unknown quantity at this point
IF you change your oil pan you don't need to change your sway bar.
1998 240sx 2jz swap in progress
2006 FULLY built WRX Rotated w/ PPG's
JDM SPUG is offline   Reply With Quote
Old 08-22-2012, 05:19 PM   #609
bullfrogg0
bullfrogg0's Avatar
bullfrogg0 is an unknown quantity at this point
what do u mean "if you change your oil pan"? unless you cut the firewall the motor won't work with a rear sump setup
bullfrogg0 is offline   Reply With Quote
Old 08-22-2012, 05:33 PM   #610
dpkid101
dpkid101's Avatar
dpkid101 is an unknown quantity at this point
x2 on that what do you mean jdm spug?
dpkid101 is offline   Reply With Quote
Old 08-23-2012, 07:27 AM   #611
BigPawr
BigPawr is an unknown quantity at this point
Yeah, I'm not aware of any other oil pan options. You either have rear sump, front sump, or front sump with the IS300 pan which has a recess in the back of the pan. Curious to what pan you speak of as well.
BigPawr is offline   Reply With Quote
Old 08-23-2012, 09:42 AM   #612
JDM SPUG
I meant change the sump.ill try and get a picture later on because I'm still using my factory front sway bar w/o spacers.
Old 08-23-2012, 09:50 AM   #613
bullfrogg0
bullfrogg0's Avatar
pics are a must
Old 08-23-2012, 05:51 PM   #614
Minz
Minz is an unknown quantity at this point
The word around here in NZ is that an A31 Cefiro sway bar clears the 1J.
I figure this is because the A31 shares many suspension components with the S13 chassis but has to make clearances for the RB series motors.
I'm almost 100% certain on this; as memory serves I've seen it in a build thread, I'm picking mine up next week so can give you pictorial evidence if you like lol.
Minz is offline   Reply With Quote
Old 08-23-2012, 06:15 PM   #615
bullfrogg0
bullfrogg0's Avatar
that would be awesome
Old 08-23-2012, 07:16 PM   #616
Mr. Phonso
Mr. Phonso is an unknown quantity at this point
sure thats great for the s13 guys but what about us s14s
Mr. Phonso is offline   Reply With Quote
Old 08-23-2012, 08:34 PM   #617
dpkid101
dpkid101's Avatar
This^. Also on a side note i got my motor running last weekend, radiator is coming in tomorrow so i will post a short vid for you guys. Also i did my own wiring for those of you who would like to know and it wasnt too bad at all!
Old 08-23-2012, 09:21 PM   #618
waste_of_space
Trader Rating: (22)
waste_of_space is an unknown quantity at this point
Feedback Score: 22 reviews
Swap in a low temp thermo if you haven't already! It helps out tremendously.
Flick's definitely right about 2j s13's running real hot. Mine was running around 210 on stock thermo. Mishimoto dropped it to around 160. I need to get a hood vent for sure though lol.
Also, installed some cs carbon hood dampers since I was tired of carrying my hood prop in my car (it was getting caught on the passenger side headlight since I had to notch my core support for fan clearance)
They were cheap and the install was a breeze. We'll see how they hold up in the winter time.
waste_of_space is offline   Reply With Quote
Old 08-24-2012, 12:12 AM   #619
Mr. Phonso
looks nice but put up some bigger pics!
Old 08-24-2012, 12:54 PM   #620
dpkid101
dpkid101's Avatar
aghh yes i do have to do that. And mr phonso is right... Bigger pics! Looks good though!
Old 08-24-2012, 02:32 PM   #621
Black R
Black R's Avatar
Black R is an unknown quantity at this point
I'm planning on putting that gold reflective stuff on the firewall and front of the tunnel.
I'm also planning on putting dynamat on the inside of the firewall and front floorboards.
Black R is offline   Reply With Quote
Old 08-24-2012, 05:01 PM   #622
Black R
Black R's Avatar
That's great news for us s13 guys.
What size is the cefiro swaybar?
Old 08-26-2012, 03:33 AM   #623
jackal264
jackal264 has much to be proud ofjackal264 has much to be proud ofjackal264 has much to be proud ofjackal264 has much to be proud ofjackal264 has much to be proud ofjackal264 has much to be proud ofjackal264 has much to be proud ofjackal264 has much to be proud ofjackal264 has much to be proud ofjackal264 has much to be proud ofjackal264 has much to be proud of
ok so here's one i havn't seen before. aftermarket intake manifolds. which ones fit? some better then others?
jackal264 is offline   Reply With Quote
Old 08-26-2012, 08:21 AM   #624
dpkid101
dpkid101's Avatar
theres quite a few out there you got driftmotion (Greddy rep), DOC, and of course greddy. Theres also others just look around. I saw a thread where someone had one on a s13 idk which one it was but he had to beat his brake lines back a little to make it fit.
Old 08-26-2012, 03:23 PM   #625
tengoku
Trader Rating: (-2)
tengoku is an unknown quantity at this point
Feedback Score: -2 reviews
I have an s14 kouki with a 2jzgte usdm swap. I'm having an issue with the cooling system; the coolant temp begins to rise ONLY when I turn the on the A/C while cruising. The temp does rise a tiny bit when I get on it but never overheats. It has a front mount, condenser with a pusher fan, koyo radiator, dual flex-a-lite puller fans, regular coolant, and a thermostat that's close to the stock spec.
I already did my research and came to a conclusion that I need a TRD or MISHIMOTO thermostat but I don't know which temp spec to get. Considering San Antonio, TX where the average temp is 90F during the day time. will be a wise decision to go with a 140F or 160F?
tengoku is offline   Reply With Quote
Old 08-26-2012, 03:35 PM   #626
waste_of_space
Trader Rating: (22)
Mishimoto, 55 bucks from driftmotion, can't beat it.
Old 08-26-2012, 05:11 PM   #627
tengoku
Trader Rating: (-2)
This article basically concludes that low temp thermostats are ineffective in solving the overheating issue.
Low Temp Thermostats: What’s the Advantage? | Tuner University
Old 08-26-2012, 05:47 PM   #628
bullfrogg0
bullfrogg0's Avatar
that article is retarded. if you run a lower thermostat then the water stays at a lower temp so when you experience a load or turning on the ac the system is at a lower starting temp to begin with meaning the cooling system doesn't have to work so hard to maintain a certain temp. cooler temps are easier to maintain because it keeps heat overall to a minimum
Old 08-26-2012, 08:18 PM   #629
BigPawr
Anybody using, or considered using stock usdm clutch fan? I know there are room issues, but I was considering moving my radiator forward (notching out the support) and then making a customer shroud.
Old 08-27-2012, 06:32 AM   #630
tengoku
Trader Rating: (-2)
BigPawr, that should work well only if having A/C is not his or her concern.
