Old 04-21-2018, 05:20 PM   #1
Sr20probs
Sr20probs's Avatar
Sr20probs is an unknown quantity at this point
S13 no crank
Hey guys I know google is still around but my problem is kinda weird I guess or Iím just not the brightest. Anyways, when I turn the key it clicks once but doesnít even try to engage or turn the starter. Any ideas why itís doing this? Would a entirely new engine harness from wiring specialties fix this issue? I just want to drive it. I replaced the trans harness with a wiring specialties one. I have 12v to the starter. Iím able to jump the solenoid and it spins. No engagement. Thanks Iím prepared for some ďyour a dumbassĒ comments but itís okay I probably deserve it lol.
Sr20probs is offline   Reply With Quote
Old 04-26-2018, 12:26 AM   #2
kyral
kyral's Avatar
kyral is making a name for him/her selfkyral is making a name for him/her self
apply/jump 12v to the little black wire. the starter will engage and spin. so have it in neutral
dont kill yourself
if it doesnt your solenoid failed
The most threads never responded to.
kyral is offline   Reply With Quote
Old 04-26-2018, 02:01 AM   #3
Sr20probs
Sr20probs's Avatar
I did that and it cranked after applying 12v to the trigger wire. Still nothing from the ignition. Everything is new besides the chassis harness.
Old 04-26-2018, 09:05 AM   #4
jedi03
is your signal wire attached to the starter? its a little connector usually a single pin...
Old 04-26-2018, 09:13 AM   #5
staying_chuki
staying_chuki's Avatar
staying_chuki is an unknown quantity at this point
S13 no crank
Check to be sure that all your wiring at the starter is getting power, and whatever isnt getting power trace back.
When i had this issue on my s14 the starter signal wire wasnt getting power, I temporarily wired up a push to start but ended up tracing it and fixing the wiring later on.
staying_chuki is offline   Reply With Quote
Old 04-26-2018, 11:34 AM   #6
Sr20probs
Sr20probs's Avatar
Yes it’s connected
Old 04-26-2018, 10:27 PM   #7
kyral
kyral's Avatar
check your starter relay and the signal wire for coninuity from the relay pin to the starter
relays can be tested with a multimeter and a 9v battery
the clicking is likely the starter relay and its either failing to forward the power to the starter or the signal wire to the starter is broken
Old 04-27-2018, 04:29 AM   #8
Sr20probs
Sr20probs's Avatar
It’s a brand new trans and engine harness so there shouldn’t be any broke connection besides from the ignition on the interior harness side. I feel that’s what causing my issue. I can hear the starter relay click every time I turn the key. I replaced the neutral safety switch as well. I’m able to jump the stater and crank it with a power probe. I’m really at a loss. I’m considering just seeing if I’m able to purchase a fuse box with the harness uncut. But that’s last resort as it has to be something stupid causing this.
Old 04-27-2018, 07:30 AM   #9
staying_chuki
S13 no crank
Originally Posted by Sr20probs View Post
Itís a brand new trans and engine harness so there shouldnít be any broke connection besides from the ignition on the interior harness side. I feel thatís what causing my issue. I can hear the starter relay click every time I turn the key. I replaced the neutral safety switch as well. Iím able to jump the stater and crank it with a power probe. Iím really at a loss. Iím considering just seeing if Iím able to purchase a fuse box with the harness uncut. But thatís last resort as it has to be something stupid causing this.
Have you checked your wires for power bro
Its a working starter the issue is obviously wiring, do what Kyral said and whip out the multimeter. Something isnt sending power to your starter.
Old 04-27-2018, 11:30 AM   #10
kyral
kyral's Avatar
Check the relay then.
the way its wired the relay cant click unless the neutral or clutch switch is activated. if its clicking then you know that part of the circuit is good
that only leaves the relay and the signal wire
Old 04-28-2018, 04:30 AM   #11
Sr20probs
Sr20probs's Avatar
I’m glad you guys are bearing with me electrical is not my forte but would love to learn. I’ll do what you guys said and keep you updated. Thank you bros
Old 04-29-2018, 11:30 AM   #12
jumboflan
jumboflan's Avatar
jumboflan has a little shameless behavior in the past
Get a new relay.
Im immune to bullshit....so put your shovel away.
jumboflan is offline   Reply With Quote
Copyright © 1998 - 2015, Zilvia.netô
