Old 01-22-2017, 01:07 PM   #1
nomoremrriceguy
nomoremrriceguy is an unknown quantity at this point
Possible water leak locations?
Kinda stumped on where my cars leaking from, it's been raining pretty hard the last couple days and every morning I check inside the car theres a huge puddle of water behind the drivers seat on the floor and the passenger side is wet but nothing like the drivers side, I had to sponge up the water for a good half an hour. I have a sun roof and a trunk with holes from removing the wing but i sprayed both of them with a hose and I didnt see any leak
I had my taillights replaced and the weather seal looks like it should be refreshed but also no leak? I feel like it's the tail lights but can water build up inside the cab if the tail lights aren't sealed?
nomoremrriceguy is offline   Reply With Quote
Old 01-22-2017, 01:38 PM   #2
jr_ss
Side rear windows or the sunroof drains are leaking inside the chassis.
Old 01-22-2017, 02:44 PM   #3
nomoremrriceguy
I have a hunch that its the sunroof drains but how do you access them? I took off the a pillar cover and I see the drain hose but I can actually access it because it's stuck behind the a pillar
EDIT: front drains are fine, both rears are leaking, how do you remove the rear interior quater panel? it seems like its secured by a screw or something but I don't wanna force it and break clips
Old 01-22-2017, 03:11 PM   #4
jr_ss
They should be snapped into place and with a solid pull come free.
Are they leaking at the sunroof or in the tubing somewhere along the line?
Old 01-22-2017, 03:15 PM   #5
nomoremrriceguy
I got at them....theres no drain hoses at all for the rear. I'll probably buy some hose at the hardware store, where am i supposed to route them though?
Old 01-23-2017, 01:18 PM   #6
gaz_moose
gaz_moose is an unknown quantity at this point
on an s13 they come down the B pillar then go into the sills.
gaz_moose is offline   Reply With Quote
Old 01-23-2017, 01:20 PM   #7
nomoremrriceguy
where are the drain holes though? I can push the hose down into the b pillar but I have no idea where it's coming out, do I look in the trunk?
Old 01-23-2017, 02:35 PM   #8
S-Verteen
S-Verteen is an unknown quantity at this point
When you figure out how to access them weed wanker string works well to clean them out!
S-Verteen is offline   Reply With Quote
Old 01-24-2017, 03:12 PM   #9
nomoremrriceguy
UPDATE: Turns out for some stupid fuckin reason the previous owner left the hoses intact inside the B pillars, but he just left them unconnected... I took off the interior panels and reconnected the hoses and secured them and voila! everything drains properly and now my interior wont turn into a lake after it rains
