08-10-2016, 11:54 AM | #20071 | |
only other option i have is to dump it a local mall and drive around a bit and get a few cycles on it. i know of one that's not to busy so no one should mess with me. Was just hoping someone had a shade tree trick to do it in my yard lol. thanks for all the answers. |
08-10-2016, 04:05 PM | #20072 | |
and yes your right they break in clutches just like a break in ceramic brakes, whats funny is ceramic clutches take about as long as ceramic brakes to break in, just enough time to get hot and your good to go, and lets say it again people heat is what kills clutches spec Miata, lemons cars, Honda challenge cars, PCA club racers, what do these all have in common? road race cars, the majority of these cars are not being shifted flat footed, gas off, shift, gas on, again far less heat than clutch kicking, far less shock, they can go without breaking in a clutch just fine for a clutch road racing and in town daily driving is virtually the same as long as your not slipping the shit out of it while racing and shifting gears and as long as the clutch holds the power and doesn't slip under throttle |
08-10-2016, 07:32 PM | #20073 |
Small Questions Thread (SEARCH FIRST! Use this instead of making NEW threads)
Put it in and go beat on it for fucks sake.
If the clutch can't handle that you really need to buy something better. I'd never consider exedy myself. Sent from my iPhone using Tapatalk. |
08-13-2016, 02:04 AM | #20074 |
So I've noticed
My car makes a really loud knocking, vibrating noise when I'm drifting, but only when I'm going right. If I'm going around a left corner, it's perfect, but for example if the first corner of a course is a right hander, my car either grips or understeers and something in the rear knocks or shakes like crazy. The weirdest part is if it's already sideways and I'm going left and then transfer to the right, it still makes the noise but it performs like normal. Any ideas? |
08-13-2016, 05:06 AM | #20075 | |
08-15-2016, 10:27 AM | #20076 | |
is your car a hicas car? get it up in the air and check all the joints, any number of things under the rear could be loose and making noise, welded diff or lsd? |
08-15-2016, 11:32 AM | #20077 |
Trader Rating: (53)
Feedback Score: 53 reviews
Are there any additional requirements needed to run a kouki heater core in a zenki? Is any rewiring needed or anything? I got rid of the bulky valve in the heater hose from car and I know that the kouki performs the same function but internally. Any way to make this easily work for that functionality with a clean look?
Sent from my iPad using Tapatalk
: @e_lemonation |
08-15-2016, 08:37 PM | #20078 |
Sorry if this has been asked before but I've been shopping around on japanese auction center and it seems like every item I select is blocked, can not be shipped international. Is there something I'm missing that would allow me to bid on items to be shipped to the U.S? Thanks in advance for the advice.
under cover brother |
08-16-2016, 09:38 AM | #20079 | |
http://jessestreeter.com/ordering-parts/
S13 Vert | SR | PE1420 | 5-Speed | 15x9.5 - 0 | |
08-16-2016, 06:32 PM | #20080 | |
Years ago, auto manufactures believed they could save wear on the heater core by shutting off coolant flow through the core with a valve. Eventually they realized that shutting off flow was actually doing more damage because coolant would just sit in the core all summer long where it would gell up. Eliminating the shutoff valve allowed constant flow therefore keeping the core free of clogs. That's why you don't see valves on modern cars. You've removed the valve. That's all there's to it. |
08-16-2016, 07:29 PM | #20081 |
So my eBay Aftermarket gauge for my rb20 says I'm overheating as it exceeds levels above 200 but my stock cluster gauge sits below mid range saying I'm fine.
Even with my fans on I do not see my temperature drop. Question is, does the RB20 Coolant temp sensor work fine on a dohc cluster? If so, I'm gonna just invest into defi gauges.. Sent from my iPhone using Tapatalk
Instagram: Nismo_Lk |
08-16-2016, 07:30 PM | #20082 |
You need to match your gauge temp sensor to the gauge cluster you have. If it's a dohc or sohc Ka cluster you need to use a dohc or sohc sensor.
Sent from my iPhone using Tapatalk |
08-16-2016, 07:35 PM | #20083 | |
Ahh ok, so the rb20 sensor would make it read inaccurately. So I would replace the rb20 sensor with a ka24 dohc coolant temp sensor right and wire it into my wiring specialties harness? Sent from my iPhone using Tapatalk
08-16-2016, 07:59 PM | #20084 |
Hesitation problem
So I just changed my oil and sea foamed the car, went for a drive and the first time I go full throttle in first gear it hesitates for a second until it hits around 4000 then it pulls normally. It's not a big hesitation but it's definitely noticeable, haven't tried to see if it does it in the other gears but I think it's only in 1. It used to pull percent before oil change. It's a twin cam ka
08-16-2016, 08:21 PM | #20085 | |
All the Nissan cluster temp sensors should be the same one wire plug. Yes if you have a dohc s13 cluster you want a dohc s13 cluster temp sensor. If you have an s14 you want an s14 sensor, etc etc. Sent from my iPhone using Tapatalk |
08-16-2016, 08:57 PM | #20086 | |
ITS LISA'S FAULT!!!
Trader Rating: (41)
Feedback Score: 41 reviews
08-17-2016, 08:14 AM | #20089 | |
08-17-2016, 10:37 AM | #20090 |
Really quick question...Tein coilver camber plates like these here should fit fine on Kei Office type GX fronts right? I'm under the impression that Tein and Kei Office were pretty similar brands. I mean front pillow ball camber plates for coilovers in general are fairly swappable if I'm not mistaken? Or would these only work for Teins?
....ok that was more than 1 question |
08-17-2016, 10:55 AM | #20091 | |
08-17-2016, 11:57 PM | #20092 |
Location: B̷͈͇̠̗͔̼̝̓̎͛͂A̧̡̠̩̭̹̼̭͔̎̃̈́̍͂ͬͬ̚Y̯̜ͨ̒̾̽͊͘ ͈͙̰
Where can I buy these stickers?
★ ★ GRANDMIGHTY.COM ★ ★ |
08-18-2016, 12:06 AM | #20093 |
Anyone know what I should be concerned about when buying a ka24de that's been sitting in a garage for 3 years?
Sent from my SAMSUNG-SM-G925A using Tapatalk |
08-18-2016, 11:43 AM | #20100 |
I think that there's a few of them on ebay for $150. Some of them even comes with good reviews.
