Old 01-17-2017, 07:40 PM   #1
panmanstan
panmanstan's Avatar
panmanstan is an unknown quantity at this point
Noobish S13 horn questions
So my 240sx hatch doesn't have a (The 2) horns in the front. can anyone show me the connectors that go onto the blade and walk me through how to connect a horn to a cheap, disgusting eBay boss hub. Does it go from little brass spring-loaded pin at the bottom to the splined steering rack shaft? Thanks in advance
panmanstan is offline   Reply With Quote
Old 01-17-2017, 09:21 PM   #2
derass
oh man...
read this to get an idea of how the horn button works: http://importnut.net/steeringswap.htm
your car probably still has the relay, make use of that. probably still has the horn connectors up front too.
either get stock 240sx horns or universal ones. it's a simple system
Old 01-18-2017, 05:05 AM   #3
panmanstan
panmanstan's Avatar
Is more for s14's but I understand. I'm more asking what do the connections to the actual horns look like, Before I just run the green wire from the relay straight to the horns. I really don't want to cut my harness more but if i have to I will. Thanks again
Old 01-18-2017, 10:00 PM   #4
derass
That link was about replicating the stock clockspring when using an aftermerket hub. S13 and S14 are the same.
I can't find a pic, but the horns mount here. Open the hood and look for the single pin connectors. Should be really obvious whether they're there of if they've been cut off.
180sx, 240sx, horn, s13
