Old 06-20-2016, 11:42 AM   #1
Joshhankins5
Joshhankins5 is an unknown quantity at this point
RB25 ACL bearing Clearance
I'm currently assembling my motor and I measured my main bearing clearances with plastigage. I only put the plastigage on one side of the bearings and came out with about .038mm all around. I torqued the crank down to 36 ft lbs as the fsm says. The fsm also says the clearances should be in between .020mm to .040mm. Im going for 700whp as my goal. So I know I need more oil clearance for high hp.
So my main question is do I double my clearance measurements since I only put plastigage on the top bearings? Or Should I get some bearings that have more clearance before I assemble it for good?
Any help is great, thanks.
Joshhankins5 is offline   Reply With Quote
Old 06-20-2016, 12:35 PM   #2
hanzbrady
hanzbrady's Avatar
hanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura about
Your measurement is fine, and you do not need any extra clearance than what you have already. The "extra clearance for extra power" mentality is dated. With today's machining capabilities and oil technology that practice isn't needed. All of our engines at the shop are built to FSM spec whether it's a 200hp stock rebuild or a 1400hp drag engine.
[email protected]
hanzbrady is offline   Reply With Quote
Old 07-06-2016, 10:39 PM   #3
MR_GUTTI
MR_GUTTI's Avatar
MR_GUTTI is an unknown quantity at this point
+1 to this guy ^^
You don't have to double the measurement of the plastigage
MR_GUTTI is offline   Reply With Quote
acl, bearing clearance, nissan, rb25
