05-03-2017, 03:22 PM | #1 |
SR O2 Sensor
What can happen if my o2 sensor wont screw into my turbo elbow all the way? Ive had to buy 2 different turbo elbows and im just going to eventually buy a new one once i have the money.. long story short i need to drive with it like this. the o2 sensor is probably about 50% screwed in. is that bad? what can happen?
05-03-2017, 03:28 PM | #2 |
The tip of the sensor should be completely in the flow of exhaust gases to properly read the mixture. With it partially threaded in you will probably have an exhaust leak and the car may not run as it should, probably running richer than normal.
Very similar to how people will space out the second o2 sensors on OBDII vehicles to trick their ECU into not throwing a code when the cats are removed. The spaced out o2 sensor only sees a limited amount of exhaust gasses letting the ECU think everything is okay. |
05-03-2017, 03:36 PM | #3 |
If you have the Fat type 02 sensor this will be much easier and cheaper than a new elbow.
https://m.summitracing.com/parts/lil...ca0xoCU0zw_wcB If you have a skinny sensor I THINK those are M14x1.5 but I could be wrong. |
05-04-2017, 11:45 AM | #5 |
not a big deal. you can unplug the sensor if you are worried about it. engine will run fine as long as you dont have any boost leaks.
This is completely accurate. The maf sensor does a great job by itself without closed loop. I don't even run a narrowband in any of my engine swaps. I've tuned over a hundred cars with no narrowband. They are actually more suited for sheep to drive the car, and not worry about the a/f ratio. Last edited by Kingtal0n; 01-13-2018 at 03:18 AM.. Reason: noted some skepticism |
05-04-2017, 12:15 PM | #6 | |
05-04-2017, 01:21 PM | #7 |
well i pulled out the o2 sensor and im just gonna tap it, now i noticed my threads on the o2 sensor are bad also lmao.. its the fat type aswell and the cheapest one i can find is like $50
05-04-2017, 02:21 PM | #8 | |
https://www.summitracing.com/parts/a...1039/overview/ https://www.nissanraceshop.com/produ...-top-fat-type/ |
05-04-2017, 11:51 PM | #9 |
you can use any narrowband you want. Even a 1-wire will work. Walk down the aisle at auto part store and price check them till you find an $8 or $12 unit and use it. Just match the signal wire to the signal wire and it will work.
05-11-2017, 11:30 AM | #10 | |
S14: https://www.rockauto.com/en/moreinfo...209114&jsn=375 Z32: https://www.rockauto.com/en/moreinfo...209844&jsn=451 |
07-17-2017, 10:58 PM | #11 | |
07-18-2017, 10:21 AM | #12 |
