07-29-2015, 09:09 PM | #1 |
*** 92 S13 - OEM Type X - 1JZ VVTi ***
EDIT* Carbyne Wheels have been sold, the car is now on real TEs with fresh tires. Price includes these 10x better wheels! *
Current Picture: Car currently runs amazing, buyers are fully welcome to come test drive the car and do whatever they want as long as they bring cash. I would keep it but I've got too many cars and could use the money. But I thought a lot about what I was gonna ask for this car and I fully believe that my price is more than reasonable and am in no hurry to sell the car. Thanks Rolando (913) 940-9237 --92 Nissan 240sx -1JZ-GTE VVTI swapped -New Low Mileage Longblock -Full Tech 2 Swap Kit and Wiring -Front Mount Intercooler -All new gaskets, new oil pan, new pickup, new main seals, new timing belt, new vvti oil control valve. new tps, all new fluids as of 10 miles ago. -ACT Heavy Duty Clutch (stiff) -R154 Tranny w/Fresh Redline Fluid -One Piece Steel Driveshaft -S13 welded Diff and FRESH S14 Axles -One Piece Turbo Back exhaust, tucked, no lower than frame rail, magnaflow rear muffler. -Koyo Radiator, with dual pusher fans -Xcessive Manufacturing Skid Plate -Interior -Evo 8 Recaro Front Seats -Grip Royal "Royal Knight" Steering wheel with Boss Hub -Pioneer Headunit with iPod hookup -Blue/Red LED Gauge Cluster Face Plate -Everything else is stock and super clean, inc. uncracked dash. -Exterior -OEM Type X Front Bumper -Clear Junyan Type X bumper lights -Clear Dmax Corner Lenses -OEM Type X Fender Extensions -OEM Style FRP Type X Front Lip -OEM Type X 2 Piece Side Skirts -OEM Type X 3 Piece Rear -OEM Type X Rear Wing Valences -Fairly new Paint on all aero and original paint will be buffed to match new paint as much as possible. -Wheels/Tires -Legit Volk TE37 17x9 +22 on 215/45/18 all around -Suspension/Brakes -Fortune Auto 500 Coilovers -Contano Five Lug Conversion F/R -Godspeed Angled Front Tension Rods -Godspeed Ver. 2 Toe Arms -Ikeya Formula S14 RUCAs -R32 GTR Front Brakes, DIF front lines, and drilled and slotted rotors. -S13 Rear Brakes are drilled and slotted rotors and new-ish brake pads -Tein Tie Rod Spacers -Cons -The recently replaced PS pump squeals on start up because of a leak. -The paint has some discoloration in some areas because it is the original 23 year old paint and then the aero is fresh paint. -Needs subframe bushings pretty badly -Usual dings around the car, no major dents tho. The car is super solid overall, I really love it. Id keep it but need money for my Japan trip in May. Asking price: 12.5k Looking for cash only at this time. Last edited by JDM_Tuner; 02-22-2016 at 08:13 PM.. |
07-30-2015, 09:39 AM | #2 |
Are you running an OEM 1j ecu with no problems? Is this the cable driven 1j, not that electronic throttle bullshit? Are there pictures of the downpipe, etc? Beautiful car.
08-01-2015, 03:59 PM | #4 | |
and its a stock engine with a stock ecu designed to run this engine. i think its okay. |
