Old 04-20-2018, 06:31 PM   #1
xxSleepy562xx
xxSleepy562xx is an unknown quantity at this point
s13 Car won't turn off?
Hey guys! I'm having an issue where my car won't turn off. I replaced the ignition switch with a brand new oem one. The car starts up normally but the problem that I'm having is that the car is stuck on the On position and won't turn off completely. I'd have to stall the car on purpose to shut it off or unplug the maf. It's for an s13 ka24de.
xxSleepy562xx is offline   Reply With Quote
Old 04-20-2018, 07:00 PM   #2
staying_chuki
staying_chuki's Avatar
staying_chuki is an unknown quantity at this point
Are you saying the key gets stuck, as in you cant turn the key back to turn the car off? Or does it stay on after taking the key out?
staying_chuki is offline   Reply With Quote
Old 04-20-2018, 09:06 PM   #3
xxSleepy562xx
Sorry I didn't clarify that part! But yes, the car stays on even when the key is completely out.
Old 04-21-2018, 06:58 AM   #4
staying_chuki
Was this happening prior to replacing that ignition switch? Also is the car stock with stock motor? There's a good few little mistakes you can make on wiring a swap that can cause this. Also ecu could be the culprit.
Old 04-21-2018, 03:29 PM   #5
xxSleepy562xx
Yeah just happened before replacing the ignition switch. Thought a new switch would help but it's still the same. Took out the ecu inspected the inside nothing looks fried or out of place. And the harness for the ecu looks intact. I'm wondering if maybe it could be the relay for ignition behind fuse box on driver side kick panel? Yeah car is stock and stock motor also.
Old 04-22-2018, 04:10 PM   #6
staying_chuki
And it just started doing this out of nowhere?
Old 04-22-2018, 08:34 PM   #7
xxSleepy562xx
Yeah just started doing it out of no where :/
Old 04-23-2018, 01:53 PM   #8
staying_chuki
Car won't turn off?
Hmm thats weird, next time you mess with it try unplugging the ignition switch after you've taken the key out. There's still a chance that your problem lies there even with a new one. Also try unplugging the alternator after taking the key out. Just a few easy tests to check, and do the accessories still work after the key is removed? Blinkers, radio, ac, etc.
Old 04-26-2018, 07:28 PM   #9
xxSleepy562xx
Everything is good now, thanks for the help brotha much appreciated!
Old 04-27-2018, 07:34 AM   #10
staying_chuki
Ahh nice man, just outta curiosity, what did it end up being?
Old 05-01-2018, 11:07 AM   #11
xxSleepy562xx
Ended up being that the fans were connected to a constant power and i guess kept staying on.
Old 12-09-2018, 01:42 PM   #12
Strebloboost13
Strebloboost13 is an unknown quantity at this point
Hey, I'm having this problem with my ls swapped s13. I've been chasing the problem all over my car. What I've come up with so far is that if I unplug my alternator sensor wire the car will shut off with the key. If I take the accessory relay out under the drivers side kick panel it will start and shut off like normal but with no gauges obviously. And even if I don't start the car and put the key to run (again not start) I have to cycle the key twice from run to off to get the accessory relay to close. There's back feeding somewhere but I can't find it yet. I've tried wiring in a diode on the alt sensor wire because I though current was getting back through it but that didn't do anything. Any help would be so greatly appreciated.
Strebloboost13 is offline   Reply With Quote
