02-18-2017, 08:11 PM | #1 |
1998 Kouki w/Sr20 Notchtop $5,500
SOLD SOLD SOLD SOLD SOLD
She's got a new home. UPDATED 19FEB2017 with pictures and more info Will attach more pictures shortly20161119_170040.jpg 20161119_170029.jpg 20170219_153901.jpg 20170219_153927.jpg 20170219_153936.jpg 20170219_153954.jpg 20170219_154031.jpg 20170219_154051.jpg 20170219_154053.jpg 20170219_155055.jpg Selling my Kouki 240sx (S14). Lots of mods Sr20det notchtop 71mm turbo FMIC 550cc Injectors Z32 Maf Chipped ECU Lightweight Chromoly Flywheel (ACT) 6 puck Kevlar/Ceramic clutch (Competition clutch) Short Throw Shifter Aluminum Driveshaft Helical LSD (S15) R32 GTR Brakes/rotors (11.7" all round) 18x8.5 x ADR Wheels Carbon Fiber Hood Odyssey battery (Relocated to trunk) BC Racing Adjustable coilovers Moog Adjustable tie-rod ends Megan Type II exhaust Greddy downpipe Mitsumoto Aluminum radiator The Bad - New Motor mounts - They are stiff and do transmit vibration from engine - Over 250k miles (almost all highway, and I'm the 2nd owner) -----------est 100k miles on the engine - Back passenger window needs replaced (it's shattered,, but sealed) - You'll need to readjust the parking brake line. It pulls back too far, so doesn't fully engage - Wipers do work, though just one speed. You'll need a wiper amplifier from an Sentra/200sx. You can get them for $35 or so. - Wiper mister is 50% installed. I ran a hard line down the bottom along side the brake lines. There is universal wiper reservoir in the back. You'll just need to make a bracket for it, and run the wire from the from to the back. - You'll need to bolt the back seats back in - You'll need to reinstall the power steering pump (I've got it,, you'll just need to put it back in) - Hood will need to be repaint eventually (small crack in paint),, it is a carbon fiber hood. - I took out the A/C compressor, but it worked beforehand. I just took out the compressor to re-thread the oil return line for the turbo, and tighten the dip stick. You will need custom lines, but electrically, it is all set up. So you'll just need to ------------1. Bolt the compressor back in -------------2. Get and install custom lines -------------3. Vacuum and fill.. you're good to go Last edited by guitaraholic; 02-27-2017 at 02:22 PM.. |
02-19-2017, 03:24 PM | #7 |
I don't see why not. Won't be super comfortable though. It sat a long time in storage while I was overseas,, so the tires have a few flat spots. I've got them pumped up to 45psi (max),, and it's not terrible,, but you do feel it.
02-19-2017, 05:21 PM | #8 |
I have the 1/4 window already removed for the person that buys this !
Www.PowerAutosports.com |
02-21-2017, 07:33 PM | #11 |
Is that gauge pod bolted to the dash, or stuck on somehow?
Easier question... are there holes in the dash because of the gauge pod?
95' S14, Kouki front, KW V3, RPF1's, caged, built LS6, rebuilt t56... drives pretty good. |
