05-26-2014, 11:17 AM | #1 |
Do I have an LSD?
Hello,
I have an 89' 240sx. I had my car on Jack stands the other day and noticed both my rear tires spun. I thought stock s13 only spun 1 tire. Please help me understand if this is normal or he I have an LSD installed. Thanks Sent from my SGH-I747M using Tapatalk
05-26-2014, 02:33 PM | #4 |
Ya both directions it spun
05-27-2014, 03:20 AM | #7 |
Is there a HICAS sticker on the back of your car? If yes, the car has a viscous lsd.
If not, answer the question fliprayzin240sx asked.
Do need the Factory Service Manual? Click here. |
05-27-2014, 05:27 AM | #8 |
I have been doing some research. Seems like 89-90 didn't come with lsd, but the mechanic I bought the car off could have put one on.
I don't think I have a hicas sticker. I did have abs. So there could have been a sport package added on at time of purchase. I'll have to test it out in 2 weeks once I get back home
05-27-2014, 05:29 AM | #9 |
I had my brother in law look at the tires. I don't think he was looking to see which direction they were going
05-27-2014, 08:24 AM | #11 |
Does it matter which tire is on the pavement?
05-27-2014, 08:56 AM | #12 |
Lift the rear tires off the ground, put trans in neutral.
Test 1 Spin drivers wheel, look at the direction the passenger wheel spins. Test 2, have someone hold the passengers wheel while you spin the drivers wheel. Test 3, remove diff and look inside. You could also spin the drive shaft and look at the direction the wheels spin. The drive wheel is the driver side usdm, iirc That wheel should be in the grass, mud or snow for the dump test. If not try both wheels. Sent from my Highly Tuned Galaxy S3.4!!!
05-27-2014, 09:22 AM | #13 | ||
Either way, drive around, then find an empty place and do a burnout. 1 tyre mark = open diff or dead VLSD, 2 marks = working LSD. Mind you, OEM VLSDs are non serviceable, and most of them are already done for now. They usually overheat and kill their oil (NOT the diff casing oil) after 60.000km. These OEM VLSDs are supposed to help transfer power in difficult conditions, like rain or snow. They won't work well after a couple of turns once you try to put some power through them. |
04-12-2018, 08:34 PM | #14 | |
What he said^ Jack up the rear and try spinning the wheel. If both tires spin in the same direction you have a LSD/VLSD. If one tire spins the opposite way, you have an open diff. |
