Old 11-12-2013, 09:16 AM   #1
Build4Boost
Build4Boost is an unknown quantity at this point
89 2jz/R154 Cressida
1989 Toyota Cressida
Unknown mileage (Odometer doesn't work)
Pearl white'ish
$8k
Engine:
-Aristo 2jzgte (From JEI in VA)
(All parts replaced with OEM Toyota parts)
New timing belt
New Usdm water pump (converted)
New front and rear Crank seals
New cam seals
New Valvecover gaskets
New NGK plugs
New Coils
New coil connectors
New Ignitor
New MK4 denso fuel pump
New TPS
New Alternator
New computer (Have 3 of them)
-Xcessive manufacturing solid engine mounts
-Xcessive manufacturing mount plates
-Xcessive manufacturing 2J mount brackets
-CX racing intercooler kit with 4" intercooler, 3" inlets
-HKS SSQV (older style) with purple insert
-3" turbo-back (fabbed with steel)
-Greddy FCC
-Battery relocated to the trunk
WIRING WAS DOWN BY A PROFFESIONAL AND DONE CORRECTLY.
Turbo's are currently set up on TTC mode on 15psi.
Drivetrain:
-R154 (freshly rebuilt with Marlin crawler parts)
(all parts replaced with OEM Toyota parts, pretty much a brand new, 0 miles transmission)
New shifter housing
New housing gasket
New housing hardware
New bellhousing
New tailshaft seal
New MK3 clutch master cylinder
New slave cylinder
New misc. transmission hardware
-South Bends endurance Feramic clutch kit
-Custom 1-piece aluminum drive shaft (New u-joints)
-Xcessive manufacturing solid trans mount
-Xcessive manufacturing trans mount bracket
Suspension
-Xcessive manufacturing BC full coilovers
-Xcessive manufacturing front tension rods
-Xcessive manufacturing front tension rods bushings
-New OEM diff bushings
-All new bushings in the rear
-G35 wheels (Brand new tires)
Extra's:
-NRG short hub
-NRG quick release v2.5
-Royal grip- Royal woodie steering wheel
-NTK AFX wideband
-APEX'i 60mm electronic gauge
water temp (functional)
-v2 greddy gauges (Boost and oil pressure)
BAD
-Paint. Its a 25 year old car, and looks its. There is no body damage or major flaws. but the paint on the roof and trunk has clear coat spots, the clear coat on the passenger door is peeling. and there are some very minor surface rust spots. ZERO RUST ON THE FRAME.
-Interior. Dash is cracked and the carpet is a little dirty, but that's it. windows and locks are functional
-The front bumper, when I bought the car, was in rough condition, so I srcapped it.
Build4Boost is offline   Reply With Quote
Old 11-13-2013, 05:52 AM   #2
Build4Boost
^^^bump^^^
Old 11-13-2013, 06:13 AM   #3
240obsessed
240obsessed's Avatar
240obsessed is an unknown quantity at this point
Bump for buying my wheels haha.
240obsessed is offline   Reply With Quote
Old 11-14-2013, 02:12 PM   #4
Build4Boost
Bump^^^^^^
Old 11-18-2013, 06:53 AM   #5
Build4Boost
upupupupupupup
Old 11-25-2013, 07:12 AM   #6
Build4Boost
upppppppppppp
Old 11-25-2013, 08:05 AM   #7
Hatemy7
Hatemy7's Avatar
Hatemy7 is an unknown quantity at this point
so what is the price?
Hatemy7 is offline   Reply With Quote
Old 11-25-2013, 09:03 AM   #8
Build4Boost
I couldn't let it go for less than $10k
Old 11-25-2013, 12:00 PM   #9
charmcitydrifter
charmcitydrifter is an unknown quantity at this point
BUMP for a clean car, everything was done right. worth every penny.
charmcitydrifter is offline   Reply With Quote
Old 11-25-2013, 07:46 PM   #10
fcnoevil
fcnoevil is an unknown quantity at this point
hate to burst your bubble but your gonna have to adjust your price if you even thing this is gonna sell
fcnoevil is offline   Reply With Quote
Old 11-26-2013, 03:54 PM   #11
Build4Boost
Thanks for your input.
Old 11-27-2013, 02:38 PM   #12
Build4Boost
ertertertert
Old 01-02-2014, 07:41 AM   #13
Build4Boost
upupupupupppuup
Old 01-03-2014, 09:42 AM   #14
Kennybhybrid
Kennybhybrid's Avatar
Kennybhybrid is an unknown quantity at this point
What are u trying to trade for
Kennybhybrid is offline   Reply With Quote
Old 01-05-2014, 07:43 AM   #15
Build4Boost
Its really up in the air. Im open to anything. I would like something Lsx swapped. No sr20's
Old 01-05-2014, 08:22 PM   #16
fcnoevil
Dreamer... not worth even close to 10k... not being a dick but as of right now its a stock cressida with a stock swap... no kit no baller wheels not suspension work... how do you figure its worth 10k? that can be built for half your asking price
Old 01-05-2014, 11:49 PM   #17
BkCressida1718
BkCressida1718 is an unknown quantity at this point
i can barely sell mine and I'm asking half your price and its more modified
BkCressida1718 is offline   Reply With Quote
Old 01-06-2014, 03:51 PM   #18
Build4Boost
I posted the car for trade. I appreciate your concern though.
Old 04-01-2014, 06:55 AM   #19
Build4Boost
BumopBumpBump
Old 04-08-2014, 09:10 AM   #20
Build4Boost
tyutyutyutyu
Old 04-08-2014, 01:21 PM   #21
hat trick
hat trick is an unknown quantity at this point
Sweet car, GLWS
1jz e36 m3
hat trick is offline   Reply With Quote
Old 04-08-2014, 03:13 PM   #22
Nismobound
Nismobound's Avatar
Nismobound is an unknown quantity at this point
Don't think you've ever owned a kinda car
Nismobound is offline   Reply With Quote
Old 04-10-2014, 08:57 AM   #23
Build4Boost
Thanks mike.
Old 04-15-2014, 06:33 AM   #24
Build4Boost
upupupupupupupup
Old 04-22-2014, 07:15 AM   #25
Build4Boost
bump it up...
Old 04-22-2014, 08:21 AM   #26
h2v7
h2v7 is an unknown quantity at this point
tell me more about the Feramic
jk nice car i like it
h2v7 is offline   Reply With Quote
Old 04-24-2014, 09:51 PM   #27
Bradswrx
Bradswrx is an unknown quantity at this point
Trade for 95 emerald blue s14? Car makes roughly 340 to the wheels and is 8/10. Pm me for details.
Bradswrx is offline   Reply With Quote
Old 05-05-2014, 12:59 PM   #28
Build4Boost
I messaged you the other day, still no reply...
Old 05-06-2014, 06:04 PM   #29
B-Rock
B-Rock is an unknown quantity at this point
Hey I have a few question about the car, can you call or text me at 410-253-3628 thanks Bryan
B-Rock is offline   Reply With Quote
Old 05-22-2014, 11:54 AM   #30
pelliccio77
pelliccio77 is an unknown quantity at this point
i have a car you might be interested in. check out my posts or text me. 318-751-3323
-Tony
pelliccio77 is offline   Reply With Quote
