05-27-2016, 11:49 AM | #1 |
Enthalpy Tune on Stock SR20DET
Hey guys, I've searched for an answer and couldnt find what I was looking for. I have an s14 sr20det, and the thoughts of tuning it have crossed my mind. I was looking at getting my ecu flashed by RS Enthalpy, but I'm wondering if it's worth it? I know Martins tuning is good. But for my current set up I'm just wondering if tuning will really open up the car more??
I dont really plan on getting bigger injectors or cams or anything like that. Just gonna keep the engine stock. These are the mods I have currently. Will I get a little more power from a tune?? without cams, or a bigger turbo or bigger injectors? Any input would be appreciated. Boost Max is currently at 11psi at WOT. AFR ratios are 14-15 during regular driving. 10-11 during WOT. •S14 sr20 swap done right (by previous owner): Replaced all gaskets and seals, intake manifold, Tomei exhaust manifold, Circuit Sports down pipe •New Cometic metal head gasket, new ARP head studs, resurfaced head, new oil pump and oil pressure sensor, and Circuit Sports rocker arm stoppers •Stock T28 Turbo •Wiring harness by wiring specialties •Greddy FMIC and piping with new HKS SSQV •SPEC stage 2 clutch •New clutch master cylinder ss clutch line and slave cylinder •DriveShaft Shop aluminum driveshaft •Koyo aluminum radiator •Altima dual e-fans •Full 3" turbo back Exhaust Last edited by Kidshifty88; 05-27-2016 at 12:31 PM.. |
05-27-2016, 12:11 PM | #2 |
Stock SR20DET tune is notoriously pig rich, which is evident by your low AFR at WOT. Very very safe from the factory, but that leaves some power on the table.
You won't get crazy gains by getting a tune, however at the same time if you have no plans to upgrade in the future I personally would get it tuned. Your exhaust and possibly turbo itself (depending on dimensions) will benefit from a tune alone. |
05-27-2016, 12:36 PM | #3 | |
Came across the enthalpy tune and saw how everyone loved it, and wasn't too expensive so I thought about it. The 240 is my daily, so longevity is something I'm really keeping in mind. Just wanted to get a little more kick outta the engine with possibly a tune if possible. Thanks for the input! |
05-27-2016, 12:37 PM | #4 |
Enthalpy is always worth it.
MRP Manufacturing |
05-27-2016, 02:40 PM | #8 |
you can gain a bit 10~Hp doing this. Its just not safe to push the limit on anything you care about in general, and enthalpy knows that. most of your power increase with these engines comes from larger turbochargers. often the one stock on the engine is old and worn out, with unknown mileage, and thats your biggest block to power increase.
if you want more power 100+ you have to upgrade the turbo. And that means bigger injectors also. Which means you have to get the ECU re-tuned again. |
05-27-2016, 09:54 PM | #10 |
That is absolutely not true.
MRP Manufacturing |
05-30-2016, 07:04 AM | #12 |
Your money would be better spent on an HKS adjustable waste gate actuator and a boost gauge.
Crank your boost to 11psi. Also what you've failed to note is Enthalpy tunes only work with Z32 maf.
05-30-2016, 08:36 AM | #13 |
Z32 maf
550 injectors Enthalpy tune (base) 260 whp + or - depending on air density Worth every penny! I've been beating the crap out of my sr for 10 years. 100k + miles Enthalpy is the shit! |
05-31-2016, 09:35 PM | #14 |
06-02-2016, 11:24 AM | #15 |
I'd say for a bone stock sr with fmic and exhaust no, but if you want like 300-400 rs is fine, anything above that then get a dyno tune. Of course a 300hp dyno tune is fine tooo but martins done so many he knows whats up. I made 315whp with an hks gt-ss 550's and a z32 maf on his ecu. Car runs awesome too!
06-02-2016, 11:34 AM | #16 |
06-04-2016, 09:06 PM | #17 | |
Thats not true.
98 240sx w/ S15 SR20DET, T2 20g, 11.22 @ 124.98 |
