Old 02-18-2002, 11:25 PM   #1
drift freaq
R.I.P. Aya, always love
drift freaq's Avatar
Trader Rating: (215)
Feedback Score: 215 reviews
95 240sx VLSD $450 and its yours i am in Los Angeles
shipping would be about $70 to just about anywhere in the U.S.
Old 02-19-2002, 02:09 PM   #2
240meowth
240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all
Send a message via AIM to 240meowth
ahh, will it fit on a s13?  i don't know if i got all that money!!! you suck... btw i called brett @ fullurton suburu, he said he needs the part #... any idea dave?
240meowth is offline   Reply With Quote
Old 02-19-2002, 02:14 PM   #3
drift freaq
yes it will meowth. you just have to shorten your driveshaft 1 inch due to the ABS sensor. unless yo have ABS already then it will bolt right in.
Old 02-19-2002, 07:44 PM   #4
will
will is an unknown quantity at this point
aah, the infamous Sid Viscous LSD, must be bad <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/wink.gif" border="0" valign="absmiddle" alt=';)'>
TTT
will is offline   Reply With Quote
Old 02-20-2002, 10:22 AM   #5
drift freaq
bump
Old 02-21-2002, 11:20 AM   #6
drift freaq
bump again:biggrin:
Old 02-21-2002, 11:35 AM   #7
black0ut
black0ut is an unknown quantity at this point
Send a message via ICQ to black0ut
What exactly goes into shortening the drive shaft? What is the difficulty? Expense? Thanks!
...contact me...
black0ut is offline   Reply With Quote
Old 02-21-2002, 12:01 PM   #8
AJ
AJ is an unknown quantity at this point
Send a message via ICQ to AJ Send a message via AIM to AJ
what is the dif between this lsd and a j30 lsd... j30 ones can be had for 300ish i believe.. correct me if i'm wrong, i need a lsd bad..
AJ is offline   Reply With Quote
Old 02-21-2002, 01:00 PM   #9
Grant
Grant has a spectacular aura aboutGrant has a spectacular aura aboutGrant has a spectacular aura aboutGrant has a spectacular aura aboutGrant has a spectacular aura aboutGrant has a spectacular aura about
Send a message via AIM to Grant Send a message via MSN to Grant
Why does the 240sx LSD cost $150 more than the J30 LSD?
Grant is offline   Reply With Quote
Old 02-21-2002, 01:27 PM   #10
drift freaq
Ok guys here are the two answers. One the J30 is a 3.92 gear which means it will be better off in a Turbo car hence me keeping the low mileage J30 VSLD I have current. Into my car it goes:biggrin:
Two , a lot of people just have to have a Genuine 240sx VLSD with 4.08 gears
they are a either afraid of putting in the J30 or B are aware of the slight gearing difference and are afraid of it affecting there off the line performance. Truth is unless your drag racing on a regular basis you won't notice it. Its probably a 1/10-4/10's of sec difference. those figures are only guess work seeing as their are a lot of variables that could actually change them so an accurate figure would need to be done with two stock cars with the two different rear ends setup in the exact same way. LIkelyhood?? not .:)
I have after extensive research into the issue concluded that throwing the J30 rear end in my car now before I have done my Turbo setup will not affect my acceleration adversly so in it goes.
And up for sale goes the 240sx VLSD. oh yeah new price $400 today $425 tomorrow so speak up or hold your peace
Old 02-21-2002, 01:53 PM   #11
black0ut
Hey you freaq!!! You forgot to answer my questions! :-) Scroll up a little bit... I've got some money to burn, but I'm not sure which way it's going yet. Let me know! Thanks!
...contact me...
Old 02-21-2002, 09:58 PM   #12
drift freaq
blackout, if you need to shorten your driveshaft a drive shaft shop can do it for like $50, Ok if your car is a 95 or newer you do not need to worry about that. If its an S13 it may or may not need I will get some more info on that shortly.
Old 02-21-2002, 10:11 PM   #13
Omega
Omega is an unknown quantity at this point
sorry this is off topic but how do i tell if i have a LSD? i also ahve a 95 and its a SE did all SEs have them? what exactly do they do, i understand the name and all but..
can anyone point me in the right way
Omega is offline   Reply With Quote
Old 02-21-2002, 11:46 PM   #14
vancouvers14
vancouvers14 is an unknown quantity at this point
Send a message via ICQ to vancouvers14
hey freaq, would swapping an s13 lsd into an s14 require shortening the driveshaft?
vancouvers14 is offline   Reply With Quote
Old 02-22-2002, 12:35 AM   #15
drift freaq
Omega , the simplest way to see if you have VLSD is to jack up the rear of your car out of gear. of course block your front wheels:biggrin: then have a friend grab a wheel and hold it as you spin the other if it fights him and rotates the same direction you are rotating then its VLSD if it stays still or goes the opposite direction you have a open rear end.
no Vancouver putting a S13 VLSD in a S14 will bolt right in you just need to put the back cover off your stock rear end on the S13 VLSD because S13 covers were 4 bolt and S14 were 2 bolt
Old 02-22-2002, 12:36 AM   #16
drift freaq
Old 02-22-2002, 03:38 AM   #17
Grant
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">Quote: from drift freaq on 12:27 pm on Feb. 21, 2002
</td></tr></table><span id='postcolor'>
so basically the higher price is due to the higher demand for this item..
Old 02-22-2002, 10:50 AM   #18
Guest
Posts: n/a
thats an affirmative... ####, my first gear is too short anyways, screw that 240 lsd,, i want a j30 <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=':)'> &nbsp;it'd be so much nicer around town and through corners... (if there is much diff at all.)
Old 02-22-2002, 01:02 PM   #19
Grant
hehe, J30 it is.
