07-24-2014, 03:34 AM | #1 |
GKTech - Spacers 15mm > 30mm, 8 Piece Sets
4x114.3 Spacers 15mm > 30mm 8, Piece Set
The GKTECH 15mm > 30mm spacers allow for adjustment of the fitment of your wheels. The set allows for 14 different widths to be made to ensure perfect wheel fitment. The 14 possible widths are 3,5,7,8,10,12,15,18,20,22,23,25,27,30mm. The wheel spacers are hub centric to suit Nissans 66.1mm hub and are manufactured to the highest quality in T6061 Aluminium and then hard anodized to further increase the strength. The ultimate adjustable width set of spacers. Features: - CNC machined aluminium T6-6061 construction - Grade 10.9 studs - Hub centric to suit 66.1mm Nissan hubs - 114.3mm PCD with M12 x 1.25 thread - 60mm long studs - Sold as a PAIR Price: 114 AUD (approx. 98 USD) Shipping cost: From 77 AUD (approx. 73 USD) Zilvia.net intro offer of $30 shipping credit when you spend over $100 using the discount code "Zilvia.net" in the checkout for the month of July. ORDER HERE: http://www.gktech.com/index.php/4x11...piece-set.html 5x114.3 Spacers 15mm > 30mm 8, Piece Set The GKTECH 15mm > 30mm spacers allow for adjustment of the fitment of your wheels. The set allows for 14 different widths to be made to ensure perfect wheel fitment. The 14 possible widths are 3,5,7,8,10,12,15,18,20,22,23,25,27,30mm. The wheel spacers are hub centric to suit Nissans 66.1mm hub and are manufactured to the highest quality in T6061 Aluminium and then hard anodized to further increase the strength. The ultimate adjustable width set of spacers. Features: - CNC machined aluminium T6-6061 construction - Grade 10.9 studs - Hub centric to suit 66.1mm Nissan hubs - 114.3mm PCD with M12 x 1.25 thread - 60mm long studs - Sold as a PAIR Price: 114 AUD (approx. 98 USD) Shipping cost: From 77 AUD (approx. 73 USD) Zilvia.net intro offer of $30 shipping credit when you spend over $100 using the discount code "Zilvia.net" in the checkout for the month of July. ORDER HERE: http://www.gktech.com/index.php/5x11...piece-set.html FAQ What torque should the nuts be set to? As per the Nissan tech guide we recommend a torque setting of between 72-87 Ft. Lbs. Anything more than this will strip the stud and is DANGEROUS. The setting of 72-87 is as per Nissans specifications. Are these wheel spacers hub centric? The 15mm spacer is to suit a 66.1mm (Nissan) hub and the 15mm spacer sits hub centric. The slip on spacers (7mm, 5mm and 3mm) are not hub centric. What exactly am I buying? You will get a pair of 15mm bolt on spacers, slimline nuts to suit and a pair of 7mm, 5mm and 3mm slip on spacer (8 pieces in total). Are these wheel spacers strong? Yes, these wheel spacers are very strong. The spacers themselves are manufactured from T6-6061 Aluminium and we use grade 10.9 fittings. That said, please note that these are for off road use and are not intended for use on public roads. Do you have wheel spacers to suit other vehicles? No, we only sell the products listed on our website. If it's not listed on here, then we don't sell it. We don’t do any custom work and only sell off the shelf products so can’t make any changes to what is for sale here. Sorry. Do you have extended wheel studs available on their own? Yes, we have extended wheel studs available in packs of 10 in our other listings. Please refer to the other listings for more information. Do you have 4 to 5 stud wheel adapters? Yes, we have 20mm hub centric 4 to 5 stud wheel adapters available. Please refer to the other listings for more information. For any inquiries please e-mail us at [email protected]. |
