07-21-2014, 03:20 AM | #1 |
GKTech - High Misalignment (64 degrees) Tie Rod Ends (12mm/14mm)
GKTECH have teamed up with QA1 to produce these high misalignment (64 degrees) tie rod ends. These tie rod ends provide up to 25mm of bump steer correction and also come with 3 different length rods (standard length, +15mm and +35mm's). Although these may look pretty similar to other tie rod ends on the market, don't be fooled as they are different (in a good way). Almost all tie rod ends on the market that use rose joints are NOT using high misalignment bearings and wear out in no time at all. OEM type tie rod ends provide around 60 degrees of misalignment and it is critical that around this level of misalignment is kept. Another common issue with most aftermarket style tie rod ends is that there is no protection from dust and dirt. We've developed dust boots specifically to suit the QA1 PCYML10T rose joints that we use in our kit. It's also pretty common for shanks to bend under high loads, our shanks have a tensile strength of 176ksi (class 12.9) - Corrects bump steer - Uses QA1 5/8" high misalignment rose joints - 3 different length rods (standard length, +15mm and +35mm's) included - Available in both 12mm and 14mm (specify at the time of ordering) - Dust boots included Vehicle Compatibility: - Nissan S13 Silvia - Nissan 180sx - Nissan S14 200SX - Nissan S15 200SX - Nissan Skyline R32 GTS-T - Nissan Skyline R33 GTS-T - Nissan Skyline R34 GTS-T - Nissan A31 Cefiro Price: 129 AUD (approx. 104 USD) Shipping cost: From 61 AUD (approx. 57 USD) Zilvia.net intro offer of $30 shipping credit when you spend over $100 using the discount code "Zilvia.net" in the checkout for the month of August. ORDER HERE: http://www.gktech.com/index.php/high...12mm-14mm.html FAQ How hard are these to install? Remove your old tie rod ends and install these. It's a very self explanatory install and shouldn't take longer than 30 minutes. Will this fit my car? If your car is listed above then this is a straight fit. Do I need a wheel alignment after installing these? Unless you get the length spot on perfect, you will need a wheel alignment after installation. Why do you include 3 different length rods? As with our knuckles, often the tie rod end position is moved and you'll need longer tie rods. Now with our kit, you can keep your standard tie rods and just use the corresponding rods that we supply in this kit. For any inquiries please e-mail us at [email protected]. Last edited by GKTECH; 08-04-2014 at 02:37 AM.. |
07-22-2014, 05:13 PM | #2 |
i was just checking this out on your website..
What Inner tie rods are these made to work with? I currently have Tein inners on my S13. And what length would I need to use with Tein inners and s14 knuckles. Used for daily use and occasional grip/track driving Thanks |
07-23-2014, 01:23 AM | #3 |
We make both M12 and M14 kits to suit all tie rod inners. Our kits come with 3 different length rods as standard and with standard knuckles you'll want to run the shortest rod.
07-24-2014, 02:02 AM | #5 | |
I don't quite understand the first question though. |
