03-10-2012, 03:38 PM | #1 |
Z-Fever builds SR20 powered 350Z w/ all OEM functionality
We just started a really cool build. We had a customer bring us an 03 350Z and he wants a truly unique set up. It is getting an S14 SR20DET. We are fully building the engine, making a top mount manifold (custom) with a Garrett 3076 (GT30R) turbo and 850cc inj's. our goal is to do something no one has done before though. We are keeping the OEM drive by wire set-up from the 350Z and running a dual ECU set-up. This will allow us to manage the engine as well as to maintain the VTC, traction control, cruise control, and all factory gauges. The S14 ECU does not run can-bus but the 350Z's does. This is a cool build. I hope you like it.
Here are the pics as it is coming together. I will add pics as the build continues. and here are all the parts we are using to build the engine: 850cc injectors New OEM S14 oil pump New .20 over CP pistons New HKS 264 step 2 camshafts New Supertech performance spring and retainers New Cosworth 87mm x 1.1mm metal head gasket New SCAT forged rods New ARP head studshttp://a4.sphotos.ak.fbcdn.net/hphotos-ak-snc7/301868_10150373688798296_296402898295_9772422_5538 780_n.jpg[/img] New ARP main studs The engine has been sent out, hot tanked, bored .20 over, and honed. The crank was polished and balanced. The head has been completely reconditioned and the new springs, retainers, and cams are installed. And of course, this is the heart of it all... the Garrett GT30R (3076) fully ball bearing beast. This power plant should make an easy 500whp on pump gas. I know that some people will not like this build because we have taken out a perfectly good running VQ35 that we could have boosted and made 400whp or built and gotten more than 600whp. All true, but we have done 100 350Z's just like that. This is something unique that you won't see 50 of at a car show. And the way we are doing it is truly inspiring. I don't think anyone has maintained all the OEM functionality of the gauges and drive-by-wire. I hope ou like it. We have finally built the engine and are getting ready to install into the chassis. Here are pics of the engine build: Installing the Supertech springs and retainers The powder coated S14 valve cover. It is polished then black satin coated Now we are putting the bottom end together with all new pistons, rings, main bearings, rod bearings, ARP's and metal head gasket: New performance oil pump gears: Then we installed the front timing cover: Then we installed the ARP head studs, Cosworth head gasket, and cylinder head. Along with in the intake manifold, valvecover, and custom made exhaust manifold: I will post more pics after we get the engine set in place and start building the custom engine and trans mounts... Here are the engine mounts we made for this build: [img] http://a6.sphotos.ak.fbcdn.net/hphot...14186896_n.jpg [/img] And here is what the engine looks like in the car Here is the VQ35 drive-by-wire throttle body installed onto the S14 intake We are using a Greddy VSPL front mount intercooler and have it mounted already We started making the turbo manifold today. Using T304 stainless 1/2" flange we made and schedule 10 T304 stainless bends {img]http://a5.sphotos.ak.fbcdn.net/hphotos-ak-ash4/396732_10150633848578296_296402898295_10929013_121 0737757_n.jpg [/img] We went ahead and threw my ITS T72 on it just so we can see how cool it looks. More pics to follow: We finally got her running today. Still have a few things to do but EVERYTHING works. The VTC, cruise, speedo, oil peressure, temp gauge, etc... Drive by wire throttle body functions. It is as though the SR20DET came in this 350Z (except it is 500hp). Here is a video for you to check out: http://www.youtube.com/watch?v=0ikTn0FYf4c PLEASE LET US KNOW WHAT YOU THINK!
Z-Fever, Inc 813-877-7600 www.zfever.com or www.VQ35swap.com Last edited by Z-Fever; 03-10-2012 at 04:51 PM.. |
03-10-2012, 04:03 PM | #3 |
Trader Rating: (22)
Feedback Score: 22 reviews
Damn that's a sick oil cap! Know where i can also get one?
And these builds are always top notch, love reading through them. Keep up the good work! |
03-10-2012, 04:08 PM | #4 |
These are available on ebay. We are not leaving it on the engine. We put it on there for the picture.. It matched the purple velocity stack...
Z-Fever, Inc 813-877-7600 www.zfever.com or www.VQ35swap.com |
03-10-2012, 04:39 PM | #8 | |
Trader Rating: (18)
Feedback Score: 18 reviews
I am also in the middle of doing an sr in a 350z (I have a build thread on here)
https://instagram.com/eck_matthew/ |
03-10-2012, 04:54 PM | #10 |
I LOVE the idea and that is truly some great work but I don't like the way it went.
I think it would have been cooler to install a lightly modified sr20, something believable with a tune. Plus that Z looks GROSS imo. Totally ruins it for me lol, but whatever, not my car. Very nice work by you guys though.
03-10-2012, 04:59 PM | #11 | |
Signal Auto of Japan also built one, same thing though...No OEM electronics worked. Ours has VTC, cruise control, gauges, can-bus functionality, the works.... This is truly the coolest thing about this build. It took us a few weeks to get the full OEM functionality to work. It is a very tricky wiring job that required the use of both the SR20 and the VQ35 ECU's to work together. We still need to finish the ROM tune on the SR's ECU. We will get a few miles on it and then stick it on the dyno and fully tune it.
03-10-2012, 07:27 PM | #13 |
This looks likes very solid, well thought out, and properly funded build and I'm sure it will be awesome.
That said with all the great motors out there why the old school SR20? Why not a new 6 liter hemi. Or a LS7 or a v10 from a Gallardo? I mean really. The SR20 is old tech. I have a SR. Aspiring shop's and builders should be thinking for the future not the past. Why not make something truly unique? Put the 3.5 liter v-8 from a 355 in that shit if you wanna go backwards in technology. Shops and builders need to start moving forward with the swap strategy. This shit is getting boring. BTW that vid is pretty cool. |
03-10-2012, 08:06 PM | #15 |
How did you tune it? Did you just tune the stock 350x ecu to replicate the sr? I dont understand how that was accomplished. How was the drive via wire accomplished as well?
What was his total $$$$$ out the door? |
03-10-2012, 08:17 PM | #17 |
Oh Florida. When building an SR at the end of the day it really doesn't make much difference what generation you start with. Also the 6spd is garbage. He would do good to just mate the 350Z 6spd to the SR.
03-10-2012, 09:43 PM | #20 |
looking good keep it rolling and actually finish updating...
zfever...u guys only answer whatever questions u guys want...my self and many ask questions and u guys dont answer |
03-10-2012, 10:18 PM | #21 | |
There was a member on here who weighed the KA, SR, and VQ and they all weighed the same give or take a couple pounds. (pretty sure it was Fred Allen Burge). He USED to have pics of everything, but they've been taken down I guess. So it's not lighter. The SR may be cheaper if you have no motor to start with, but I can't see swapping out a VQ to install an SR being "cheaper". I could argue that the SR is longer, so I can't see it sitting further back. Being easier to work is relative. What's easy for you may not be easy for someone else and vise versa. Plus I don't see how trying to set up 2 ecu's to work in conjunction with each other is easier either. This seems like a lot of hassle just to be "unique". And I'm not really seeing any "positives" to it. |
03-10-2012, 10:33 PM | #22 |
03-10-2012, 11:19 PM | #23 |
I'm aware of that. Which is why I asked "why SR? Just to be unique?"
As to inquire that the OP may know why the customer wanted it done for another reason other than to be unique. |
03-10-2012, 11:59 PM | #24 |
Car looks HORRIBLE but the motor and build seems legit. Some good working you guys have done. I would have left the vq in or done an rb....Sr seems like a down grade to me.
03-11-2012, 12:12 AM | #25 | |
It's Always Broken.
I wouldnt have chose an SR either, but the quality of the work looks to be very good
03-11-2012, 12:26 AM | #26 |
good work!!!
03-11-2012, 12:26 AM | #27 |
BEFORE
You go around spamming your build thread on every forum. Make sure you didn't already make one. http://zilvia.net/f/chat/423922-z-fe...rive-wire.html
Nagasaki Motors Friends help you move. Real friends help you move bodies. |
03-11-2012, 12:44 AM | #28 |
the build looks great!!!!
buildhttp://zilvia.net/f/chat/438695-sr36...o-bmw-e36.html |
