11-19-2008, 08:36 PM | #34 |
hey TTrx7Pete do u have the wire colors for the s14 sr20det dash harness.... mine was messed with and so i cant do it like ur pinout diragram is... so i need to know all the colors for all the pin numbers... there is some missing so if u can help me out that will be really helpfull...thanks
11-19-2008, 10:11 PM | #35 |
We need the REP system back, because of folks like the OP....great writeup dude!!!
Juicy slayin aint easy, but dammit somebody has to do it!!! |
12-10-2008, 08:10 PM | #36 |
//quote// MAFs: Oval vs. Rectangular. You WILL need a retangular MAF if you have a RECTANGULAR plug on your WC harness. However, certain WC harnesses use an OVAL plug like the Kouki harness. Most people think that this means that the harness if from the Chuki series. This is true. However, there isn't a single difference between the OVAL MAF of the Kouki and the Chuki. Lesson: Make sure your MAF plugs are identical to each other and you will have no problems. \\quote\\
so it dosent matter which maf [69F00 or 69F01] as long as the plug on your harness matches the plug on the maf? please help been searcing for a while |
12-12-2008, 03:03 PM | #37 | |
1993 AW Mazda RX-7 1997 Nissan Silvia |
12-16-2008, 06:12 PM | #40 |
Someone did a write up on that... you should be able to search for an answer... I can't tell you off the top of my head.
03-02-2009, 12:33 PM | #41 |
alright, most of this info is great, but i have a small pinned L/R wire and a small pinned G/Y wire left, along with the two black wires that need to be grounded. do i not need these wires to be hooked up? also which plugs on the sr harness are not used,like the 17 pin white connector by the dash plug harness. pictures sure would be nice
03-02-2009, 03:42 PM | #42 | |
As for that little 17 pin white connector, I'm assuming that it is the one that comes up on the passenger side by the ecu you are talking about? If it is, it is not used.
01-29-2010, 08:55 AM | #44 |
Man w/ CTSV & a Car Seat
As with every fucking SR swap out there, yes you can. You just have to ghetto rig heater hose to match up the upper radiator next, which is on the left side, to the SR water neck, which is on the right side.
04-16-2010, 03:57 PM | #46 |
yeah that is pretty much like asking if you can use a D16z ecu for an H22.
always use the ecu that goes with that engine. awesome write up. going to need this soon for the monster sitting in my garage... pretty sure i have a greddy hot pipe with the nipple on it. and no MAF whatsoever. gotta love the power FC MAP conversion! has anyone ever used crimp on bullet connectors on the wires you cut from your KA harness on both ends so you could swap back to KA easier? for us CA folks who have to worry about the adventures of daily driving with johnny law... |
04-17-2010, 07:41 AM | #47 |
I would wire in the boost control solonoid. If you get a power fc with boost control kit it uses that wiring. Wire it just don't plug it in unless you want sucky 1st gear pulls. Also no need the extent the O2 plug. Putting rhd harness in a lhd chassis will leave excess harness . Fold it over tape it a little to stay folded and tuck it behind the head. Looks cleaner and less work. Also for waste gate pressure signal I usually just drill and tap the compressor outlet neck which unbolts so no metal in the turbo. Tap it 1/8 NPT and get a barb fitting from the hardware store. No welding needed .
07-10-2011, 06:22 PM | #48 |
I've been reading through the main article as well as the provided document for wiring.
I'd like to point out that, while the "wiring.pdf" document is accurate for 96+, it's completely off for the 1995 S14, as the wires don't match. I also found multiple pinout pages online for the M63 such as: http://www.vadriven.com/eng/M63.html This indicates the pinout for the 96+, but it is not applicable for the 95 on which wiring.pdf is based. I was wondering if anyone would have the 1995 M63 pinout available, which would save me a ton of time from searching in the FSM what is what for the M63. Thank you! Last edited by Ninja0n3; 07-11-2011 at 04:25 PM.. |
07-10-2011, 10:34 PM | #49 |
They contain a shielded wire which must be correctly reattached. Make sure you match up your wires correctly and make sure you reattach the shielded part of the wire to the SR's shield. This shield runs a ground which disrupts "noise" from the other wires, thus giving the ECU a clean MAF and O2 Signal. You can also reuse the heat wrap that goes around the O2 sensor's wiring since it will be along the back of the engine.
so what exactly happens if some of the shielded wire is missing in like a 5in strip does that matter. would it make the sr not run right?
RB POWA!!!!!!!! |
12-27-2011, 05:29 PM | #50 | |
Sorry to bring up an old thread just lost on a bit of wiring My s14 was an automatic and my new sr is a Manuel so what does that mean I'll have to do on the few lower harnesses |
01-08-2012, 03:29 AM | #52 |
There is no such thing as a 1994 Zenki S14, atleast not a 240sx...unless you have a real Silvia S14? If you have an actual Silvia, why the hell would you need to do any conversion wiring?!?!
01-08-2012, 04:48 AM | #53 | |
lolz sorry the date the car was sold was in 94.. lol but the title says 95 |
01-08-2012, 05:10 AM | #56 | |
ummm the m63 female plug is the same with the 240sx 95-98 some guy on here did a 98 ka24de engine to a 95 240sx chassis. he ran into plug issues in the engine bay and wiper plug. sideways blacks14 told me he didnt touch the wiring at all, so the m63 plug is the same 95-98 |
01-08-2012, 05:14 AM | #57 |
just means that you would have to wire the reverse lights and speed sensor in urself since its not there and connect the neutral posi switch to complete dat circuit. the KA lower harness is used on the SR so you dont need to modify anything.. thank goodness..
01-08-2012, 03:34 PM | #58 |
help me wire my sr??
well i tried seeing if the fuel pump would turn on and it doesnt.. just my luck... all i get is a click coming from the exhuast side?/ please help... and out of curiosity i tried turning the starter andi get another click coming from the exhaust side... please help....
01-08-2012, 03:58 PM | #59 |
right now would be a good time to have a extra 400 right now.... damn..... i thought it would be easy and i guess this is way over my head... could someone please help me and add there 2 cents...
01-08-2012, 05:17 PM | #60 |
this post is a bunch of BS. if wiring on your own just match up wires by following these wirings. the wiring.pdf file is bunk fuel pump ground signal is in the worng place for one. it actually goes where that special star thing is on this diagram. i learnd the hard way.. dont trust the internet. what a load of crap chuck.
info on the wires on the zenki s14 S14 SR20DET into DOHC 240sx S13 Swap info on the chassis plug 240/LS1 swap questions and wiring - LS1TECH |
