11-22-2014, 07:09 PM | #1 |
Blown head gasket?
So I just put in a thermostat, car didn't have one in before I bought it, ran fine before I replaced it oil looked fine, now the oil looks a little milky and there was white smoke/steam coming out of the exhaust, not sure which since it's 30 degrees out. Is this a blown head gasket?
11-22-2014, 07:18 PM | #3 |
Pictures of coolant?
11-22-2014, 07:23 PM | #6 |
It smells kinda sweet but I also run e85 so it always smells a little sweet, the oil just started getting milky after I put a thermostat in, could I have overfilled it and belw the HG?
11-22-2014, 11:59 PM | #9 | |
Like others have said, compression test motor or get a hydrocarbon tester, that'll tell you for sure.
11-23-2014, 03:24 PM | #12 |
You could check your coolant as well. If you take the radiator cap off is the coolant a milky color?
Should only be the color of the coolant mixture. Not milky looking. |
11-23-2014, 05:22 PM | #13 |
Compression test takes 10 minutes
11-23-2014, 09:22 PM | #15 |
you need to test compression when the engine is at operating temp. As well as making sure the throttle is open all the way.
Is it smoking non stop? Or on a cold start only? |
11-24-2014, 10:53 AM | #16 |
I haven't driving it, is it okay to drive if the head gasket is blow? Because I don't want to fill my oil with coolant while driving it to see, and yes throttle is wide open
11-25-2014, 06:49 AM | #18 |
http://www.autozone.com/loan-a-tools...er/391378_0_0/
Go to autozone and rent one of those, it tests for combustion gases in your coolant...(caused by a blown headgasket.) |
11-25-2014, 09:01 AM | #19 |
I am not saying you did the compression test wrong but I have a had a few sr's some built some stock and I haven't had one read over 165 across all four and usually they are 150 across...
11-25-2014, 10:14 AM | #20 | |
Just as I suggested and someone recently repeated, go buy a hydrocarbon test and test your coolant.
11-25-2014, 01:18 PM | #25 |
Then again, the fact it didn't have a thermostat in it is kind of suspicious. Ive heard of people removing the thermostat because they were too lazy to find out why their car was overheating.
Overheating can and will cause a failed head gasket |
11-25-2014, 01:39 PM | #26 |
The guy I got it from lived in Vegas and said he didn't need it because it was so warm down there, I wanted to put a metal head gasket in just wasn't planning on doing it this soon haha
11-25-2014, 01:57 PM | #27 |
do a compression test with the engine at operating temp.
I would think you'd for sure have low compression if the head gasket was done for Unless the gasket is just now starting to go..? Not sure if head gaskets can go slowly or if they just flat out fail when they do. You can also get a head gasket leak tester as stated from someone above. |
11-25-2014, 01:59 PM | #28 |
Sounds like another excuse to me. Every car needs a thermostat to run properly, except say a drag car. You don't efficiently cool the engine without one. The coolant needs time to stay in the radiator to dissipate heat. Not to mention engines and their Ecus are designed to run at a specific temperature. If it's constantly running outside designed parameters it uses more fuel and is in the end less efficient. Put a thermostat back in it.
11-25-2014, 04:58 PM | #30 |
So I did a block test and another compression test, I got about 118 psi for all cylinders, the block test didn't do anything, the solution stayed blue the whole time, depending on when I check the oil it looks like coffe with a bunch of cream in it and other times it looks alright, I did notice some steam coming off my radiator though, and the radiator fluid is the color of rust, I use green coolant to fill it.
