Old 01-20-2010, 12:17 PM   #361
coww-cho!!!!!
coww-cho!!!!!'s Avatar
coww-cho!!!!! is a jewel in the roughcoww-cho!!!!! is a jewel in the roughcoww-cho!!!!! is a jewel in the roughcoww-cho!!!!! is a jewel in the roughcoww-cho!!!!! is a jewel in the roughcoww-cho!!!!! is a jewel in the roughcoww-cho!!!!! is a jewel in the roughcoww-cho!!!!! is a jewel in the rough
Send a message via AIM to coww-cho!!!!!
Originally Posted by drftkng951 View Post
i would be down but, my only door key is breaking and i can't get my door to unlock.
i took out my climate control already is there anything i should look for? or do i have to pull the dash out
lol go to dealerships parts store approx $20 for original key just bring your cars registration and I.D.
well everything is behind the dash ducts and such which reminds me i have to remove mine to replace my heater core =( no heater for me as of now MAYBE SOMEONE CAN CHIME IN ON THIS TO HELP DIAGNOSE THIS!
heres a pic behind the dash as you can see the climate contril there connected you can see whats going wrong and the FSM might help heres the link to a diy dash removal
Technical Articles: s13 Dash Removal
**CoUpe LOve** #3
coww-cho!!!!! is offline   Reply With Quote
Old 01-20-2010, 01:15 PM   #362
jing
jing's Avatar
jing is an unknown quantity at this point
The alternator on my SR swap has a 4-rib pulley when it's supposed to be 5 so I'm guessing the previous owner used his old DOHC alternator and neglected to change the pulley? It works I guess but it squeals like a bitch all the time...
The belt looks like it's new still and the tension's set correctly. Could the fact that it's the wrong belt/pulley be the cause of the squealing?
Anyone know the part # for the SR alternator pulley?
jing is offline   Reply With Quote
Old 01-20-2010, 01:46 PM   #363
Iron_Zenki
Iron_Zenki's Avatar
Iron_Zenki is an unknown quantity at this point
I have a question alright I was wondering do any other 5 lug hubs from other cars like J30, 300zx ect fit into a s14 trying to save money
I know some frown being cheap but i cant help it lol
Originally Posted by handinpants View Post
anyways,watch out for stupid people driving hondas
Iron_Zenki is offline   Reply With Quote
Old 01-20-2010, 03:11 PM   #364
DFWZenki
DFWZenki's Avatar
DFWZenki is an unknown quantity at this point
I have two questions:
#1-Is an S14 ('95) already wired for fog lights even if your car doesnt have any?
#2-Is an S14 ('95) already wired for a power antenna evin if your car doesnt have one?
It looks like the plugs are already there for the fogs. You would just untape the plugs off the harness, plug your fogs in and replace the switch on the column with one with fog light controls on it.
Anyone?
The antenna thing im really unsure about. But i have a plug back there im unsure about. Was hopeing to run a power antenna on my car.
Thanks for any help!!
DFWZenki is offline   Reply With Quote
Old 01-20-2010, 03:21 PM   #365
japslapsilvia
japslapsilvia's Avatar
japslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the rough
yes, you can use REAR Z-32 N/A rear hubs for 5 lug. For the front u can just get s14 5 lug. Buy them new at the dealer...IIRC they arent that expensive.
Nothing is rare just expensive.
if you've ever been with multiple women, then even you can understand that not all girlfriends are created equal. some are capable of amazing oral talents, while others dont mind a lill back door action.
japslapsilvia is offline   Reply With Quote
Old 01-20-2010, 03:57 PM   #366
d0pe240
d0pe240 is a glorious beacon of lightd0pe240 is a glorious beacon of lightd0pe240 is a glorious beacon of lightd0pe240 is a glorious beacon of lightd0pe240 is a glorious beacon of lightd0pe240 is a glorious beacon of lightd0pe240 is a glorious beacon of lightd0pe240 is a glorious beacon of lightd0pe240 is a glorious beacon of lightd0pe240 is a glorious beacon of lightd0pe240 is a glorious beacon of light
anybody know the thread pitch for an s14 ka coolant temp sensor, just the single wire sensor. is it the same as an s13?
d0pe240 is offline   Reply With Quote
Old 01-20-2010, 06:48 PM   #367
Sileighty_85
Sileighty_85's Avatar
Anybody know if there is a US vehicle's Valve cover Rubber grommets (for the screws) i can use for the RB25 Valve cover?
I thought maybe the Z32 but theirs look alot thicker.
I know The Nismo Shop has them but im not paying 3.00 EACH for them when i need 20 of them
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 01-20-2010, 07:51 PM   #368
JAYTRON
JAYTRON's Avatar
JAYTRON is making a name for him/her selfJAYTRON is making a name for him/her self
Send a message via AIM to JAYTRON
For Auto to 5spd swap, how big a hole do I need dremel'd for the clutch pedal to the firewall?
JAYTRON is offline   Reply With Quote
Old 01-21-2010, 12:21 AM   #369
Slammed180
Slammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of light
maybe PM him?????
Blow me, bitches.
Slammed180 is offline   Reply With Quote
Old 01-21-2010, 12:55 AM   #370
coww-cho!!!!!
this may give you a rough idea and heres a direct quote with pic
[SIZE=2px][SIZE=2px]Nissan left a guide under the dash that tells you where to drill. Drill out the two bolt holes and the larger center whole with a circle cutter drill bit and touch it up with a dremel. Slide your clutch assembly up there and bolt it in, attach the clutch master cylinder on the other side and cotter pin them together.[/size][/size]
more info is at 240sxtech.com look for 5spd maual swap
if you're still unsure you can hopefully get one of the engineering tools from someone which i can't remember the name of but you can use it to check the dimensions (the one that looks like it has beaks) and just use a sharpee to pin point everything G.L.
**CoUpe LOve** #3
Old 01-21-2010, 02:30 AM   #371
widebodyseven
widebodyseven's Avatar
widebodyseven is an unknown quantity at this point
I rewired my zenki s14 for kouki headlights and now my headlights works fine but i don't know why but after that none of my other lights work(taillights, corners,etc).
I think its a fuse but haven't check bc the previous owner relocated the fuse box and haven't found it yet but anybody know why this happen?
widebodyseven is offline   Reply With Quote
Old 01-21-2010, 06:29 AM   #372
heavenboundkevin
heavenboundkevin's Avatar
heavenboundkevin is an unknown quantity at this point
IIRC im pretty sure a 1 3/4 inch hole saw will work out. you need a right angle drill, or a small size air drill cause the space you have to work is pretty tight.
Originally Posted by rat240 View Post
sick bro .... hella jdm foshow i love haters
heavenboundkevin is offline   Reply With Quote
Old 01-21-2010, 10:00 AM   #373
DFWZenki
DFWZenki's Avatar
Originally Posted by dfwzenki View Post
i have two questions:
#1-is an s14 ('95) already wired for fog lights even if your car doesnt have any?
#2-is an s14 ('95) already wired for a power antenna evin if your car doesnt have one?
Anyone?
Anybody?
Old 01-21-2010, 11:18 AM   #374
NeedCAforS13
NeedCAforS13's Avatar
NeedCAforS13 has a spectacular aura aboutNeedCAforS13 has a spectacular aura aboutNeedCAforS13 has a spectacular aura aboutNeedCAforS13 has a spectacular aura aboutNeedCAforS13 has a spectacular aura aboutNeedCAforS13 has a spectacular aura aboutNeedCAforS13 has a spectacular aura about
Send a message via AIM to NeedCAforS13
Don't know the actual pitch, but S13 and S14 are the same. When I put an S13 SR in my S14 I reused the S14 temp sensor. Screwed right in.
NeedCAforS13 is offline   Reply With Quote
Old 01-21-2010, 11:20 AM   #375
NeedCAforS13
I was able to do it on an S14 without any special drill. Just a hole saw. Took 2 minutes. I forget the size, you don't have to get it right on, you can make the hole slightly larger than the clutch master.
Old 01-21-2010, 11:34 AM   #376
stinky_180
stinky_180's Avatar
Trader Rating: (26)
Feedback Score: 26 reviews
what is the bolt size for the SOHC KA camshaft gear? also the crankshaft bolt?
WheelsDirty
Old 01-21-2010, 12:11 PM   #377
ZX88
ZX88's Avatar
where to get big boy spacers that fit 5 lug nissans.
in talking about 38mm all i can find are ones with 1.5 threaded studs.
Old 01-21-2010, 12:36 PM   #378
hOngsterr
Bandwagon.
hOngsterr's Avatar
Trader Rating: (73)
hOngsterr is an unknown quantity at this point
Feedback Score: 73 reviews
hit up parts by max
- Hong
OCD isn't so bad just means you'll spend more money then most people, but you'll have a quality car not a POS put together with POS parts.
Old 01-21-2010, 10:02 PM   #379
frsh4
frsh4's Avatar
frsh4 is an unknown quantity at this point
Whats the LED bulb size for key ring lights?
frsh4 is offline   Reply With Quote
Old 01-21-2010, 10:08 PM   #380
irritatedmax
irritatedmax's Avatar
irritatedmax will become famous soon enoughirritatedmax will become famous soon enoughirritatedmax will become famous soon enoughirritatedmax will become famous soon enough
ebaymotors used to have those things listed all the time.
i just searched and found nothing.
weird.
BRICKHOUSE PRODUCTS
IG @brickhouse_products
irritatedmax is offline   Reply With Quote
Old 01-21-2010, 10:26 PM   #381
DisFrikkenWill
DisFrikkenWill is a well-known jackass
QUICK!
$250 for used OEM S14 front and rear(with bearing) 5 Lug hubs a good deal?
DisFrikkenWill is offline   Reply With Quote
Old 01-21-2010, 11:24 PM   #382
hassanbakar123
hassanbakar123 is an unknown quantity at this point
on a s14 for 17x9.5 +15 (mb battles) will i need to pull the fender or just a roll
i want to run 235/40/r17
hassanbakar123 is offline   Reply With Quote
Old 01-21-2010, 11:27 PM   #383
P_856
P_856's Avatar
P_856 is just really niceP_856 is just really niceP_856 is just really niceP_856 is just really niceP_856 is just really niceP_856 is just really niceP_856 is just really niceP_856 is just really nice
i need to redrill my rotor to 4 lug the i should get a 1/2 in drill bit right?
P_856 is offline   Reply With Quote
Old 01-22-2010, 02:19 AM   #384
hOngsterr
Bandwagon.
hOngsterr's Avatar
Trader Rating: (73)
Originally Posted by DisFrikkenWill View Post
QUICK!
if your getting all four! yes!
the set is 400+
or if you can find it cheaper.
- Hong
Old 01-22-2010, 03:08 AM   #385
I LUV MY S13
I LUV MY S13's Avatar
$400? you sure?
-Jorge
I LUV MY S13 is offline   Reply With Quote
Old 01-22-2010, 05:11 AM   #386
tootall4la
tootall4la's Avatar
tootall4la is a name known to alltootall4la is a name known to alltootall4la is a name known to alltootall4la is a name known to alltootall4la is a name known to alltootall4la is a name known to alltootall4la is a name known to alltootall4la is a name known to alltootall4la is a name known to alltootall4la is a name known to alltootall4la is a name known to all
How do i fix my Cig Lighter on my S13?/
Fuse??
New Cig Lighter??
i need it to charge electronics
P.S. Pm me. If u can help me!!
tootall4la is offline   Reply With Quote
Old 01-22-2010, 07:26 AM   #387
Future240
Future Moderator
Future240's Avatar
Fuse??
New Cig Lighter??
I don't know if I can so so I will just put it here. It could be simple as a fuse, first thing to do is to check the fuses. If it is not popped, then check the wiring that leads to the cig lighter.
Originally Posted by ThatGuy
Old 01-22-2010, 11:14 AM   #388
tootall4la
tootall4la's Avatar
Which Fuse leads to the Cig??
i checked the fuses
Old 01-22-2010, 12:59 PM   #389
dopplganger1
dopplganger1 is an unknown quantity at this point
what is the size of the turbo coolant line for an s13 sr20det? also what size AN fitting would i need for the s14 water neck?
dopplganger1 is offline   Reply With Quote
Old 01-22-2010, 01:49 PM   #390
Future240
Future Moderator
Future240's Avatar
i checked the fuses
If there is no panel in the car telling you which fuses are what, then your next option is to consult the Factory Service Manual
