Old 11-14-2017, 12:42 PM   #1
412xx
412xx is an unknown quantity at this point
sr20 won't turn over after fixing ecu / fuel related?
EDITED: NEW ISSUES!
S13 SR would start after swap, ran extremely rich and would not go above 2500rpms.
Turns out the ECU chip was fried. Had the ECU fixed, rechipped and tuned.
Plugged it back in, will not start now.
The Coil Packs are only getting 6V and not the full 12V and I'm not sure why.
Here is what has been checked/done:
- Compression: 150-155 across all 4
- Fuel Pressure: 43-45
- Fuel Pump - Great
- FPR - stock, works for now will upgrade.
- Injectors: Great, 850cc
- Spark Plugs: Replaced w/ NGK and has spark
- Maf: s13 maf, no changes from when it was running before ECU fix
- Ignitor: tested, failed. Borrowed a friends from his car, still did not run.
- Coil Packs - getting 6V instead of 12v? This could be part of the issue
- Timing - have not checked timing, but it would still run before the ECU fix. Should I check the timing? I didn't think I would have to if I only rechipped my ECU and timing was set at 15*?
Any ideas?
412xx is offline   Reply With Quote
Old 11-21-2017, 08:00 AM   #2
412xx
bump for sad 240 not running
Old 12-29-2017, 06:20 PM   #3
sr vegas 240
sr vegas 240 is an unknown quantity at this point
im no expert but I would start with the basic since you are only getting 6v at the coils check the battery make sure you are getting 12.6v check your fuses, grounds especially. I know the coil pack harness has its own ground.
sr vegas 240 is offline   Reply With Quote
Old 12-31-2017, 10:34 AM   #4
Kingtal0n
Kingtal0n's Avatar
Wont turn over? Try manually applying 12v to the starter to make it spin.
Old 02-15-2018, 06:57 PM   #5
92SEric240sx
92SEric240sx's Avatar
Trader Rating: (32)
92SEric240sx is an unknown quantity at this point
Feedback Score: 32 reviews
Starter trigger attached to the starter? There is a plug that slides on the blade for the starter, if this is not on your car won’t turn over
RELAX BRO!!!!
92SEric240sx is offline   Reply With Quote
Old 02-25-2018, 06:56 PM   #6
mr.nismo.
mr.nismo.'s Avatar
Trader Rating: (31)
mr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond repute
Feedback Score: 31 reviews
6v at the coils? What about injectors? Start probing backward until you find the resistance issue
Sent from my SM-G955U using Tapatalk
mr.nismo. is offline   Reply With Quote
