06-26-2007, 02:36 PM | #1 |
Why wont my sr20det start after driving it 30min?
Cliffnotes at the bottom...i tried to search with no sucess.
OK. So i have a 95 240sx with s13 sr20det redtop. Its more a toy than anything so i only pull it out of the garage a few times a week and drive it around for 5-10 min then park it back. Under these circumstances it cranks right up and runs great. Well i decided to venture out for a 30 min drive to the mall and shut the car off. Low and behold it wouldnt start. The water temp was fine. The car would crank so im pretty sure its not the security system because usually that wont allow the car to even crank. I can hear the fuel pump comming on...its almost as if it wasnt getting spark. BTW i have 4 brand new coilpacks. I try to let it cool down for 30 min but still it wouldnt fire up. It was getting late so i spent $95 getting it towed back home A few hours later i walk back outside and it fires right up like nothing ever happened....arggggg. Advice? To my best guess something is shorting out when it gets hot from the long drive. I thought maybe it was a faulty ignitor chip but if that were the case the car wouldnt even run...right? Cliffnotes: car will not start when it has been driven for longer than 20-30min even though it seems to be getting fuel and the starter is cranking. |
06-26-2007, 02:41 PM | #2 |
because it hates you
serious... nvr mind it cranks right?
Like Me on FaceBook ! |
06-26-2007, 02:43 PM | #3 | |
06-26-2007, 02:50 PM | #4 |
i had the same problems with my Skyline.. the problem? the damn battery terminals were weak and corroded.. i would suggest getting a new battery and possible some new terminals.. that worked out for me!..
PS... please check ur PM Shelton.. thanks. |
06-26-2007, 03:02 PM | #5 |
Trader Rating: (81)
Feedback Score: 81 reviews
Instead of replacing the battery or getting new terminals, just clean them with a wire brush and make sure they are tight. Any loose terminals will cause the car not to start.
06-26-2007, 03:25 PM | #6 |
what do you spark plugs look like?
Replace them then come back and let us know.
06-26-2007, 04:41 PM | #8 |
06-26-2007, 07:57 PM | #9 |
Check the ECU for codes yet?? Wierd problem.. Clean as many electrical connections as you can. Maybe your fuel pressure is off for some reason? Is the car even getting fuel after this no-start shit happens???
-Bart |
06-26-2007, 08:15 PM | #10 |
car starts when its cold? yes?
car runs fine (all warm-up) until you shut it off and then you cannot start again? yes? wait till car cools down and you can start the car agagin? yes? check your coolant sensor that goes to the ecu hope that helps..enjoy |
06-26-2007, 10:35 PM | #11 |
I have the same problem... my thoughts so far
From What I have found out there are three main areas to look at.
Fuel... (probably not) maybe a bad pump or fpr, but i doubt it. On mine these are both new so I know it is not that Clutch relay (probably not) If your car was manual before the swap, you have one of these...they go bad. Check if you hear a "click" from the relaybeside the intake side fuse box. If you get this, then it is ok. If you had an auto before, you don't have one of these unless you deliberately put it in. Bad grounds. (possibility) the Starter grounds through its body to the engine block... maybe when it gets hot, the ground contact is not being made. May have to make a dedicated ground wire for the starter. Bad starter.(very possible) When hot, hit the starter with a hammer while key in start location. If it works, then you have a bad starter. You can swap the internals from a sohc starter to repair or replace with a brand new one. Hope this helps you. I will found out over the 4th weekend.
Above!!! |
06-27-2007, 12:09 AM | #13 |
got my money on a cam angle sensor or ignitor, don't guess it's not getting spark, test and see if it's not getting spark. after verifying no spark, borrow a friend's ignitor , two plugs BAM, if still no spark, make sure the ecu's getting power, should have a red led that lights up with the key in ON position. if ecu lights up, try a known good cam angle sensor. test until you find the problem, don't guess. good luck
Dave
RB25 280z GT30/76R 441hp/381tq 11.9@125 |
06-27-2007, 12:34 AM | #14 |
i had the same problem. on a cold crank, it starts fine, but when the engine is warm, it won't start up. once i let it cool down for like an hour or so, it starts up fine. i was told that it is the coolant temperature sensor, so i bought a new one, and it seemed to work fine for me.
06-27-2007, 01:01 AM | #15 |
i've been having the same problems as well. had the alterntor changed since the battery wasn't charging... then something was draining the battery so i checked grounds and replaced my battery terminals. i also had the starter checked too... so far it's okay.
06-27-2007, 01:41 PM | #16 |
Banned from the Marketplace
it could be the main rely. because sometime u drive for a while, the main rely getting hot. once u park and turn off the car, it won't start up. I know for sure it will crank. after a certain time later it will start like nothing happen.
07-16-2007, 09:25 PM | #17 |
ok guys i know for sure its not the starter, battery, battery terminals, or ignitor chip.
where is the main relay located? and does anyone have a stock FPR they can sell me for cheap just so i can elimnate that possibility? |
07-18-2007, 12:25 PM | #18 |
i just swapped my buddies relays into my car. i swapped the underhood and underdash relays. it didnt make any difference. the car still wont start once its been driven a while.
can anyone tell me where the coolant temp switch is located? |
10-15-2007, 08:19 PM | #20 |
Its could be the coolant temp sensor. I had a problem with cold starts and the only way to get her going was to step on the gas like a carb'd motor!
http://allies-drift.blogspot.com/ |
10-16-2007, 03:22 PM | #21 | |
your car cranks over, so you dont have a starter issue/Neutral Safety Switch (clutch start sensor) It sounds like it is temperature related from what you described. Check for spark. *edit** Both the coolant temp sending unit and switch are located on the intake manifold under the T-Body.
This is my clever and witty signature. |
07-22-2014, 06:16 PM | #22 |
@ 240m3srt, so did you ever find out what the issue was with your car? I'm having the same issue with mine, if i drive it for 10+ minutes or anytime for that matter and attempt to start it again within 2 hours it won't start. just cranks and cranks and cranks but nothing. sorry for reviving this mega ancient thread, but in zilvia tradition i used the search button and something came up!!!
07-25-2014, 08:58 AM | #24 | |
There are a few things to try that are posted in this thread, I would start with pulling codes, and change the ecu coolant temp sensor, even if you don't have any codes. Sent from my Highly Tuned Galaxy S3.4!!!
07-25-2014, 04:41 PM | #25 | |
07-25-2014, 05:01 PM | #26 |
When I mention ecu coolant temp sensor, I mean the 2 wire sensor and if it's not hooked up? That's part of you issue right there.
