06-24-2017, 12:51 PM | #1 |
Trader Rating: (24)
Feedback Score: 24 reviews
Sr20 no start, possibly bad gas?
Sr20 s13 with t28, 550 sti injectors and z32 MAF with rs enthalpy ecu tuned for the setup. Has spark, has fuel, good battery, turns over great but acts like it's not even trying to fire. Have checked over everything I can think of and the only thing that comes to mind is the gas has gone bad from sitting (5-6months) but even if that was the case I'd think it would still try to start and just run poorly
Other than that I'm out of ideas, any other things it could be? Very busy these days and have limited time to mess with the car so trying to get a list of everything I can check before I go mess with it again. Gonna try to start it on starting fluid and drain the tank and fill with fresh 93 on Monday but won't have time to until then
IG: @Haley72692 |
06-25-2017, 12:34 PM | #3 |
gas gone bad after 6 months
I just started a car last week that had been sitting for 3-4 years, ran fine. Did it run before it sat? if not you might want to check timing and or compression |
06-25-2017, 12:39 PM | #4 | |
Trader Rating: (24)
Daily drove it until last December when I parked it because of winter, planned to big turbo It and didn't so only things that have changed is that I took the injectors/computer out and then put it back together Timing has never been messed with and compression is 140-145 cold
IG: @Haley72692 |
06-25-2017, 04:49 PM | #5 |
maybe try unplugging the maf or coolant temp sensor. My only guess is either the mixture is way to far off or the spark is too weak
06-26-2017, 05:24 PM | #7 |
Trader Rating: (24)
Have tried both, it's acting like it's not sparking at all but if I pull a plug out and put it in a coil I can watch it spark
IG: @Haley72692 |
06-26-2017, 08:56 PM | #9 |
are the cylinders flooded with fuel?
06-27-2017, 05:49 PM | #10 |
Trader Rating: (24)
Nope, the plugs will get wet and if I pull plugs and Crank it I can see fuel come out of the cylinder but it doesn't build up to the point where it fills the cylinder any
IG: @Haley72692 |
07-03-2017, 02:36 PM | #13 |
Trader Rating: (24)
Still not starting, have restabbed cas as per frsport writeup and have gone over every wire and connection and everything seems fine and still nothing, has to be the computer, sending it to Martin on Friday
IG: @Haley72692 |
07-06-2017, 09:32 AM | #14 |
ive had this issue with my RB same symptoms ended up being a mix between a bad MAF and a dying Fuel pump!!
