Old 11-27-2014, 10:50 PM   #1
dorkidori_s13
ITS LISA'S FAULT!!!
dorkidori_s13's Avatar
Trader Rating: (41)
Feedback Score: 41 reviews
Clutch issue...
So almost 4 years ago I bought a brand new ACT 6 puck sprung clutch disc, ACT Heavy Duty Pressure Plate and ACT Tracklight flywheel (SR20det Blacktop Early Gen, NOT S14/S15 NOTCHTOP). Well, about 6 months after having the clutch setup in the car, the clutch disc started slipping and wouldnt fully disengage with the pedal depressed when coming to a stop. We pulled the transmission off and found an imperfection in the flywheel that carved a groove into all of the pads. We sanded down the imperfection and I stuck an AutoZone Maxima disc in the tranny, it worked fine for the last 3 1/2 years (though it would start slipping after 2-3 pulls down the drag strip until it cooled off, pad life was decent on the disc after pulling it out). Sent the ACT 6 puck and throw out bearing back to ACT. They rebuilt and repadded the disc and sent me a new throw out bearing. both of which sat in my closet for 3 1/2 years.
Fast forward to Tuesday. Took the car to my friends shop (same person I installed the clutch with originally) with rebuilt ACT disc and new throw out bearing in hand. Pulled the tranny off, got the flywheel resurfaced at the neighboring machine shop, put everything back together, re-lubricated the throw out bearing shaft, installed brand new slave cylinder (correct NABCO slave for SR20det/KA24de) and an auto to manual conversion line to eliminate the stupid 2 piece hardline and braided line setup. Bled the setup and left the clutch pedal alone (it was adjusted to FSM spec)
Well, after driving around a bit, Im getting a lot of tranny drone now, I can feel vibration in my clutch pedal and the goddamn problem of the clutch disc not completely disengaging when depressed coming to a stop is back! Ive played with various clutch pedal positions (full engagement near firewall, OEM engagement range and currently super high engagement where the master cylinder pin end is flush with the clutch pedal bolt, like I have maybe 3-4 turns before it falls out). Im really lost on what is going on! Its basically a brand fucking new clutch setup and it SHOULD NOT be pulling this crap.
I owned the exact clutch setup on my last S13 and had ZERO issues with it. Car made over 300whp, my current 240 probably makes around 215-220 to the wheels (OEM injectors are maxed out at 100% duty cycle around 6000rpms per NISTune data logger at like 12psi on an S15 SpecR turbo). Some Im guessing MAYBE 250-260 at the crank. Stock MAF and injectors crap out around 240-250 crank horsepower, so thats what Im gauging my power output at given what Ive seen from the NISTune data logger.
Any input would be appreciated! Im gonna call ACT tomorrow and see what info they can give me as well.
Old 11-27-2014, 11:47 PM   #2
FaLKoN240
Super Moderator
FaLKoN240's Avatar
Trader Rating: (73)
Feedback Score: 73 reviews
Do you still have a clutch dampener?
Old 11-27-2014, 11:54 PM   #3
dorkidori_s13
ITS LISA'S FAULT!!!
Trader Rating: (41)
nope, was removed before i bought the car.
Old 11-28-2014, 10:28 AM   #4
Scott@FontanaNissan
Scott@FontanaNissan's Avatar
Scott@FontanaNissan is an unknown quantity at this point
Send a message via AIM to Scott@FontanaNissan
from the sounds of it looks like you have a bad transmission, i had a customer who had the same issue, he replaced his clutch with about 3 different brands (ACT, Centerforce, Excedy) then shortly after he got his car tuned the transmission Blew up, he now has a Z33 Six Speed in his car and hasn't had issues since. he had the same exact symptoms you have.
-Juan
Juan Vargas - Motorsports Specialist Fontana Nissan/Nissanraceshop.com
email: [email protected]
Scott's Personal Website/Blog: http://www.scottandkerryann.com
Scott@FontanaNissan is offline   Reply With Quote
Old 11-28-2014, 03:12 PM   #5
dorkidori_s13
ITS LISA'S FAULT!!!
Trader Rating: (41)
-Juan
ive had zero issues with the tranny over the past 4 1/2 years of owning the car. no grinds, no strange noises, nothin... the car came with an exedy stage 2 clutch setup that i pulled and replaced with the ACT setup. the exedy clutch didnt really have any issues outside of a bad pilot bearing which has since been replaced. i just wasnt a fan of the exedy clutch, though keep in mind it didnt present any issues im having with the ACT setup. i may just wind up ordering an ACT street disc, but im gonna talk to ACT first before doing anything else.
also, keep in mind that my car is a daily driver, not a track/drift car. i rarely take it out drag racing at the track (ive gone once in the 4 1/2 years ive owned it) and it has never seen any road racing/drifting abuse.
Old 11-28-2014, 03:22 PM   #6
s13mikesr20
s13mikesr20 is an unknown quantity at this point
Bring it to my house and I garentee a answer of what the hell is going on
s13mikesr20 is offline   Reply With Quote
Old 11-28-2014, 06:10 PM   #7
jr_ss
Have you inspected any of the hardware on/in the bellhousing? How's the pivot? Does your TOB sleeve look worn? Is it the correct length recommended for that clutch? I know Exedy specifies a particular TOB sleeve for their clutches, specifically the multiplate ones. I'm just spit balling here, but they could be options/fixes. Perhaps your PP has a bad finger/s and isn't disengaging the disk completely.
A clutch not fully disengaging is more a symptom of the pressure plate/hydraulics, than it is of the disk itself. Has your MC been changed? What color is your clutch fluid? It should be clear. If it's dirty/black/brown/any color other than previously mentioned, I suggest getting a new OEM MC.
Old 11-29-2014, 01:25 AM   #8
dorkidori_s13
ITS LISA'S FAULT!!!
Trader Rating: (41)
I think im gonna try a new master cylinder. Fluid is dark grey and milky/metallic like crazy. I have no idea when the MC was changed and it looks like an el cheapy autozone deal.
Old 11-29-2014, 08:16 AM   #9
jr_ss
Originally Posted by dorkidori_s13 View Post
I think im gonna try a new master cylinder. Fluid is dark grey and metallic like whoa. I have no idea when the Mc was changed and it looks like an el cheapy autozone deal.
Yep, 9 out of 10 times the cheap aftermarket master cylinders just don't work well on our cars. If you get it to work, they fail within a very short time compared to what the OEMs life spans are. Update when that's been swapped. Don't forget to bench bleed it before installing it, otherwise it takes s long time to purge all the air out.
Old 11-29-2014, 12:37 PM   #10
silverarrow27
silverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud of
^^^3 out of 3 clutch master cylinders I've bought from Autozone works just fine for me. It sounds more like luck of the draw or user error.
1989 240sx XE|2002 Frontier SC CC LB 4wd|2011 Pathfinder LE V8 4wd
silverarrow27 is offline   Reply With Quote
Old 11-29-2014, 06:11 PM   #11
jr_ss
So those "3" MC's from autozone were for 3 seperate cars then? Because if it's been for the same car, you just proved my point...
Regardless, most of the aftermarket MC's just plain ole suck for the s-chassis. I buy OEM parts the majority of the time because of past experiences with crap reman'd stuff.
Dorki- here is a new Nabco unit for cheap. http://zilvia.net/f/showthread.php?t=585006
Old 11-29-2014, 10:35 PM   #12
silverarrow27
No, 3 different cars in a period of over 10 yrs. Never had any remanufactured part fail on me so I'll keep buying them for 1/4 cost of an OEM unit if available.
Another experience, current Autozone brake booster in my s13 now has been in there since 2004.
To the OP though, just stick with a remanufactured unit from any of your local parts store and call it a day.
Old 11-30-2014, 03:09 AM   #13
dorkidori_s13
ITS LISA'S FAULT!!!
Trader Rating: (41)
id actually be a lot happier hunting down either an Exedy or Nabco unit. ill be ordering a brand new MC from FRSport on Monday.
Old 12-01-2014, 10:09 AM   #14
Scott@FontanaNissan
Give me a call whenever you need OE parts, I'll smash anyone's pricing on oem/jdm parts any day of the week
-Juan
Old 12-02-2014, 02:05 PM   #15
godsmack
godsmack's Avatar
godsmack is an unknown quantity at this point
Before going through the troubles of mc make sure there's no air in the system. Some times these systems can be a real b**** to bleed properly, and if not bled properly will have exact symptoms that you have.
godsmack is offline   Reply With Quote
Old 12-02-2014, 03:26 PM   #16
dorkidori_s13
ITS LISA'S FAULT!!!
Trader Rating: (41)
i already stated that 1) the clutch was bled properly as Im not a n00b, have done it dozens of times 2) the brake fluid is dark grey/milky and 3) i dont have a clutch damper
my brand new NABCO master cylinder will be here tomorrow. clutch cylinders are easy to change, not sure why you worded it "going thru the trouble of replacing the master cynlinder"...
and not being bitchy, but PLEASE PLEASE PLEASE make sure you read the entire thread before responding. i appreciate the input in here, but some of the responses were evidence of simply not reading everything thoroughly.
Old 12-06-2014, 05:53 PM   #17
dorkidori_s13
ITS LISA'S FAULT!!!
Trader Rating: (41)
Installed a brand new OEM nabco unit tonight i got from Fontana Nissan and everything works like a champ again! Clutch actually feels like i remember, damn near stock with very marginal chatter and awesome engagement! Tranny shifts like normal again and all of the annoying transmission drone is completely gone.
Thanks to jr_ss for pointing out the brake fluid color and to Juan at Fontana nissan for the OEM master cylinder!!! Ill report back in a few days with any updates as it should take about 48-72 hours for any problems to rear their heads
Old 12-06-2014, 06:38 PM   #18
jr_ss
Good stuff! Glad to hear it's back like it should be. Let's hope it fixes your issues for a long time.
Old 12-07-2014, 02:00 PM   #19
dorkidori_s13
ITS LISA'S FAULT!!!
Trader Rating: (41)
sooooooooo the disengagement issue is still happening! car drives much better, no more tranny drone and it shifts about 100x times better now. ive spent about 20-30 minutes via google looking up 240sx disengagement issues with clutches (most results were from Zilvia) and about the only thing i can really come up with is that its an issue with my pressure plate...
• brand new OEM NABCO master cylinder
• brand new OEM NABCO slave cylinder
• brand new auto to manual conversion braided line
• brand new ACT throw out bearing properly lubed and installed
• resurfaced fly wheel via my friends machine shop
• completely rebuilt ACT 6 puck SR spring clutch
• everything torqued down properly with torque wrench when reassembling
• have tried multiple positions with clutch pedal
• clutch has been bled correct
• NABCO clutch master cylinder was bench bled properly before install
• DOT3 brake fluid is staying nice and clean after a good nights worth of driving
• Pilot bearing was inspected, looked normal (as in no excess wearing or scoring)
the only thing that hasnt been replaced is the ACT pressure plate. didnt really see anything wrong with it when reinstalling. it was cleaned out completely with B12 carb cleaner and an air nozzle to ensure there were no bits or dust in it. didnt notice any scoring on the brake plate for the clutch disc, was also wiped down with a clean and soft rag soaked in B12 carb cleaner to ensure no oils were let on brake plate to cause heat spots.
so now i will be phoning ACT monday and asking WTF!!!
EDIT: and now im really curious about the TOB carrier... ran across this thread http://zilvia.net/f/showthread.php?t=290132&page=2 with some very interesting points being made on the 2nd page.
Old 12-07-2014, 02:19 PM   #20
jr_ss
That's unfortunate, however atleast it is narrowed down. Hopefully they'll replace it via a prorated system so you aren't out all previously spent funds. Keep this updated so if/when the PP is swapped out we know it was the issue.
Old 12-07-2014, 02:24 PM   #21
dorkidori_s13
ITS LISA'S FAULT!!!
Trader Rating: (41)
after reading thru that thread i just posted a link to, im now very curious if its a pressure plate issue or if its the throw out bearing + carrier. unfortunately BOTH questions point to taking the tranny off the car (which i HATE doing), but at least its narrowed down now... lol
Old 12-07-2014, 02:31 PM   #22
jr_ss
Well when you call them ask them if they specify a specific TOB sleeve.
Rhd-Japan sells the sleeves if you need a specific length. I had to buy a specific one for my twin disk Exedy.
Old 12-07-2014, 02:44 PM   #23
dorkidori_s13
ITS LISA'S FAULT!!!
Trader Rating: (41)
FRSport has OEM sleeves as well, im really starting to lean toward the TOB being the cause of the problems. i remember both TOBs sitting on the table when we were swapping them out on the carrier and the OEM unit looked like a monster compared to ACT part. my first ACT TOB started to go bad when i first had the clutch setup in the car back in 2010/11 (started making an audible whirring and whining noise, like when any TOB goes bad).
Old 12-08-2014, 11:37 AM   #24
Scott@FontanaNissan
Let me help you out here, clutch release bearing sleeve part numbers are as follows. (for USDM KA24)
07/88-07/90 30501-K0401
07/90-04/92 30501-60461
04/92-01/94 30501-k0401
all three different parts superseded to 30501-0H600
now for the clutch release bearing, from 07/88-12/94 they all used 30502-21000
as for the pressure plates
07/88-07/90 nissan used 30210-Y0600 --> 30210-Y0605
07/90-01/94 nissan used 30210-51F00 --> 30210-51F01
now for S14
this is the variations of release bearings
02/94-03/96 30502-21000
03/96-12/98 30502-45P00
and the clutch release bearing sleeve only one
02/94-12/98 30501-0H600 alternatively you can use 30501-K0404
as for the pressure plate nissan used only one part number on the S14
-30210-70F00 that superseded to C0210-70F00
being that the last year production KA used the same TOB as a Z32 makes me think that that is the TOB you'd wanna run on your ACT setup as they are probably using the most current pressure plate style for the KA24.
I would imagine ACT is probably going to ask you to run
30501-0H600 sleeve with the 30502-45P00 bearing
now getting off topic here: to clear up some confusion on the SR20 and CA18 Compability
All S13 SR20DE & DET used clutch release bearing sleeve 30501-0H600
All S13 CA18DE & DET used clutch release bearing sleeve 30501-S0106
All S13 SR20DE & DET used clutch release bearing 30502-21000 (Z31/D21)
all S13 CA18DE & DET used clutch release bearing 30502-W1700 which superseded to 30502-W1701 (same bearing just different manufacture)
now for S14 things got a bit more complex;
Clutch release bearing sleeve was as follows
10/93-02/96 30501-0H600
03/95 and up used 30501-0H600 and superseded to 30501-K0404
for the clutch release bearing itself this was the breakdown
10/93-03/95 30502-21000 (D21/Z31)
03/95-04/98 30502-45P00 (Z32)
04/98 and up used 30502-69F00 which superseded to 30502-69F10 (Z33)
S15 SR20DET
All 6 Speed S15's used
Clutch Release bearing Sleeve 30501-0H600 (can also use 30501-K0404)
Clutch release bearing 30502-69F10 (used on the Z33 in japan from 07/02 to 01/07)
the NA 5 Speed S15's
Clutch release bearing sleeve 30501-N1600 (can also use 30501-1C104)
Clutch release bearing was the same as the DET 30502-69F10
When Running after market SR20 clutch kits they mostly use the newest SR20 pressure plate so I would imagine they'll want you to use
Clutch release bearing Sleeve 30501-0H600 and clutch release bearing 30502-69F10 (both USDM part numbers)
-Juan
P.S. you can get all of these parts from us at www.nissanraceshop.com
Old 12-08-2014, 05:34 PM   #25
dorkidori_s13
ITS LISA'S FAULT!!!
Trader Rating: (41)
Im currently using their SR20det/300zx TT throw out bearing (Part number RB810). I spoke to ACT directly this morning.
Old 12-08-2014, 05:54 PM   #26
Scott@FontanaNissan
so if you're using that TOB the sleeve to use would be 30501-0H600 or 30501-K0404
if you'd like to measure the one you have here is a picture of it for reference
Old 12-08-2014, 05:59 PM   #27
jr_ss
What was their response?
Old 12-12-2014, 12:34 AM   #28
dorkidori_s13
ITS LISA'S FAULT!!!
Trader Rating: (41)
@jr_ss - response was they cant figure it out unless i sent them the entire clutch setup back (in a nut shell)
@juan - ok, so your listings caught my attention. when i sent back the ACT disc and throw out bearing back in '11, i had to change out the TOB with an OEM unit i purchased directly from my local Nissan dealership for around $85 (if i remember correctly on price). the link below is the exact unit i got from Nissan that i used in my tranny for 3 1/2 years (with the AutoZone Maxima Disc) and is the part # you list above for the SR20de/SR20det (30502-21000)...
http://www.frsport.com/Nissan-30502-...A_p_60126.html
the throw out bearing that ACT sent me originally, and then again a 2nd time looks EXACTLY like the below link...
http://www.thenismoshop.com/Nissan-F...ZX_p_1707.html
ACT said themselves that their TOB listing for the SR is the same as the Z32 TOB (2nd link). something tells me that the throw out bearing MAY be incorrect! the TOBs side by side are distinctly different (the OEM Nissan solid one was a monster compared to the hollowed out ACT unit in the 2nd link)
Unfortunately, my OEM TOB was thrown away so I cant grab the stupid thing from the shop where I swapped my clutch setup out at. But yeah, Im starting to get the feeling that the TOB ACT sent out and recommends may be the wrong TOB for my particular setup.
Old 12-12-2014, 07:32 AM   #29
S14DB
AFC #1
S14DB's Avatar
How much material was removed from the flywheel when it was resurfaced? Was it stepped or surfaced flat?
I always toss the TOB that comes in clutch kits and use OEM.
Old 12-12-2014, 07:39 AM   #30
hobbs
Trader Rating: (43)
hobbs is a jewel in the roughhobbs is a jewel in the roughhobbs is a jewel in the roughhobbs is a jewel in the roughhobbs is a jewel in the roughhobbs is a jewel in the roughhobbs is a jewel in the rough
Feedback Score: 43 reviews
Sounds like you need that extra 3mm
All jokes aside, I ran into a similar issue when a shop fucked up the flywheel stepping on my FWD flywheel and made it to large by 2mm and caused all sorts of disengagement issues. ACT throw out bearings tend to be junk, always replaced the ones in ACT kits with OEM bearings. After high RPM lockout on my P11 and evo I'm done with ACT clutches.
hobbs is offline   Reply With Quote
