Old 02-05-2018, 07:31 PM   #1
Salivabuildnz
Salivabuildnz is an unknown quantity at this point
S14 prefacelift sr20de plus t project
Hi guys, I’m a noob to the site and also to silvia’s. I’ve taken on an s14 project and recently started piecing it back together. So far I’m stuck on wiring issues as it had the main loom and motor loom in a box along with other bits and bobs.
I’ve managed to roughly plug it all back into place however I have run into 2 issues.
Firstly the wires for the ignition are cut and I cannot seem to find a diagram on how to re wire it to the barrel.
And second I don’t have power to the under dash fuse box, what powers this up?
Any help would be much appreciated cheers
Salivabuildnz is offline   Reply With Quote
Old 02-23-2018, 10:28 PM   #2
Salivabuildnz
Ok so I found out today that if you unbolt the under dash fuse box you will see four plugs, two of which supply the fuse box with mains power and I assume the others connect up the rest of the loom. So I now have power and the car fired up ���� However I really am not sure what way the ignition barrel should be wired up(works however not sure if it’s right) anyone have a diagram for it cheers
