Old 01-31-2012, 10:29 PM   #1
Balto4
Balto4's Avatar
Balto4 is an unknown quantity at this point
s13 Windshield Wipers Going Berzerk!
The other day, I get in my car to head to work.
I notice that my wipers gave a little, then went off just once.
I reverse out of my driveway and it does it again.
It's been doing it for the past couple of days
I recently noticed that it does it mostly when I apply the brakes.
It will usually stop when I'm constantly moving, but it gets annoying
throughout the day, as I drive quite a bit.
I'm new to the mechanics world, and I am definitely no electrical
wizz... got any ideas???
Balto4 is offline   Reply With Quote
Old 01-31-2012, 11:36 PM   #2
starplatnumm
starplatnumm is an unknown quantity at this point
going through this as well. lol weird part is that my rear defrost button lights up when applying the brakes. a day later while heading home from work someone gave me the heads up that my brake lights aren't lighting. it was raining. i checked the fuse which i did go out. bought a fuse kit 20 of 15a fusses. results have failed. i was going through my FSM and had a thought for the Fuse block or fuse holder. check the fuse block and found some melted fuse where the brake lamps fuse sits at. but the first step people do is check for fuse- but having to repeatedly replace fuse mean there something wrong with the wiring. in this case I'm having. inside the contacts are burned out.
starplatnumm is offline   Reply With Quote
Old 01-31-2012, 11:48 PM   #3
Matej
Trader Rating: (39)
Feedback Score: 39 reviews
You have most likely rubbed through your wheel well wiring.
Old 01-31-2012, 11:56 PM   #4
karl wasabi
karl wasabi's Avatar
Trader Rating: (41)
Feedback Score: 41 reviews
^^^ That's what I'm thinking. ^^^
Check the left side fender harness. Your tires most likely rubbed though. The wipers are usually the first thing to go wrong when that happens.
karl wasabi is offline   Reply With Quote
Old 02-01-2012, 12:10 AM   #5
EvoVIII808
EvoVIII808 is an unknown quantity at this point
Send a message via AIM to EvoVIII808 Send a message via Yahoo to EvoVIII808
+1 on harness
If thats not it, then that green box on the driver side by the master cyl is going bad.
Check Out My S13 Build
EvoVIII808 is offline   Reply With Quote
Old 02-01-2012, 12:22 AM   #6
jdm213
jdm213's Avatar
jdm213 is an unknown quantity at this point
check the 30 amp alt fuse this happened to me
jdm213 is offline   Reply With Quote
Old 02-01-2012, 03:56 AM   #7
angelz365
angelz365's Avatar
angelz365 is an unknown quantity at this point
had the same problem, if its not the wheel well wiring then open ur hatch and check the top right for that harness the wires usually corrode and tear from closing and opening the hatch.
angelz365 is offline   Reply With Quote
Old 02-15-2012, 11:06 PM   #8
Balto4
Balto4's Avatar
s13
update: took the fuse out for the wipers because I got annoyed. Not too long after, my turn signal bulb blew out. Forgot to mention that earlier in the week, my turn signal blew out and thats how the whole thing started. Changed the bulb and changed the fuse for the turn signals and put back the wiper fuse. things seem ok for the moment. Also, checked the well because I took off the cover and thought that might be it, but the harness is untouched and in good condish. I'll post another update in a few days and see if it was just the fuses.
Old 02-16-2012, 02:50 PM   #9
amarx2002
amarx2002's Avatar
amarx2002 is an unknown quantity at this point
Not sure if my problem is the well harness rubbing but my wipers work with key on and no engine . Don't work when engine is running
amarx2002 is offline   Reply With Quote
electrical, s13, windshield wipers
