03-01-2017, 03:41 PM | #1 |
Rb25 new setup issues
Just finished installing hx35 on my rb25 mods list:
Stock s1 rb25 Freddy IM Ls coilpacks Tial 44mm wg 3"exhaust all the way back Z32 maf Enthalpy tuned ecu 750cc injectors So my issue is the car idles at 10.1-10.5 afrs. I checked the tps and im getting .46v closed throttle 4.16v wot, I cant find any vac leaks and dont really know where to go from here, also feels sluggisg getting into boost. |
03-01-2017, 07:30 PM | #7 |
Check injector o rings as well. Common issue
MRP Manufacturing |
03-02-2017, 09:21 AM | #12 |
Found out one of my plugs in my knock sensor subharness doesnt lock into the the knock sensor, getting another knock sensor subharness. Hopefully it is just a connection that was coming loose causing my car to run rich at idle and causing me to get code 34 as well. Btw i have ls coilpacks and gonna go back to the stock coilpacks to see if this helps.
03-02-2017, 01:23 PM | #14 |
failure in the harness, i would say check MAF and make sure your cas is set properly.
03-02-2017, 09:49 PM | #19 |
You check fuel pressure,
pressurize the plumbing for leaks to 15psi~ check you are using the correct maf, make sure you have the right tune in the chip, fueling is basically maf -> ecu -> Injector so this is the entire chain of command I have suggested above. If it still runs rich at idle, dial it down using a SAFC type device, OR get somebody to re-tune the chip. Not all 700~CC injectors are identical, so a tiny change in the fuel map, engine idle vacuum, idle conditions, pulse dead-zone (delay) as voltage at the injector adjusts the delay and so forth, it is too many variables for a "canned tune" as you move up in injector size. In other words, the larger the injector, the more unknown the injector, the less likely you will be "in the correct region" at low injector pulse widths such as around idle. |
03-02-2017, 10:05 PM | #20 |
Fuel pressure is at 38 psi at idle, using n62 maf. I checked with my tuner about my setup and he said he tuned for the same setup. My problem only occurs on idle the closer the car comes to warming up the richer it gets until it reaches in the low 10afr range and it bounces between 10.9 and 10.3afr. Checked my tps and I am getting .46v closed throttle 4.16v wot maf is .4v ign on eng off and 1.2v eng on so both maf and tps are reading good. Checked to see if my injector o- rings are leaking and nothing as far as I can tell. I also swapped back to the factor coils and igniror setup and it didnt make a difference and the codes 21,34 returned
03-03-2017, 10:41 PM | #21 |
*UPDATE*So today I found some interesting things. Pulled my cas and could barely turn it by hand, knowing at the very least the bearings are shot I borrowed a known working cas hooked it up, deleted the codes and with the ignition switch on engine off spun the cas by hand for a minute or two and checked the codes again and code 21 is gone so waiting to order a new cas and hopefully my issue will be resolved
