03-24-2007, 12:36 PM | #1 |
e brake cable how to
im replacing my e brake cable. does anyone know what to do before i go at it. and are there any upgrades to do here or do i just use an oem cable? thanks
white '92 hatch |
03-24-2007, 12:53 PM | #2 | |
Replacing is very straightforward. Just follow the FSM and adjust as necessary. Make sure the wheels turn freely and lock completely to spec. Your only upgrade would be hydraulic rear brakes, but they're not meant to replace parking brakes, and would also be very expensive. |
03-24-2007, 02:52 PM | #5 |
its easy... if u dont have rear z32, it connect from the ebrake handle... then clamps on the subframe and disconnect it from the rear caliper...
S14 TrackSlut coming to a raceway near you... 510 TimeAttack on its way... |
03-24-2007, 03:53 PM | #6 |
i looked underneath the car. the nut on the handle itself is goe. it must had snapped off. but the right rear was still clamped. so i got the car jacked up and wiggled the brake lines and it popped free. idk how it was stuck but it was. it ok for now but i can get it on a lift on onday to get a better look at it. please if anyone can help please do. im really fed up with this car.
white '92 hatch |
03-24-2007, 08:06 PM | #7 |
Just take off your drive shaft and catch all the trans fluid. Drill two new holes for each e-brake line and put in some new bolts. Relocate over a little bit that's all. No biggie. You can do it. If you talking about the part that attaches to the e brake handle then your gonna have to take a trip to the junk yard. Or buy one off me.
03-24-2007, 08:32 PM | #8 |
haha. and how much you selling for? i dont think the two lower cables are bad, but theone in the handle needs to be replaced. idk if i can just replace one or if its all one unit
white '92 hatch |
03-24-2007, 08:40 PM | #9 |
the handle connects to the separator.
i broke my handle and took it off thinking i could sep. the lines.. you really cant, unless you drill out the big ass rivet. i have stock s13 ebrake lines if you need em. i dont know what car you have.. so i just put that plug^ there |
03-24-2007, 08:45 PM | #10 |
So you broke your line that attaches to the handle. I thought by your description that you broke the lines attached to the back brakes. I have an e brake handle with the line. Shoot me an honest offer and its yours.
03-23-2017, 03:37 PM | #11 |
Brake/Ebrake issue
Recently did my subframe bushings/ diff bushings/ ball joints(rear) rebuilt front and rear brakes after the demand seamed to be seized. Problem I'm having is hooking up the ebrake cables to the calipers. I had initially put the cables back in crossed when I put the subframe back in(head slap) but I corrected it but I can't seem to connect both sides of cables. My driver side went on easily but it seems that I'll have to tension the holy hell out of the pass side to connect then it feels that I have constant pressure from ebrake causing lock. Is there a step I'm missing to connect the cable that I'll feel stupid about? Keep in mind the handbrake is down not engaged. I have loosened the ebrake from the 10 mil on handle. Any help please
03-25-2017, 10:21 AM | #12 |
Do you have the right cables?
03-26-2017, 02:22 AM | #13 |
Stock cables fit in proper sides via mounting brackets and clips under driveshaft. Somebody mentioned the riser bushings pinching the cables if that's the cause anybody know a way around this?
