Old 01-10-2013, 07:52 AM   #91
turbo2nr
turbo2nr's Avatar
turbo2nr will become famous soon enoughturbo2nr will become famous soon enoughturbo2nr will become famous soon enoughturbo2nr will become famous soon enoughturbo2nr will become famous soon enough
Send a message via AIM to turbo2nr
awesome build! keep it up, im taking alot of hints from you on your vmount, im also in the process of v-mount for my s14.
keep it up!
s14 kouki ka-t
turbo2nr is offline   Reply With Quote
Old 01-10-2013, 09:07 AM   #92
mishimoto
mishimoto's Avatar
mishimoto is an unknown quantity at this point
Great fabrication skills. Coming along nicely.
Mishimoto Automotive
mishimoto is offline   Reply With Quote
Old 01-10-2013, 12:52 PM   #93
Mannykiller
Mannykiller's Avatar
Mannykiller is an unknown quantity at this point
Thanks guys!!
You know it's really not a v-mount at all.. I actually got the idea from the sierra-sierra time attack evo. But I just moved everything as far back as possible to keep everything as close to the center of the car as possible. no more IC hanging over the front end of the car, and no more radiator hanging over in front of the steering rack. Will be cool to see the actual difference in weight distribution when the car actually runs =-) I'm excited to get her finished!! more updates soon!!
Mannykiller is offline   Reply With Quote
Old 01-11-2013, 11:42 AM   #94
Mannykiller
Little Update:
So I was looking at some of my parts yesterday morning and realized that I forgot to cut a hole in my BOV tube. So not having a large porting tool.. I drilled a series of holes around the aluminum and used a dremel to clean it up/port it nice and smooth. Came out damn good.. must say.. i'm getting pretty good at being patient and blending metals ;-)
and all cleaned up and done
More Updates soon!
Old 01-11-2013, 12:08 PM   #95
Team Runner Video
Team Runner Video is an unknown quantity at this point
Subscribed!!
Team Runner Video is offline   Reply With Quote
Old 01-11-2013, 12:25 PM   #96
PrimeDirective
PrimeDirective's Avatar
PrimeDirective is an unknown quantity at this point
Top notch work, I think your intercooler and radiator set up is awesome! I love how short the piping is. And though I'm probably missing something, could you of designed the inlet and outlet ports of the radiator differently so you didn't have to have so much radiator piping snaking around the front of the engine?
PrimeDirective is offline   Reply With Quote
Old 01-11-2013, 12:43 PM   #97
Extreme Dimensions
Extreme Dimensions's Avatar
Extreme Dimensions is a splendid one to beholdExtreme Dimensions is a splendid one to beholdExtreme Dimensions is a splendid one to beholdExtreme Dimensions is a splendid one to beholdExtreme Dimensions is a splendid one to beholdExtreme Dimensions is a splendid one to beholdExtreme Dimensions is a splendid one to beholdExtreme Dimensions is a splendid one to beholdExtreme Dimensions is a splendid one to beholdExtreme Dimensions is a splendid one to beholdExtreme Dimensions is a splendid one to behold
DANG! keep up the work on the rx7 and hopefully I get to see this thing run at willow when its done.
- Chris Gary
p: 714-278-8000 x 19
E: [email protected]
Extreme Dimensions is offline   Reply With Quote
Old 01-11-2013, 12:55 PM   #98
The1991sx
The1991sx's Avatar
The1991sx is an unknown quantity at this point
I'm.... officially a fanboy of your FD.
Great work! Plus all that custom fabrication!
The1991sx is offline   Reply With Quote
Old 01-11-2013, 01:40 PM   #99
510erv
510erv is an unknown quantity at this point
very nice build looks good
510erv is offline   Reply With Quote
Old 01-13-2013, 10:48 AM   #100
Mannykiller
Yes, you are correct!! You know I left it long for the time being because i havn't gotten the time to fit my radiator fans. So just looking at it...its a pretty tight fit for coolant lines.. So I wanted to keep the coolant line away from the Turbo housing but if it I made it short... it would hit the fan area.. So i figured why not loop it all the way around so that it cleared both fans and was routed around to the cold side of the engine. I'm still not Certain i'll keep them looped that much..but It does clear the fans now, so it'll most likely stay this way unless I run into clearance issues =-) Thanks for the input!!
- Ap
Old 01-13-2013, 01:52 PM   #101
KoukiMonsta
KoukiMonsta's Avatar
lookin good man!
can you give me more info on the cannon plug? i want to do something like that but where can i acquire the plug?
@UpshiftEngineering
Old 01-15-2013, 04:03 PM   #102
Mannykiller
Little Update:
This is always a good sign!!
good stuff!
Needed to re-make the oil line for my oil coolers that went from the motor to my thermostat
..came out good!
Finally got around to finishing up the manifold turbo flange..needed to be port matched to the divided housing. It was off alot. Don't have pics but it was off almost a 16th of an inch on the right side of each divided port..if that makes sense.
THis is finished though.
Got the adapter for my power steering line... no more banjo oem line!!
out with the old in with the new!!
installed
also put a AN plug in the bottom of my UIM...been putting this off for far too long..
Old 01-15-2013, 04:06 PM   #103
Mannykiller
It came with my Harness!! you can get them at RYWIRE.COM!! Thanks!
Got the compressor housing off my turbo...and clocked it in order to take advantage of thermal siphoning!!
Old 01-15-2013, 04:10 PM   #104
Mannykiller
Also installed my Pineapple racing Idler pulley...got it for 145 SHIPPED!! BNIB!! excellent used item deal!!
took my compressor housing off and clocked it in order to take advantage of thermal siphoning
still need Oil and water lines!!
And used a pvc pipe that bent with the contour of the hood to cut my Wastegate tubes so I could close the hood
done
And so here she sits..99% mechanically complete!! just turbo oil and water lines and she's ready to be all taken apart for paint!!
More updates soon!!
Old 01-15-2013, 06:44 PM   #105
nujabe
nujabe's Avatar
nujabe can only hope to improve
epic thread... i cant wait to see it painted and moving!!
Some black guy who lurks zilvia.
nujabe is offline   Reply With Quote
Old 01-16-2013, 07:37 AM   #106
mishimoto
mishimoto's Avatar
That waste-gate setup is awesome! Can we expect a running video before it gets ripped back apart?
Old 01-16-2013, 09:10 AM   #107
blo0d
blo0d is an unknown quantity at this point
when r the tubs going in? killer build btw.
blo0d is offline   Reply With Quote
Old 01-16-2013, 09:55 AM   #108
Mannykiller
No running vid before it gets torn apart... haha I don't want to fill fluids for a start up =-) If money wasn't a concern it'd be different..just not that baller.
Tubs are for show cars and hard parkers.. I may make some sheet metal removable covers though ;-)
Old 01-16-2013, 09:57 AM   #109
Mannykiller
Lastly..forgot to post a pic of my cut waste gates...cleaned them up on the belt sander.
still need to get the tape off...used it to get the right cut marks
Old 01-16-2013, 10:01 AM   #110
mishimoto
mishimoto's Avatar
So we have to wait even longer! Lol I understand well done thus far.
Old 01-22-2013, 09:38 AM   #111
Mannykiller
Small Update:
Went ahead and sealed the rear fenders again.. I didn't like the clear silicone previously on there...plus there were some gaps where stuff could get in and I didn't want a bunch of dirt/sand/muck getting wedged all inbetween the body panels and the interior panels. I hate when stuff bounces around..or you hit a turn and you hear stuff sliding all around etc.
anyways....
first
IMG]http://i804.photobucket.com/albums/yy325/mannykiller/FD%20Build/IMAG1767.jpg[/IMG]
done
THen I got to work making a template to cut the hood for my wastegates
traced the template onto the hood after lining it up all nice
rough cuts
almost done
And final product!! came out great!! i'm loving it!
After cutting the hood I decided to get to work on the last real components to my set up... Oil/coolant lines for the turbo. So at first I really wanted to do stainless braided lines to keep everything moveable...but I had some spare tube laying around and all I needed was one fitting..so I got to work on some hard lines.
first was the Oil feed...
Then the water feed line
and from this angle it looks completely pointless as it looks like there are a bunch of useless bends going this wat and that.. But the horse shoe looking bend under the turbo is for my Oil drain. This way the line's wouldn't have the chance of rubbing or rattling together.
And lastly, the Water drain. Now i'll have to check the garrett faq page again..but I may have to re-do this line for thermal siphoning. I think Garrett says to take advantage of thermal siphoning the water drain must not be higher than the inlet to the system.. Or was it the highest point in the cooling system? I an't remember....if I got it wrong..i'll have to go ahead and re do the line as best as possible. But there are very limited options as how to route the line already... All the lines will need DEI heat sleeving though... otherwise they'll just get too hot for my peace of mind out there on the track!
I wasn't able to get the oil drain line done because I am missing the fitting/flange that goes from the block to the line. I'll have to order one asap!!...this line will be - AN10 and stainless braided. Big oil drain is a "need."
Old 01-22-2013, 09:48 AM   #112
Mannykiller
p.s......Anyone know someone who paints pretty good that doesn't charge a ton? It's hard for me to justify spending money on paint when I know what the car will be used for... 3 years ago my buddy spent 2500 on a paint job. His first drift event made him regret his decision completely because he got tapped twice and put into the K-rail. His 2500 dollar paint job looked dooo dooo haha
Old 01-22-2013, 10:23 AM   #113
mishimoto
mishimoto's Avatar
Nice job on the lines and the hood looks great as well.
Old 01-22-2013, 10:29 AM   #114
Mannykiller
^Thanks man!!!
Old 01-22-2013, 11:29 AM   #115
Mofuhcka
Mofuhcka's Avatar
Mofuhcka is an unknown quantity at this point
A friend of mine does it pretty cheap if you dont mind going up to the bay area
@hcr32love 400whp NEO R32 Sedan
Mofuhcka is offline   Reply With Quote
Old 01-22-2013, 12:21 PM   #116
bc.
bc.'s Avatar
bc. is an unknown quantity at this point
Step 1: grab two racquetballs
Step 2: insert into wastegate holes
Step 3: mash the throttle
Step 4: watch them enter orbit
* S14SR22 * 9.0 c/r * GT3071R *
bc. is offline   Reply With Quote
Old 01-23-2013, 08:27 AM   #117
Mannykiller
^^ I was thinking of putting the steel flappers on the top like the big rigs hahaha
Old 01-23-2013, 08:48 AM   #118
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
First this /\/\/\/\/\
THEN this \/\/\/\/\/
Old 01-23-2013, 09:02 AM   #119
Supergoji
Supergoji's Avatar
Supergoji is an unknown quantity at this point
Send a message via AIM to Supergoji
manny was ur fd yellow at one point and were u ever a part of groovydrift?
www.NYZC.net
Supergoji is offline   Reply With Quote
Old 01-23-2013, 09:55 AM   #120
spooled240
spooled240's Avatar
spooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfection
I prefer the hardlines over the steel braided lines
spooled240 is offline   Reply With Quote
adaptronic
