09-18-2013, 06:08 PM | #1 |
Best way to ground dualfanshroud?
Hey so i recently picked up a IsIs dual fan shroud for my mishimoto radiator & I havent really dealt with grounding things since the stock fan was a sensor I could just plug in. So i was wondering where and what way would be the best to ground the fan? I heard I could ground it to a switch , the ignition n a couple others. What would be best & more efficient ? Ka24de...Thanks in advance & sorry if this thread has been made already.
09-18-2013, 06:14 PM | #2 |
Trader Rating: (106)
Feedback Score: 106 reviews
First off, ALWAYS use a relay to control a high amperage load like a fan. I, personally, use one of the stock fan switches from a singlecam to GROUND the RELAY for my fan. I also sometimes wire-in a switch on the dash so I can turn the fan on if I want to. The wiring can get pretty complicated and time-consuming to make it look good, especially with a dual fan setup.
09-18-2013, 07:25 PM | #3 |
Listen to that guy^ go to pick and pull and swipe a few relays and make the ground be your switch.
Nothing says racecar like a stock car with no interior. |
09-18-2013, 11:04 PM | #4 | |
09-23-2013, 03:32 PM | #5 |
that's not a bad idea, but how would the car know when youre at a complete stop to turn the fans on? wouldn't it just turn on everytime you tapped your brakes without actually coming to a complete stop? and if this is the case, it sounds like you just need it on a switch to where you can manually control when you want it on. it just sounds like a lot of unnecessary work imo.
