01-13-2005, 06:01 PM | #1 |
Edited - !!!Clean 93 S13 Coupe with built SR and new paint for sale!!!
Well, now that I'm moving from San Antonio, Texas to San Diego, California, it is time to sell my 93 S13 Coupe with the built (54C internals) redtop. I have to sell it ASAP as I have to be in California by the end of Jan.
I've got 26k in the car and I'm letting it go for 10k! The car is located in San Antonio Texas and will only be shipped at buyers expense. The car is in VERY good mechanical shape and purrs like a kitten. It even has fully functional AC charged with R134a. It's also got new paint, Defi Link gauges, an uncracked dash, and a TON of extras (see website). More info (many more pics, vin #, email, etc) can be found here: http://home.satx.rr.com/silviaweb/car_sale.htm Please contact me via email with ANY questions at [email protected] I will NOT accept trades, or monthly payments. Oh yeah...sorry, I can't deliver it to California when I move out there either. Edit: Here are all the mods with the prices I paid for them. Again, the price is $10,000.00 Engine: Redtop SR20DET engine (fully rebuilt 10k miles ago due to diluted oil = spun bearing) $2500 SR20DET 5 speed transmission Brand new Nissan 54C Factory Overbore Pistons $200 Brand new Nissan Factory Overbore Piston Rings $82 New Nissan 54C Main Bearings $75 New Nissan 54C Rod Bearings $48 New Nissan 54C Main Bolts $25 New Nissan 54C Connecting Rod Bolts $24 New Nismo roller bearing pilot bushing $15 .2 mm overbore block $1300 for all machining New freeze plugs in block Complete machine balance of all rotating mass together All aluminum engine parts "cold tank" cleaned New oil pump $240 New water pump $89 New IACV $280 New valve seals $65 Bored and sleeved valve guides 5 angle valve job Greddy Rocker Arm Stopper $70 New timing chain $85 New timing chain tensioner $75 New timing chain tensioner gasket $15 New timing chain guides (Metal and plastic VS Plastic) $100 ARP head studs $130 Cometic head gasket $100 Nismo Thermostat $70 Nismo engine and transmission mounts $215 Toda lightweight flywheel $450 New Front Main Seal $13 New Rear Main Seal $19 Blitz LM intake kit $123 New Nisan intake collector gasket $16 New Nissan intake manifold gasket $15 New Nissan multilayer exhaust manifold gasket $50 New exhaust manifold inlet gasket $15 New exhaust turbo outlet gasket $30 New O2 sensor $95 Greddy 02 Extension $215 Greddy 3" Downpipe $145 Apexi N1 3"exhaust $400? Taka Turbo Lines $160 Cusco hot pipe $90 Blitz LM Front Mount Intercooler $890 HKS Super Sequential Blow Off Valve $200 Completely Polished Intake Manifold $250 Spec Stage III clutch $339 Samco Radiator Hoses $115 C&R Racing Custom Aluminum Double Pass Radiator $600 Walbro Fuel Pump $140 Greddy Oil Filter Relocation Kit $145 Canton Oil Filter Housing $102 Canton 2 quart Accusump with electric valve $325 New radiator Overflow tank $80 SVR Battery $125 Subtotal: $10,950 Suspension: Nismo Power Brace $180 Cusco Tension Rods $328 Tein Tie Rods $150 Whiteline Adjustable Front Sway Bar $180 Whiteline Adjustable Rear Sway Bar $180 Whiteline Polyurethane bushings all around $200 Whiteline Sub-Frame Align and Lock Kit $85 Whiteline Springs $200 Whiteline Front Strut Tower Brace $140 Whiteline Rear Strut Tower Brace $145 Koni Adjustable Struts and struts $400 Cusco Adjustable Rear Upper Control Arms $380 D-Speed Transmission Tunnel Brace $350 Subtotal: $2918 Brakes: 180SX Calipers in Front and 240SX Calipers in Rear Altima Front Rotors Metal Master Pads Electronics: Greddy Profec B Boost Controller $320 HKS Fan Controller $175 DEFI Link Gauge Controller II $113 DEFI Link Boost Gauge (PSI) $199 DEFI Link Oil Pressure Gauge $217 DEFI Link Water Temperature Gauge (F) $155 DEFI Link Oil Temperature Gauge $155 Eclipse CD player Fuba Roof Mount Antenna (Acura MDX Style) $50 Subtotal: $1384 Exterior: Carbon Fiber Hood (now painted) $350 Bomex Wangan Rear Wing $300 16" 5Zigen Imperio S08 rims $600 Kuhmo Ecsta Supra tires $400 New Paint (JUST painted) $650 Hella Headlights PIAA wiper blades (they work DAMN well) Subtotal: $2,300 Total: $17,552 Chassis: $2,000 Grand Total: $19,552 As you can see, I have a ton of money dumped into this car and I am letting it go for only $10,000.00!! The car has NEVER been drifted, dragged or even autocrossed! I also have a bunch of spares (probably 2k worth) that I am throwing in with the car! Last edited by fsae_alum; 01-14-2005 at 12:29 PM.. Reason: Inluded mods |
01-14-2005, 07:40 AM | #3 |
It's actually "silver satin". Yep...I thought about taking it to California with me but when I went to JGTC, everybody I talked to said that it is getting worse by the day in the San Diego area for 240SX SR owners. With my new job, I don't have any time to deal with all the legal hassles that an SR could bring in southern California.
02-16-2005, 11:31 AM | #6 |
just bring it with you to san diego. just dont screw around in your car like alot of people here do and ull be find. for a while.
02-18-2005, 09:27 AM | #8 |
Yea, bring it to cali. Your car will sell within the first few hours once it hits cali! And the price of it will skyrocket!! from 10,000 to like 15000!!! Hahaha. Damn Cali!!!
If you dont know SEARCH!!! |
