Old 02-28-2018, 09:10 PM   #1
k00laid83
k00laid83's Avatar
k00laid83 is an unknown quantity at this point
Power Steering Fittings
Hello Everyone,
So a couple of years back I created a thread gauging interest on who would be interested in buying S-Chassis specific PS fittings. I've been in contact with a manufacturer who will make the PS fittings, and before I go all in I want to see if members would be interested. The S-Chassis specific PS fittings will be made in brass or steel. I'm leaning towards brass to avoid rusty fittings. I'm avoiding aluminum since I've experienced aluminum fittings snapping on me.
The reason I've looked into this was that I was tired of my steering rack always leaking ps fluid, because of fittings that came in my kit were to short. I tried everything to stop the leak, like slapping a bunch of sealant on the threads, crush washers, washers with rubber seals, and different fittings. None of that worked and my rack still leaked. I was fed up so I ended up making my own fittings from the original lines and welding them to -6an bungs. Since, I've done that I haven't had one single leak for over a year. Now I'm looking into having fittings made and wanted to see if the community would be interested in something like this.
Last edited by k00laid83; 04-12-2018 at 08:46 AM.. Reason: Removed old pricing so there aren't any confusions
k00laid83 is offline   Reply With Quote
Old 02-28-2018, 09:33 PM   #2
RalliartRsX
Trader Rating: (32)
RalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfection
Feedback Score: 32 reviews
I would be interested
Also in search of replacing the banjo bolt and banjo bolt extender with a -AN fitting and line for fitment
RalliartRsX is offline   Reply With Quote
Old 02-28-2018, 09:38 PM   #3
k00laid83
k00laid83's Avatar
Thanks for the heads up. As for that banjo fitting, try a 16mm x 1.5 fitting to 6an. That's what I'm using for the pump but I'm still using the banjo itself.
Old 02-28-2018, 09:37 PM   #4
tongva
tongva's Avatar
tongva is an unknown quantity at this point
PS fluid is messy when there’s a leak.. would give this a try
tongva is offline   Reply With Quote
Old 03-01-2018, 07:02 AM   #5
los_inc
los_inc's Avatar
los_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond repute
Send a message via AIM to los_inc
i would like a set. <3
los_inc is offline   Reply With Quote
Old 03-01-2018, 08:01 AM   #6
tuzzio
tuzzio's Avatar
Curious why they're sold in pairs when typically the one to leak is the high pressure line going into the rack.
Edit: not to burst your bubble, but chasebays offers a revised fitting which you can buy on their website for like $10. I have a comparson picture between their old fitting and their new one and the middle is definitely thinner to let the o ring get further into the rack. If I recall, there was about an .080" difference between fittings when I measured.
Old 03-01-2018, 08:21 AM   #7
PoorMans180SX
PoorMans180SX's Avatar
Maybe that one isn't made in China :lol:
to the OP: I use a steel fitting at the rack that you can actually put some torque into and it's given me zero issues.
Old 03-01-2018, 09:34 AM   #8
k00laid83
k00laid83's Avatar
I've thought of getting steel fittings, the only issue I considered was it rusting. I'm thinking about people out in the east coast. I had set in my mind that brass would help with the rust issue.
Old 03-01-2018, 09:32 AM   #9
k00laid83
k00laid83's Avatar
Talking
I just took a look at their revised fittings and it looks the same as the ones that I was provided. When I had the issue chasebays did send me a different set, but it still leaked. When my rack was leaking I had a leak come from both the high and low pressure line. Once I welded bungs to my old lines my leaking problem went away.
What I'm going to sell will be both PS fittings with o-rings. The low pressure side will be an o-ring fitting as well. I want to ensure I provide something that ensures there are no leaks.
I attached pictures of my old fittings for comparison.
Last edited by k00laid83; 12-13-2019 at 09:45 PM.. Reason: Fixing all of the photobucket issues
Old 03-01-2018, 12:07 PM   #10
240KA
240KA is just really nice240KA is just really nice240KA is just really nice240KA is just really nice240KA is just really nice240KA is just really nice240KA is just really nice240KA is just really nice240KA is just really nice240KA is just really nice
i'd be interested.
could you PM me a link to the $14 aluminum ones? i'm curious
240KA is offline   Reply With Quote
Old 03-01-2018, 12:19 PM   #11
KAT-PWR
KAT-PWR's Avatar
KAT-PWR is just really niceKAT-PWR is just really niceKAT-PWR is just really niceKAT-PWR is just really niceKAT-PWR is just really niceKAT-PWR is just really niceKAT-PWR is just really niceKAT-PWR is just really niceKAT-PWR is just really nice
weld AN fitting to stock fitting.
MRP Manufacturing
KAT-PWR is offline   Reply With Quote
Old 03-01-2018, 12:28 PM   #12
Hoffman5982
Hoffman5982's Avatar
Trader Rating: (25)
Hoffman5982 is just really niceHoffman5982 is just really niceHoffman5982 is just really niceHoffman5982 is just really niceHoffman5982 is just really niceHoffman5982 is just really niceHoffman5982 is just really niceHoffman5982 is just really niceHoffman5982 is just really niceHoffman5982 is just really nice
Feedback Score: 25 reviews
I've bought multiple high pressure fittings over the years ranging from Earl's to the cheapest I could find on eBay, none of them leaked. So I'm calling bs on the high pressure line being the most common one to leak. The low pressure one is the one you have to get fittings machined down so they seat correctly. I need one myself but the only one I can find is the guy on here selling the pair for almost $70 which is a bit ridiculous imo
Hoffman5982 is offline   Reply With Quote
Old 03-01-2018, 12:36 PM   #13
k00laid83
k00laid83's Avatar
You can call BS but mine leaked until I welded up 6an bungs to my stock lines
Old 06-25-2018, 01:04 PM   #14
LayNLow
LayNLow is making a name for him/her selfLayNLow is making a name for him/her self
I always had a problem with the high pressure side leaking. Tried many washers and other stuff to kill the leak but was never really able to. With these, I actually felt the o-ring seat into the rack.
Thanks K00laid!
LayNLow is offline   Reply With Quote
Old 06-25-2018, 01:29 PM   #15
k00laid83
k00laid83's Avatar
Thanks K00laid!
I'm glad to hear that the fittings worked out for you. It's nice to hear!
Old 03-01-2018, 01:06 PM   #16
Hoffman5982
Trader Rating: (25)
Didn't say they never leak for people, I said it's not the most common one to leak.
Old 03-01-2018, 01:49 PM   #17
tuzzio
tuzzio's Avatar
Comparison shot of my chasebays fittings.
Old 03-01-2018, 01:51 PM   #18
RalliartRsX
Trader Rating: (32)
One thing to note: in a quick 10 sec search via Google, I uncovered no fewer than 5 companies which either make the line(s), the proper (longer) fittings or both as a package (and this is outside of ISR and ChasBays).
Just something to keep in mind.
The $70 set on here is just outrageous. I think I saw the set as cheap at $22 + shipping (so maybe $30 total). Albeit AL fittings.
Old 03-01-2018, 03:27 PM   #19
Hoffman5982
Trader Rating: (25)
Have a link to the low side fitting? I haven’t been able to find a longer one
Old 03-01-2018, 03:39 PM   #20
Mitsubayati
Trader Rating: (18)
Mitsubayati is an unknown quantity at this point
Feedback Score: 18 reviews
Send a message via AIM to Mitsubayati
also interested in low side fitting. As far as kits, I've used the ISR one with their rack fitting and haven't had any issues at the rack. The PS pump side washer/seal is garbage though. Leaked immediately. I used a copper washer in front of it and it worked.
http://www.fittedlife.com/images/nickbanner.jpg
Mitsubayati is offline   Reply With Quote
Old 03-04-2018, 08:19 PM   #21
NismoPlsr
NismoPlsr is an unknown quantity at this point
Yea dudes, here is a pair for cheaper than I can get fittings prior to re-oping. These didn't exist a couple years ago. They look like they would fit and seal pretty good. Anyone try them yet?
https://www.cutwormspecialties.com/p...ck-an-fittings
S12 || KN13 || S13 || B16
NismoPlsr is offline   Reply With Quote
Old 03-04-2018, 09:55 PM   #22
Smurf_240SX
Smurf_240SX's Avatar
Smurf_240SX has made poor choicesSmurf_240SX has made poor choicesSmurf_240SX has made poor choicesSmurf_240SX has made poor choicesSmurf_240SX has made poor choicesSmurf_240SX has made poor choices
Send a message via AIM to Smurf_240SX
I purchased some about a week ago, quality seems really good. Have yet to actually try them out, still rebuilding my car, but can't wait to try them out.
FS OEM RB25 PARTS
Smurf_240SX is offline   Reply With Quote
Old 03-05-2018, 01:49 PM   #23
k00laid83
k00laid83's Avatar
I've seen that company, and the fittings look great. I'm interested in fittings other than aluminum. I've had bad experiences with AL fittings.
Old 03-05-2018, 02:04 PM   #24
Hoffman5982
Trader Rating: (25)
You the best. Will be ordering one of these for sure
Old 03-05-2018, 02:20 PM   #25
RalliartRsX
Trader Rating: (32)
That's the set I was referring to in my post
Why are people so keen on NOT running AL?? If the fitting is built correctly, one should NOT have to crank down on it and strip threads/destroy fittings. If you are destroying fittings or have some aversion to AL, you are doing something wrong
Old 03-12-2018, 09:16 AM   #26
k00laid83
k00laid83's Avatar
I haven't tried any AL fittings on my rack. I had a bad experience with a AL fitting on my turbo I had back in the day on my civic. It wasn't over tightened it had snapped right above where it threaded in. It was perfect for a few months and then just broke. So I personally always use steel or brass if possible.
Just installed the Cutworm fittings along with my new rack and they did the trick. I bought both fittings and the total after shipping was right around $27. I would definitely recommend anyone with a ChaseBays kit pick these up if you're having trouble with leaking at the rack. I don't really see a problem with them being aluminum, the fittings have O rings and are the proper length so you don't really have to crank down all that hard to get them to seal.
I'm glad they worked out for you. Great option! I've been in talks with a few hydraulic companies about these fittings, and every fitting I've seen that they provide needs to be milled. The quality of all the fittings I've seen are amazing. I just can't seem to find fittings besides cutworm that are just long enough without being milled. I've even thought of buying a small mill and milling down their fittings.
Old 03-06-2018, 07:19 AM   #27
Rustys14
Rustys14's Avatar
Rustys14 is a glorious beacon of lightRustys14 is a glorious beacon of lightRustys14 is a glorious beacon of lightRustys14 is a glorious beacon of lightRustys14 is a glorious beacon of lightRustys14 is a glorious beacon of lightRustys14 is a glorious beacon of lightRustys14 is a glorious beacon of lightRustys14 is a glorious beacon of lightRustys14 is a glorious beacon of lightRustys14 is a glorious beacon of light
So glad you posted this link, just ordered a set! I think these might finally be the ticket to keeping my ChaseBays kit from leaking at the rack. I have a brand new HICAS rack sitting in the garage waiting to replace the standard rack so hopefully the new rack coupled with these fittings will finally solve my powersteering woes...
Originally Posted by bossin240 View Post
I have a pretty badass neon.
Rustys14 is offline   Reply With Quote
Old 03-06-2018, 08:23 AM   #28
CamryOnBronze
CamryOnBronze's Avatar
Trader Rating: (131)
CamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud of
Feedback Score: 131 reviews
Send a message via AIM to CamryOnBronze
These look like they would do the trick- good find.
I had this issue with my Chase Bays kit. After trying numerous different fittings and tricks I read in many old threads, I picked up these fittings from Allstar and had a friend machine them down for me. No leaks since:
This is a good thread- will solve a lot of people's headaches for sure!
CamryOnBronze.com
CamryOnBronze is offline   Reply With Quote
Old 03-05-2018, 02:04 PM   #29
TheRealSy90
TheRealSy90's Avatar
If the oring is sealing properly, there's no need to crank the fitting down so tightly to seal on a crush washer. Thus you shouldn't be stripping or snapping off the fitting.
Such a good signature.
Old 03-05-2018, 02:31 PM   #30
TheRealSy90
So is it common practice to keep the high pressure line connector to the pump or to remove it?
I usually see it done both ways as the fitting usually supplied with most kits can be installed into this connector, or you can remove it and install straight into the pump itself. Thing is I believe the banjo bolt securing the connector to the pump is actually also a pressure regulator. Would be interesting to find out if people with PS issues did or did not retain it.
