01-29-2018, 11:10 AM | #1 |
Rusty Flywheel
I broke my finger and couldn’t finish my 5 speed swap. Had the flywheel bolted up and just needed to get the bellhousing up. Anyway it’s been about a month since I’ve touched it and with all the snow and moisture in the air, my flywheel has gotten a lot of surface rust all over it. What is the best way to clean this up before I bolt up the bellhousing?
01-29-2018, 11:39 AM | #3 |
Get it resurfaced at your local machine shop, it should run you about $35. As per the rest of the rust a wire wheel or soaking it in anything else that eats rust would be your best bet. Just be sure to soak it after resurfacing.
