Wanted to Buy Post your needs and wants here. |
10-09-2017, 03:28 PM | #1 |
Wtb used s14 diff/subframe bushing
Ok, so I'm doing differential and subframe bushings on my s14, 1 of my rear differential bushings is damaged. So I need a used rear differential bushing from the inside of subframe. I only need 1, let me know what you have with pics so I can make sure it's the right part.
Reason why I want the used bushing is so I can get the metal piece from the inside of it. Last edited by Chief 1402; 10-24-2017 at 06:51 PM.. |
10-26-2017, 01:53 PM | #6 |
those are pretty impossible to press out without a special press so i don't see it likely you'd find a "used" set. i had to burn mine out to to energy suspension bushings in.
why don't you just use energy or powerflex bushings to replace it? its really not that expensive.
10-26-2017, 01:56 PM | #7 | |
10-26-2017, 06:41 PM | #8 | |
10-26-2017, 06:44 PM | #9 |
Yes. The cup that the bolt goes through is what is cut. So I only have 1 to reuse. I'm looking for 1 differential bushing from subframe to have a bonfire for the metal piece inside.
11-01-2017, 01:44 PM | #13 | |
11-03-2017, 02:59 PM | #16 |
Is there a salvage yard near you you can try and source from another nissan? J30, z32, Q45 or any onther R200 equivalent? I can't find a definitive answer but since they're interchangeable and use the same Diff bushing I'd assume they have that cup??
Sent from my SM-G930P using Tapatalk |
11-03-2017, 03:01 PM | #17 | |
I was thinking the same thing, since they all interchange maybe it will be the same, but nope. |
11-03-2017, 03:09 PM | #18 |
Ahh Bummer. Perhaps It' the title of this thread because it wasn't till your reponse to reborns14's post that I knew you just need the cup... and if you've been on Zilvia long enough you know most don't like reading anything between the 1st and last post.
11-03-2017, 03:15 PM | #19 | |
