Old 03-26-2015, 04:32 PM   #1
mrtwoforty
mrtwoforty is an unknown quantity at this point
s13 S13 Manual Steering Rack Problems...
So i picked up an ka24de s13 and the power steering lines are all screwed up, to the point where I would have to buy all new lines, and that would cost money. Since I am cheap I was thinking I would just convert it to a "manual steering rack". I was going to loop the lines and stick a small reservoir on. Now the problem is that the belt that goes to the ps pump also goes to the water pump so I cant just take it off. Wondering if anybody knows what belt I would need fit only around the water pump pulley. Also if anybody knows a nice small reservoir that would be good for this let me know!
Thanks
mrtwoforty is offline   Reply With Quote
Old 03-26-2015, 05:26 PM   #2
TheRealSy90
TheRealSy90's Avatar
Looping the lines is not the correct way to have a manual rack. It's a good way to have your steering mess up and put your car in a wall. There are write ups on the correct way to convert the rack to manual operation.
Such a good signature.
Old 03-26-2015, 06:17 PM   #3
mrtwoforty
Even if i where to do that do you know what to do about the belt for the ps Pump?
Old 03-26-2015, 06:55 PM   #4
e1_griego
e1_griego's Avatar
Trader Rating: (24)
Feedback Score: 24 reviews
google it. You can use ka24e parts to do a power steering delete.
Or buy the xcessive kit.
Old 03-26-2015, 07:11 PM   #5
riprodder
riprodder's Avatar
Trader Rating: (30)
riprodder is an unknown quantity at this point
Feedback Score: 30 reviews
He is correct. I'm currently running a de-powered steering rack on my 91. The steering feels a little heavier but you can compensate for it a bit by over inflating the front tires some. I run mine at 32psi for reference. You'll need the alternator brackets and the thermostat housing from a KA24E. That will position the alt in the right place. You also have to grind a small clearance notch in the upper bracket for belt clearance. As for the belt I don't remember the length but I couldn't find a 3-rib one that was the right length, so i bought a 4-rib belt and removed a rib with a razor knife. For the rack itself, just remove the two small lines on the rear of it and you'll be fine. This keeps it from pressurizing either of the chambers in there so you can turn it freely. There is also a large lock nut and a small adjuster nut on the back of the rack. You will need to back the tension all the way off and then re-tighten it about 1 turn for just a little tension. Otherwise it will be really difficult to turn.
That being said. I personally wouldn't do it again and my spring project is to restore the power steering. Good luck with your project.
Coupe Love!
riprodder is offline   Reply With Quote
Old 04-06-2015, 01:34 AM   #6
Hoffman5982
Hoffman5982's Avatar
Trader Rating: (25)
Hoffman5982 is just really niceHoffman5982 is just really niceHoffman5982 is just really niceHoffman5982 is just really niceHoffman5982 is just really niceHoffman5982 is just really niceHoffman5982 is just really niceHoffman5982 is just really niceHoffman5982 is just really niceHoffman5982 is just really nice
Feedback Score: 25 reviews
This is correct. You also need the water pump pulley.
This is absolutely wrong, and it is not how you properly depower a rack. Depowering it involves taking it completely apart. I have a properly depowered rack and it feels great. The car was my daily throughout winter and I never regretted it.
Hoffman5982 is offline   Reply With Quote
s13
