Old 12-11-2017, 06:32 PM   #1
Balthizz
Balthizz's Avatar
Balthizz is an unknown quantity at this point
Ka24de turbo clearance issues.
So I am up-sizing to a HX35 this winter. However I have a terrible clearance issue with the brake master cylinder.
Does anyone know of a t3 top mount manifold that moves the turbo towards the front of the car. So I can fabricate a downpipe that wont cook my brakes?
Any help is greatly appreciated!!!!
Old Talent.
Balthizz is offline   Reply With Quote
Old 12-13-2017, 04:52 PM   #2
supersayianjim
supersayianjim's Avatar
supersayianjim will become famous soon enoughsupersayianjim will become famous soon enoughsupersayianjim will become famous soon enoughsupersayianjim will become famous soon enough
bummer!!!!!!!!!!!
supersayianjim is offline   Reply With Quote
Old 12-13-2017, 05:55 PM   #3
KAT-PWR
KAT-PWR's Avatar
Cxracing gen 2
Other cast manifold
MRP Manufacturing
Old 12-13-2017, 05:57 PM   #4
gtrpryde
gtrpryde is an unknown quantity at this point
I have a JGS log that clears great, but they're discontinued, so unless you find one used... no help there.
But Treadstone makes a cast manifold (that's not the typical revhard style.) It looks like it'll clear well, as long as you can clock the compressor. $350
https://www.treadstoneperformance.co...urbo-manifold/
Other than that DOC or Xcessive make nice but expensive tubular manifolds.
gtrpryde is offline   Reply With Quote
Old 12-14-2017, 08:14 AM   #5
tuzzio
tuzzio's Avatar
Friend of mine built my manifold. He's got it back and making a jig. If this interests you I can give you his contact info if you PM me. BTW, my turbo is a GTX3076R. I don't see why yours wouldn't fit.
http://zilvia.net/f/showpost.php?p=6180084&postcount=27
Old 12-15-2017, 05:25 AM   #6
Balthizz
Balthizz's Avatar
Its mainly the size/orientation of how the hotside terminates. I sent you a PM
Old Talent.
Old 12-15-2017, 06:22 AM   #7
Sailor
Sailor is a well-known jackass
There is also a "slim" version on the newer 240's that would increase the distance from your downpipe form you brake setup. It's on the second gens and it bolts right up to the first gens
Sailor is offline   Reply With Quote
Old 12-17-2017, 03:53 AM   #8
gaz_moose
gaz_moose is an unknown quantity at this point
the RHD master cylinders have the brake pipes coming out the other side.
gaz_moose is offline   Reply With Quote
Old 12-18-2017, 09:56 AM   #9
Kingtal0n
Kingtal0n's Avatar
convert to RHD...
Anything to avoid an engine bay fire. Remember that air has less heat transfer than metal; Wrap the downpipe, add a turbo blanket, then run two shields, with air between them.
I've seen too many of these cars burnt to the ground
Old 12-18-2017, 10:01 AM   #10
anti tyler
GM2 (SW/AW)
anti tyler's Avatar
Trader Rating: (37)
anti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfection
Feedback Score: 37 reviews
Send a message via AIM to anti tyler Send a message via Yahoo to anti tyler
Listen I've been through this with a KA-t and about 10 different manifolds.
Here's multiple solutions I've used and encountered;
RHD master cylinder. (My first KA-t used one, the lines can be gently moved to the other side)
CXracing manifold. (My last setup used a CXracing manifold/downpipe etc. this will move the turbo further forward. )
If you'd like pictures of either just let me know. Unfortunately I already sold my RHD cylinder on ebay. IF you'd like to go Z32 brakes, you'll need to get the CXracing manifold.
Or be like everyone else and don't run top mount
So you're only going to offer the manifold? Not the RHD master setup you're also using?
WillEastS14:
mannn u whylin son.
but that shyt has SWAG
KA-T for life!
Current for sale advertisement
anti tyler is offline   Reply With Quote
Old 12-19-2017, 08:06 AM   #11
tuzzio
tuzzio's Avatar
Its actually not a RHD master, Its a pathfinder master.
Old 12-19-2017, 08:48 AM   #12
TheRealSy90
TheRealSy90's Avatar
Yep, pathfinder brake master has the fittings on the other side same as a rhd master. That's what I used for clearance with my mid mount greddy manifold, as well as a smaller brake booster.
Such a good signature.
Old 12-20-2017, 04:41 PM   #13
brandon519
brandon519 has a spectacular aura aboutbrandon519 has a spectacular aura aboutbrandon519 has a spectacular aura aboutbrandon519 has a spectacular aura aboutbrandon519 has a spectacular aura aboutbrandon519 has a spectacular aura aboutbrandon519 has a spectacular aura about
What year pathfinder works? I'm assuming whichever one's had a ka but how about for a single cam.
brandon519 is offline   Reply With Quote
Old 12-20-2017, 04:46 PM   #14
Mitsubayati
Trader Rating: (18)
Mitsubayati is an unknown quantity at this point
Feedback Score: 18 reviews
Send a message via AIM to Mitsubayati
You can do what I didhttps://www.instagram.com/p/BKkFAgbB...realnickbayati
http://www.fittedlife.com/images/nickbanner.jpg
Mitsubayati is offline   Reply With Quote
Old 12-20-2017, 04:47 PM   #15
anti tyler
GM2 (SW/AW)
anti tyler's Avatar
Trader Rating: (37)
It appears mid 90's works. It's a 1"
Funny enough a guy I used to know made the comment on another forum.
by AndrewHuffman ยป Fri May 24, 2013 8:43 am
i did this on a s14.
but i used the non abs booster and a mid 90s pathfinder bmc
WillEastS14:
mannn u whylin son.
KA-T for life!
Old 12-20-2017, 04:48 PM   #16
brandon519
Thank you. And what a coincidence with your friend!
Old 12-22-2017, 09:45 AM   #17
apex128
apex128 will become famous soon enoughapex128 will become famous soon enoughapex128 will become famous soon enoughapex128 will become famous soon enoughapex128 will become famous soon enough
I think a brake booster delete kit might help move the lines over a little bit. Chase bays makes one for 200 bucks. Might be worth checking out.
apex128 is offline   Reply With Quote
Old 01-09-2018, 10:49 AM   #18
Balthizz
Balthizz's Avatar
I would love some more information about which booster and master cylinder You guys are using. Anyone know for sure what pathfinder master works?
If I could move the whole system back about an inch I think things will work.
I've heard from numerous friends that the chase bays booster delete feels like garbage, unfortunately.
Old Talent.
Old 01-10-2018, 08:08 AM   #19
tuzzio
tuzzio's Avatar
If I remember later i'll try to give you the part number off my master.
