09-21-2014, 08:06 PM | #1 |
1998 240sx rb26dett
Hey guys, for sale is my 1998 240sx se with a R33 rb26dett. I've had her for sale a few times, but never had the heart to let her go. Since I might be moving to LA soon I finally need to find her a new home due to the stringent inspection/smog laws.
The car The motor is running on stock internals but was taken apart and serviced before the swap. I replaced the headgasket, waterpump (n1), oil pump (n1), Thermostat (nismo), Type B Poncams, Hks gt2530 turbos, and new gaskets. The head was decked and hot tanked and the valve guides were replaced. Overall a very clean motor with mods that can take the car above the 500hp range. At this point in time I have the car tuned on 93 octane at 12lbs of boost and the car makes 395whp and 310tq. Pretty good numbers considering the turbos are good up to 22lbs of boost. The reason the car is not running at its full potential is that I am only running a 255 fuel pump on the stock injectors. Has power steering and heat, but no AC. I just installed some 12" derale pusher fans and the car does not budge above 175. To fix: 1) There is a very small weep on the oil pan. When I was fabricating the oil pan I had to shave down the aluminum fins for it to fit on the subframe and subsequently the pan now leaks about a drop or two of oil every couple weeks. Something so minimal I never bothered to fix it and do not see any real loss of oil between changes. I was quoted $650 for the fix. Parts on the car: -Mckinney Motormounts -Mckinney driveshaft -Mckinney Front Mount Intercooler -Mckinney Wiring harness -ACT 6 puck clutch -hks gt2530 turbos -Tomei poncams Type B -Apexi Power FC DJetro (JR tuned) -Apexi power intake kit -ALuminum radiator w/ 2 12" derale fans (4500cfm) -Synapse BOV -KYB AGX struts -Defi blue racer oil pressure, boost and temp gauge. -Innovate db series wideband -Rota grids 18x9.5 +22 all around Here are some shots I took this afternoon. Price is $16,000obo Let me know if you guys have any questions or need anymore information. Thanks |
10-24-2014, 08:28 PM | #15 |
Cali's laws suck but if you end up not selling it... There are alot more 240 folks in LA... Idk if they have that kind of cash but yiu may get lucky. Andnif you do end up keeping it, the laws only apply toncars registered inncali if you keeep thebout of state plates, you'll be good.
10-24-2014, 09:14 PM | #16 | |
