Old 10-29-2010, 05:02 PM   #91
LaSuperSlow
LaSuperSlow is an unknown quantity at this point
did both the line to the front and to the rear the earl way. worked out great for me. for anyone doing it to their hicas i would recommend getting a 6ft hose from then and cutting a 4ft piece and a 2ft piece.
and TheGrim i had the same problem with the rack end leaking. i just put teflon tape on that end and it fixed it... but i didnt use a washer.
LaSuperSlow is offline   Reply With Quote
Old 10-31-2010, 09:14 AM   #92
Future_gohan
Future_gohan is an unknown quantity at this point
I always have one made, what fitting is everyone using for the rack? You need to have a fitting with that o ring or its suppose to leak, none of the part numbers or anything show the fitting with that rubber seal. Because the place where i get mine made that one fitting is almost 40 bucks, so i'd like to find it cheaper and buy it separately.
Future_gohan is offline   Reply With Quote
Old 02-06-2011, 04:02 PM   #93
jparker7
jparker7 is an unknown quantity at this point
what are the part numbers for the low pressure side. Id like to have them braided too
jparker7 is offline   Reply With Quote
Old 02-07-2011, 10:38 AM   #94
japslapsilvia
japslapsilvia's Avatar
japslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the rough
its been covered.. search around here an you will find it...
Nothing is rare just expensive.
if you've ever been with multiple women, then even you can understand that not all girlfriends are created equal. some are capable of amazing oral talents, while others dont mind a lill back door action.
japslapsilvia is offline   Reply With Quote
Old 02-15-2011, 08:58 AM   #95
ZenKi_373
ZenKi_373's Avatar
ZenKi_373 is an unknown quantity at this point
sorry for the thread from the dead! but i have a questions. the fitting that has the o-ring on it goes on the bottom closest to the racknpinion?when i removed the oem one that line had the o-ring on it) and the one without the oring goes on the pump? or is it viceversa
im going to buy one of these next paycheck so i kinda only want to install it once lol. thanks!
ZenKi_373 is offline   Reply With Quote
Old 02-15-2011, 11:16 PM   #96
LaSuperSlow
well the holes are different sizes on the rack and pinion if i remember(correct me if im wrong)
and the one with the o-ring goes to the pump. i forgot too. i was excited of putting the new hose in that i forgot to note which line went to the pump and which one to the resevior(cant spell)
Old 02-28-2011, 08:57 AM   #97
Black R
Black R's Avatar
Black R is an unknown quantity at this point
I'm subscribing bc i'm making my own after finding out everyone is out of stock on the isis line. Hopefully I'll save $40 this way...
Here's what I'm ordering from racerpartswholesale.com:
Aeroquip 90 Degree Reusable Elbow Fitting - -06 Aeroquip 90 Degree Reusable Elbow Fitting x2 $25.78 http://www.racerpartswholesale.com/p...sable_Fittings
Aeroquip AN Flare to Metric Adapters - Aeroquip AN Flare -06 to Metric 14mm x 1.5 Adapter $7.29 http://www.racerpartswholesale.com/p...pFlareAdapters
Aeroquip AN Flare to Metric Adapters - Aeroquip AN Flare -06 to Metric 16mm x 1.5 Adapter $7.29 http://www.racerpartswholesale.com/p...pFlareAdapters
Aeroquip Teflon Racing Hose - Aeroquip Teflon Racing Hose -06 3ft $13.50 http://www.racerpartswholesale.com/p...quipTeflonHose
I'm ordering an extra foot of hose bc I have a 2j swap and don't want to have the line be too short.
*idk why zilvia breaks the links, but those are the parts.
Black R is offline   Reply With Quote
Old 02-28-2011, 09:02 AM   #98
japslapsilvia
Here's what I'm ordering:
are you buying regular SS hose?
i didnt see any power steering specific hose or hose ends in your list..
here is what you need to get
http://zilvia.net/f/chat/338796-powe...ood-times.html
Old 02-28-2011, 09:30 AM   #99
Black R
Black R's Avatar
They got into that discussion earlier in the thread:
Superior fluid compatibility, abrasion and corrosion resistance for reliable service. Made with an extruded Teflon inner tube that's compatible with a wide range of fluids, including hydraulic brake fluids. The hose has a bright stainless steel wire-braid cover that resists abrasion and corrosion, providing optimum dependability. Applications: Offraod brake, transmission, clutch, gauge, N20, power steering, hydraulic.
-03 specs: 0.14 Hose ID, 0.25 Hose OD, Max operating pressure of 3000 PSI
-04 specs: 0.19 Hose ID, 0.30 Hose OD, Max operating pressure of 3000 PSI
-06 specs: 0.32 Hose ID, 0.43 Hose OD, Max operating pressure of 2500 PSI
Sold by the Foot
Old 04-05-2011, 02:21 AM   #100
mitcheyismyname
mitcheyismyname is an unknown quantity at this point
Update!!!!
For those making their own line, you need to get a 14mm x 1.5 ORiNG!!!!! adapter for the rack and pinion side. Otherwise it will leak. I'll try thread sealer and see how that goes.
mitcheyismyname is offline   Reply With Quote
Old 04-28-2011, 12:01 PM   #101
ZenkiKid
ZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud of
Originally Posted by rollout240 View Post
so any word on the ps line noise. i installed the line maybe about 3 months ago. have bled it numerous times and i am using ATF. it seems that the problem is normal since many people are saying it's happening to them. well not normal but you get the point. Do you guys thing that the diameter of the hose is smaller maybe??? and not enough flow??
I have been having the same problem. Just recently my pump started to smoke along as if its not getting any fluid. What could be the cause of all of this? It looks as if the pump is simply not pumping because theres like no change to my reservoir.
ZenkiKid is offline   Reply With Quote
Old 04-28-2011, 01:23 PM   #102
Flicktitty
Flicktitty's Avatar
Flicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to behold
Send a message via AIM to Flicktitty
does anyone know of a company who offers a BLACK -6AN POWER STEERING LINE HOSE?
I can only find silver and blue, i am going to slowly change all my lines/fittings out to the black an fittings and just would like to get rid of that silver line.
2JZ-GTE Swapped S13 Coupe - 1994 Supra Turbo
Flicktitty is offline   Reply With Quote
Old 04-28-2011, 01:33 PM   #103
singlecamslam
singlecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymore
ok like an idiot i used PS fluid instead of ATF, and right away my BRAND NEW rack, yes brand new from the store started leaking. Could this be from the PS fluid? Is it too late to switch back to ATF? I HATE LEAKS. Thanks. It leaks from the hose in the middle of the rack.
singlecamslam is offline   Reply With Quote
Old 04-28-2011, 07:37 PM   #104
ZenkiKid
Fail... I had a massive leak coming from the hose and i figured out it was because the bottom fitting wasnt even fully threaded into the rack -_-
Old 02-19-2012, 10:36 PM   #105
Tommy
Tommy is an unknown quantity at this point
^^ wants eggs with that spam?
Tommy is offline   Reply With Quote
Old 06-02-2013, 11:16 PM   #106
Geezy
Geezy's Avatar
Geezy is an unknown quantity at this point
I know this thread is old... had mine for 4 years now and it failed earlier this afternoon. It had a burst somewhere in the middle of the line.
Any idea what could cause this, failing pressure check valve in the pump?
Geezy is offline   Reply With Quote
Old 06-03-2013, 12:55 AM   #107
4x4le
4x4le's Avatar
4x4le is an unknown quantity at this point
Send a message via AIM to 4x4le Send a message via Yahoo to 4x4le
Probably chafing. An fittings and line will fix you right up
4x4le is offline   Reply With Quote
Old 06-03-2013, 01:07 AM   #108
zerodameaon
zerodameaon's Avatar
zerodameaon is an unknown quantity at this point
With the missing brading it looks like chafing like 4x4 said. It does not look as if it burst out spreading the braiding out.
This is a good reason to revive a thread though.
Originally Posted by MrMigs View Post
That's a one-way trip to understeer land...
Originally Posted by BKdaMoRoN View Post
Maybe you should petition the retards who are paying 5k for an S13.
Need to adjust your idle?
http://zilvia.net/f/s-chassis/395413...-pictures.html
zerodameaon is offline   Reply With Quote
Old 06-03-2013, 03:59 AM   #109
Geezy
Geezy's Avatar
it could possibly be chaffing, BUT, it was tied away from the frame rails not touching anything metal. and when it went out, i heard a LOUD POP right before the sound of rushing fluid... =[
Old 09-08-2013, 12:11 PM   #110
hacknik
hacknik's Avatar
hacknik is an unknown quantity at this point
Bump!
Anyone else want to chime in on the quality of the ISIS lines? I'm about to purchase one as well. My lines are leaking like crazy...however I did put P/S fluid in them earlier since the previous fluid leaked out.
Hope the seals are still ok.
Shit is WET
hacknik is offline   Reply With Quote
Old 09-10-2013, 12:29 PM   #111
LetsGetLifted_180sx
LetsGetLifted_180sx is an unknown quantity at this point
Anyone know what went on the side that went to the rack I got my line and I lost the thingy that was on that fitting is it an o ring or washer? Or am I tripping balls? It's not the side with that lol baby o ring. The other end of the line. And what's this about not using power steering fluid. But ATF? The hell is that?
LetsGetLifted_180sx is offline   Reply With Quote
Old 09-11-2013, 06:09 AM   #112
Tripoptski
Tripoptski is an unknown quantity at this point
automatic trans fluid lol
Tripoptski is offline   Reply With Quote
Old 09-12-2013, 12:48 AM   #113
MamangSorbetero
MamangSorbetero's Avatar
MamangSorbetero is a jewel in the roughMamangSorbetero is a jewel in the roughMamangSorbetero is a jewel in the roughMamangSorbetero is a jewel in the roughMamangSorbetero is a jewel in the roughMamangSorbetero is a jewel in the roughMamangSorbetero is a jewel in the rough
Nissan uses Dexron ATF as power steering fluid. Increased viscosity and heat prevention. If you use mineral powersteering fluid like what BMW, Volvo, Mazda, Audi use it will leak
MamangSorbetero is offline   Reply With Quote
Old 01-12-2015, 10:26 PM   #114
senger
senger is an unknown quantity at this point
sorry to bring up an old post but does anyone have pictures of the install? the ones that were originally posted do not show up on my computer.. thanks!
senger is offline   Reply With Quote
