Old 02-20-2018, 07:16 PM   #21631
cjack300zx
cjack300zx's Avatar
cjack300zx is an unknown quantity at this point
Does anyone here know how to tell if you have a real Nismo shift knob, i see so many fake ones on ebay and the shift knob came with the car.
Nismo knob in question
https://conceptzperformance.com/nism...sal_p_2799.php
cjack300zx is offline   Reply With Quote
Old 02-21-2018, 04:37 AM   #21632
I'm Redline
I'm Redline's Avatar
Legit Nissan Nismo shift knob does not have an adapter to fit anything else except Nissan threads
My work in progress...
Old 02-22-2018, 12:14 PM   #21633
VTEC_lol
VTEC_lol's Avatar
VTEC_lol is an unknown quantity at this point
Anyone here a paint expert? I have single step paint on my car (I assume) and my bumper has o semi-deep scratch that I have to bog and paint.
The question is that can I put clear coat over the corrected area? I bought matching paint in a spray bottle that has some kind of clear coat in it, but should I or could I put clear coat over the painted scratch in order to blend it better?
VTEC_lol is offline   Reply With Quote
Old 02-23-2018, 04:46 AM   #21634
I'm Redline
Most just paint the whole bumper. Only time you want to try to blend is a whole side because a door or fender gets whacked. Try buffing it out first
Old 02-23-2018, 09:37 AM   #21635
_poo40
_poo40 is an unknown quantity at this point
s14 Exhaust system setups
Exhaust fell off on my s14 KA24DE (1995). Like, bolts from the
midpipe->manifold snapped clean off. Probably from scraping. Suggestions for header/catback setups? I don't know what gets along well with what, and what bolts up nicely to a stock chassis. Looking for something rather inexpensive, as I'll be doing a swap by this time next year. Thanks in advance.
Sidenote: Was looking at ISR tubular 4-2-1 and the 3" straight blast pipes, seems to be about a $350-$410 setup altogether, just not sure if it all fits up nicely. Anything around that price would work, just need somethin that fkn fits!
_poo40 is offline   Reply With Quote
Old 02-23-2018, 03:09 PM   #21636
anti tyler
GM2 (SW/AW)
anti tyler's Avatar
Trader Rating: (37)
Feedback Score: 37 reviews
Honestly? I would just get a damn $188 ebay setup if you're going to swap. (I understand this is a 4", there are 3")
https://www.ebay.com/itm/4-MUFFLER-T...5aPffu&vxp=mtr
The ISR setup would fit just the same. I've used both etc.
I have seen absolutely no difference between the 2.
WillEastS14:
mannn u whylin son.
but that shyt has SWAG
KA-T for life!
Old 02-23-2018, 08:33 PM   #21637
JrDarknes
JrDarknes's Avatar
JrDarknes has much to be proud ofJrDarknes has much to be proud ofJrDarknes has much to be proud ofJrDarknes has much to be proud ofJrDarknes has much to be proud ofJrDarknes has much to be proud ofJrDarknes has much to be proud ofJrDarknes has much to be proud ofJrDarknes has much to be proud ofJrDarknes has much to be proud ofJrDarknes has much to be proud of
Whenever I start my car, this wire to the fusebox in the engine bay gets really hot. Smells like its burning if the car runs for too long. This just happened all of sudden.
Also my car cluster lights stay on even when I turn off the car. Replaced ignition switch but that didnt help. Checked my harness under the fender and its fine. I keep hearing a relay click so I am thinking it is the Ignition Relay under the dash? Could this correlate with the wire getting hot all of a sudden?
JrDarknes is offline   Reply With Quote
Old 02-24-2018, 07:07 AM   #21638
I'm Redline
The only system that is exactly ran the same as the OE is the OBX Racing. I know it comes in a 2.5", but it may also come in 3". Bottom line is the cheapest way to go is Summit Racing, get the SS tubing, fit it with four " over lap so it tucks really high, then have the joints slipped at a muffler shop. Under 200 usually, plus cost of muffler and shop work(100 or so)
Old 02-24-2018, 11:34 AM   #21639
S14DB
AFC #1
S14DB's Avatar
http://www.nismo.co.jp/products/cata....html#page=313
Old 02-24-2018, 03:46 PM   #21640
VTEC_lol
VTEC_lol's Avatar
Does anyone know which wire this yellow/green is? For some reason it has a splitter connector to a brown wire that is 10cm long and goes nowhere?
It's from an S14a with SR20DET that is european, every ecm wiring diagram shows different, so anyone have any idea?
Old 02-24-2018, 05:17 PM   #21641
LoSt180
LoSt180's Avatar
Trader Rating: (18)
Feedback Score: 18 reviews
If I'm looking at your ECU connector right, looks like pin #4, which would go to the ECU relay. Maybe that tapped wire was used to power an accessory?
Old 02-24-2018, 05:27 PM   #21642
VTEC_lol
VTEC_lol's Avatar
Okay thanks for that image, I needed that! Might've been an accessory of some kind, I have no idea.
EDIT: turns out the yellow/green wire is NATS Immobilizer, I just don't know why it is splitted
Old 03-08-2018, 08:29 AM   #21643
NickyD0403
NickyD0403's Avatar
NickyD0403 is a jewel in the roughNickyD0403 is a jewel in the roughNickyD0403 is a jewel in the roughNickyD0403 is a jewel in the roughNickyD0403 is a jewel in the roughNickyD0403 is a jewel in the roughNickyD0403 is a jewel in the roughNickyD0403 is a jewel in the rough
Are S14 headlight brackets the same on both sides? i.e., Can I just buy 2 of these? Asking because this one says "RH" but I didn't see an "LH" anywhere on the site:
https://frsport.com/Right-Headlamp-B..._p_368851.html
NickyD0403 is offline   Reply With Quote
Old 03-08-2018, 08:46 AM   #21644
TheRealSy90
TheRealSy90's Avatar
Yep probably the same as Silvia S13 brackets where there's only one "side" and it works for both.
Such a good signature.
Old 03-08-2018, 12:18 PM   #21645
di-devol
di-devol will become famous soon enoughdi-devol will become famous soon enoughdi-devol will become famous soon enoughdi-devol will become famous soon enough
Where are you guys getting rear overfenders? And what kind? I'm looking for +30mm coupe rear overs, and just about everything seems out of stock. FrSport has Dmax, but I dont like the rivet recess they have built in.
di-devol is offline   Reply With Quote
Old 03-08-2018, 12:38 PM   #21646
conrad_s13.5
conrad_s13.5's Avatar
conrad_s13.5 is making a name for him/her selfconrad_s13.5 is making a name for him/her self
Did you call Touge Factory?
As lame as it sounds, local facebook car groups have a decent marketplace too nowadays. Not sure of brands without some sort of rivet recess tho.
cONtRol FReAkS
conrad_s13.5 is offline   Reply With Quote
Old 03-09-2018, 04:35 AM   #21647
I'm Redline
What's wrong with rivet recesses, not using the thinset anywhere on the car before paint?
Rivet, fill and mold in. Smooth looking ride done right
Old 03-09-2018, 09:38 AM   #21648
conrad_s13.5
I have no problem with it at all, OP mentioned not liking the recesses.
cONtRol FReAkS
Old 03-09-2018, 09:58 AM   #21649
Crazyced
Crazyced's Avatar
Crazyced is an unknown quantity at this point
Are intakes even remotely worth it on a KA24E? Reason I ask, intakes are 'free' in my autocross class and the stock rubber booth at the TB is ripped and apparently an OEM replacement is worth 70$.
Crazyced is offline   Reply With Quote
Old 03-09-2018, 01:13 PM   #21650
caspa
caspa's Avatar
caspa is an unknown quantity at this point
Question, my s14 front wheels move out of control on high rpm (5th gear around 2k+).... any idea?
caspa is offline   Reply With Quote
Old 03-09-2018, 02:11 PM   #21651
S14DB
AFC #1
S14DB's Avatar
Silicone coupler.
Side to side or up and down? or Float?
Old 03-09-2018, 02:35 PM   #21652
mr.nismo.
mr.nismo.'s Avatar
Trader Rating: (31)
mr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond repute
Feedback Score: 31 reviews
Anyone with a hatch have both the miracle x bar and Cusco triangle brace? Curious to see if it's worth it as I already have the x brace
Sent from my SM-G955U using Tapatalk
mr.nismo. is offline   Reply With Quote
Old 03-09-2018, 02:49 PM   #21653
S14DB
AFC #1
S14DB's Avatar
Cusco triangle brace is not worth it on the 240sx. IMHO.
Old 03-09-2018, 03:26 PM   #21654
mr.nismo.
mr.nismo.'s Avatar
Trader Rating: (31)
Yeah. Id figure I'd ask, as I tried picturing any more benefit that the x bar doesn't help with. Plus I forgot to mention I have the do-luck floor bar and a trunk bar, so maybe it'd be overkill haha
Old 03-09-2018, 06:05 PM   #21655
caspa
caspa's Avatar
Silicone coupler.
whats do you mean by float??
It goes side to side and vibrates violently.
Old 03-10-2018, 07:09 AM   #21656
I'm Redline
Yes, intake is worth it. Less weight, and better air movement increase hp by a nominal 3 - 7 hp. Less weight is great in any class.
This sounds like you are either getting air under the car, or your steering is way out of alignment(cause can be rack, or front suspension parts, or all, but misalignment would seriously show at all speeds.
Bracing triangulates all the rest of the good parts like coil overs, adjustable arms, antisway bars, and new bushings. Squaring the chassis is ALWAYS a good thing, and rigidity in corners is what makes you faster or able to hold a slide longer, or even easier
Old 03-10-2018, 11:34 AM   #21657
VTEC_lol
VTEC_lol's Avatar
I bought I strut brace for my S14 but it doesn't fit because it hits this line (not sure what it is, some kind of liquid tank for AC or something?)
Anyone have any suggestions what can I do about this? I loosened the bracket and slid it down but it's not low enough...
Old 03-10-2018, 11:57 AM   #21658
S14DB
AFC #1
S14DB's Avatar
It's the drier for the AC. I would not move it to much. I haven't seen a strut brace that hits it. You sure you don't have the brace backwards?
Old 03-10-2018, 12:24 PM   #21659
VTEC_lol
VTEC_lol's Avatar
I'm not sure how could it be backwards, it's pretty much this exact one but mine has longer "brackets" so they hit the line (I don't have an image of mine rn)
Old 03-10-2018, 01:17 PM   #21660
LoSt180
LoSt180's Avatar
Trader Rating: (18)
That's weird, mine is down right next to the radiator. Do you have custom AC work or anything to explain why it's located there? Unless it's one of those odd year to year variances? I see you have an ABS car, doubt that would affect the AC placement though.
