Old 02-15-2013, 10:37 AM   #1
Derko
Derko is an unknown quantity at this point
s13 Adding Powersteering Help
I just recently bought a 91 240 and it came with no power steering. It's a KA24DE and i was wondering what i needed to add power steering back on. I know you need PS pump and bracket, pressure lines, reservoir. Is there anything else i'll be needing and does anyone know were i can find the parts,thanks
Derko is offline   Reply With Quote
Old 02-15-2013, 10:52 AM   #2
Drift_FX
Drift_FX's Avatar
Drift_FX is an unknown quantity at this point
something you need to consider is how the power steering was removed. if they just cut the lines and left it, odds are your rack is junk, and if you hook up your system to it it will ruin your pump... you definately wanna check if the lines are capped or not, odds are your gonna need a new rack... you should be able to find all of what you need in the FS section, just look for someone doing a partout...
Drift_FX is offline   Reply With Quote
Old 02-15-2013, 11:02 AM   #3
zooopreme
Trader Rating: (38)
Feedback Score: 38 reviews
^This. But to add on to what he said, some people just drain the fluid & use that as their manual rack, while that isn't how it works, it does get rid of the power steering. I would check to make sure it is in fact a PS/Manual rack then proceed with what Drift FX said.
power steering
