Old 06-06-2018, 12:07 AM   #1
drfftn
drfftn has a reputation beyond reputedrfftn has a reputation beyond reputedrfftn has a reputation beyond reputedrfftn has a reputation beyond reputedrfftn has a reputation beyond reputedrfftn has a reputation beyond reputedrfftn has a reputation beyond reputedrfftn has a reputation beyond reputedrfftn has a reputation beyond reputedrfftn has a reputation beyond reputedrfftn has a reputation beyond repute
Key won't come out of the ignition (s13)
I purchased the car as a shell a few years ago and did a V8 swap. When I purchased the shell from the previous owner he was in the process of 5 speed swapping the car. Pedal installed, the shift lock control unit is plugged in (under the dash), and plug is jumped in the engine bay so the car will start. The key will not come out of the ignition unless I use the little emergency release lever behind the release button. I replaced the ignition with a new ignition and the problem continues.
In the video below the guy says he had to jump the 2 wires from the shift lock solenoid for the key to be released.
https://youtu.be/J9hmQ-zLx40?t=8m59s
I know on S14's the have a metal lever that controls the key release. Is this on S13's also? First time dealing with an auto to 5 speed chassis.
drfftn is offline   Reply With Quote
Old 06-06-2018, 08:23 AM   #2
slider2828
slider2828's Avatar
On the S13 there is a little round botton above the key go from accessory mode to turn to unlock to pull out the key.
Turn and Burn!
Old 06-06-2018, 11:27 PM   #3
drfftn
ya brah i know that. mine won't release the key at all when the button is pressed like it should. Right now I have the use the little emergency lever behind the button to release the key.
Old 06-07-2018, 10:06 AM   #4
slider2828
slider2828's Avatar
Man... that sucks... maybe something wrong with the cylinder.... Tough to get a cylinder nowadays, but maybe you can get it replaced, but then you have to rekey everything....
Turn and Burn!
Old 12-12-2022, 02:34 PM   #5
usctom
usctom is an unknown quantity at this point
Late answer. I was having the same issue.
Tie the black and Yellow with red line together on the the shift lock solenoid
usctom is offline   Reply With Quote
