09-19-2005, 01:20 AM | #1 | |
RB FAQ
By popular demand, here's an FAQ for Nissan's RB-series motor.
09-19-2005, 04:29 PM | #2 |
No more nissan.
You can use a z32 yoke for the driveshaft, it mates the RB tranny
custom downpipe has to be made to clear the steering column You NEED custom mounts available from Mckinney or Phase2. Ebay has them once in a while as well. E-fans are a must since you loose the extra space for your clutch fan I'll think of more later.. |
09-19-2005, 06:46 PM | #3 | |
R.I.P. Aya, always love
Trader Rating: (215)
Feedback Score: 215 reviews
We addressed this issue by making a custom 3 inch elbow/downpipe , to this date no one else I have seen has done this, we also make custom urethane engine mounts, transmission brackets and swaybar brackets and driveshaft. It is a complete kit that is coming out shortly. We feel it will blow the competitions right out of the water. shameless promotion here for Syko Performance.
"Having a lot of tracks on a song is like putting stickers on a car to get more horsepower" New Video https://www.youtube.com/watch?v=uebV1OnbRsw Buy my mounts! http://zilvia.net/f/sale-items/51531...ns-mounts.html http://zilvia.net/f/tech-talk/317539...e-mouts-6.html |
09-19-2005, 06:48 PM | #5 | |
09-19-2005, 10:39 PM | #6 | |
09-20-2005, 01:07 AM | #7 | |
from what i understand, i think it depends on which mount kit you use. im not 100% though.
-Dane |
09-19-2005, 07:05 PM | #9 |
No more nissan.
you need to upgrade fuel pump
PS lines and AC lines have to be re-fabricated and google turned this up http://sportcompactcarweb.com/tech/0309scc_hybrid/ |
09-19-2005, 07:10 PM | #10 |
[QUOTE=NemeGuero]you need to upgrade fuel pump
PS lines and AC lines have to be re-fabricated and google turned this up http://sportcompactcarweb.com/tech/0309scc_hybrid/[/QUOTE We are in the process of designing custom AC lines. We also have actually designed a custom Power steering line setup as well. Not sure when that stuff will be ready for marketplace though.
09-19-2005, 07:48 PM | #12 |
No more nissan.
well shoot.. I guess you're the guy to get in touch with for an RB swap.. hahah
we should just erase all these posts and put your contact info in a single thread. |
09-01-2010, 12:43 PM | #15 |
Werrrrrrd i just did an RB swap last night literally. you dont have to bang the actual firewall but the transmisson tunnel. especially on the passenger side cause the starter. The RB was 25 that i swapped and we used McKinney mounts with the stock s14 kouki crossmember. it went smooth (as smooth as an RB swap can go). there is some fab required but not a crazy amount.
09-20-2005, 11:37 AM | #17 | |
oh ya and for everyone. These installs have a number of ways to be done, depending on if you utilize a R33 GTST crossmember with the stock RB engine brackets, (which is what we do) or not. We choose this particulare method because it allowed us with our Custom Urethane mounts to move the engine as far back and as low as possible in the S13 chassis. Yes we did custom power steering lines,it works kick ass too!! I am in the process of finishing up my air, using a RB25 R33 air con compressor and fittings. All we had to do is have the lines extended to my stock lines coming from the firewall. The only reason I say what I say is because compared to whats on the market our setup is cleaner and looks much more factory. Ours will be a product not someones back yard job.
09-20-2005, 09:55 PM | #18 | ||
09-20-2005, 10:33 PM | #19 | |
If street Jesus is some kind of god who knows so much why does not post under his own screen name ? sounds like ego once again. Again like I stated before , I am speaking from having a working product that I have even shown here on the forums and posted about. I do not need any RB questions answered. My associate was installing RB's in S14's over 6 years ago, thats before Mckinney or anyone else. In fact his ITB SR20de is in this months Super Street. Our stuff is clean and right so much that I can say it and market it. Thats a pretty strong statement.
08-22-2009, 02:08 PM | #20 | |
09-08-2009, 08:05 AM | #21 | |
Making it AWD will cost lotssss and lots of $$. Just put a rb25 tranny on there. if you reaallly want a 6 speed, thenn..... well, fuck it. what do you need a 6 speed for? 45mph 6th gear pulls? |
09-20-2005, 10:08 PM | #23 |
No more nissan.
nobody was fighting,
and you still need custom mounts, whether you modify your original mounts or buy new ones, you still can NOT utilize the stock mounts in their stock condition and re-drilling stock mounts doesn't seem like the 'best' of ideas you can do it the right way, or put a bandaid on it and hope it stays |
09-20-2005, 10:17 PM | #24 |
No more nissan.
it will bolt in using the R33 crossmember and fit well enough to get you on the road, but the engine will sit a little higher and a little farther forward than is ideal. Some of the hood bracing will have to be removed to clear the throttle body and blow-off valve flange and the shifter will sit about an inch and a half forward of the center of the shifter hole in the floor. The Skyline's transmission crossmember is nearly identical to the one on the 240SX, but the transmission is longer, so it won't line up with the holes in the car. Again, you have options.
If this is just a show car, file the bolt holes on the transmission mount so it can slide forward on the transmission a half inch or so. Then shove on the flimsy, flexy transmission mount until the center hole on each side of the crossmember (originally a drain hole, not a bolt hole, but it will work) lines up with the rearmost mounting hole on the car. Bolt it on with one bolt on each side (it's supposed to have two) and go polish something. Oh, sure, the top of the transmission will be jammed up into the top of the tunnel, but that won't really matter on a show car. Now, if you actually intend to use that big turbo six to make power, two bolts aren't enough, and having the transmission hitting the tunnel won't do. Finally, if you want the engine to sit low enough to clear the hood bracing, the shifter to sit where it used to, the steering shaft not to hit the downpipe and everything to bolt in properly, there's a third option. McKinney Motorsports in San Diego, Calif., unStable Hybrids in Conyers, Ga.,Syko Performance in Torrance Calif, all make engine mount kits that move the engine down and back about an inch and a half. In addition to making everything fit better, moving the drivetrain, which weighs about 650 pounds, shifts the center of gravity in exactly the right direction. This is also the ideal option if you have an engine, transmission, harness and ECU, but no front clip. |
09-20-2005, 10:38 PM | #25 | |
Syko transmission brackets allow you to use the factory S13/S14 crossmember. SyKO swaybar brackets allow the swaybar not to hit the oil pan either. All of this stuff is high performance stuff designed to handle high HP. YOu can add SyKO company to that list above .Syko Performance in Torrance Calif. P.S. I no longer work with Syko though they are a great company. I am on to my own things.
"Having a lot of tracks on a song is like putting stickers on a car to get more horsepower" New Video https://www.youtube.com/watch?v=uebV1OnbRsw Buy my mounts! http://zilvia.net/f/sale-items/51531...ns-mounts.html http://zilvia.net/f/tech-talk/317539...e-mouts-6.html Last edited by drift freaq; 04-22-2008 at 01:24 AM.. |
09-20-2005, 11:22 PM | #26 |
Now you're starting to talk crap. From pissing me off, I conclude your talking shit, is your marketing tool. Flipping the "ego" thing around on you.
09-21-2005, 01:21 PM | #28 |
Just easy kinda things heres some parts info RE RB25det
Clutch kit = Z32 N/A Throwout bearing = will work for z31 turbo, some others work too. Coil Packs = Z32 Nismo Thermostat = Same as z32/ xterra, all 6 cyl Nismo FPR (Highly recommended on all cars with walbros, fuel pressure is too high causes super richness) = 22670-RR580US (same as SR20det model) Maf = Same as J30 maf on series 1!?, any z32 filter will adapt to the maf, but the plug is the main concern. other info that is good -------------------------- Make sure you change your waterpump, and timing belt before you swap, who knows how many miles your engine has, its better now then when it shits out on you and you have to do it from inside. S14 can use tach and speedo, as well as coolant temp gauge (must swap in KA coolant temp sensor into RB temp sensor location.) It reads a little bit faster on warm up, but is accurate thereafter. To use the tach correctly, recalibrate it using the adjustment screw on the back of the gauge cluster, you need something else to read your RPMs to calibrate it correctly. Remember rb is 6 cyl vs 4 cyl, so tach will read 1.5 too much. I.e. 2000 rpms reads as 3000 rpms on your tach. Lower harness: Use your KA lower harness. You will have to cut off the starter plug and rewire it inplace of the Ka start plug (spade plug). You willneed to cut off the KA oil pressure sender, replace with the rb one. Starter loops that you secure on with 10/12 mm bolts, you may have to ream the inside or replace the loop that is secured with the bolts. Everything else pretty much works. Also extend the KA tranny harnesses , some plug up, those that don't make sure you splice them with the correct plug from the KA harness. |
