02-01-2017, 04:37 AM | #20731 |
July 96 forward uses all ABS sizes(this can apply to zenki's too, that fall at end model build dates like mine) My bitch was built when Champagne Supernova was charting, and Hawaii's Japanese club girl scene was trying to draw white boys in with advertised half price pints of Guinness over on Kalakaua
02-01-2017, 06:51 AM | #20732 | |
02-01-2017, 09:31 AM | #20733 |
Anyone know the width and height of an s13 Silvia headlight cover housing? Currently don't have one sitting in front of me to measure. Preferably the back mating face to the bulb housing. Thanks.
02-01-2017, 12:48 PM | #20734 | |
02-01-2017, 07:37 PM | #20735 |
does anyone have pics that are running a map sensor on the SR? I'm going aem standalone but couldn't find any good pics of how anyone mounted their map sensors, any help is appreciated thanks!
02-01-2017, 08:47 PM | #20737 | |
Since it has a GTR drivetrain, probably the same way a GTR can switch from awd to rwd. Sent from my iPhone using Tapatalk |
02-02-2017, 10:21 AM | #20738 |
I bought a blown sr and it doesnt have the rod and main caps. Am i fucked?
And does any run pbm rear knuckles with kazama ruca on here? The kazamas don't work on the gk tech knuckles (-.-)
https://www.instagram.com/jdpowersport_/ Last edited by jared420sx; 02-02-2017 at 11:50 AM.. |
02-02-2017, 12:50 PM | #20739 |
On a basic T25 setup, what source do I connect to the nipple on the actuator? Every diagram shows to connect it to a nipple on the compressor housing but the stock T25's and T28's don't have a nipple there.
02-02-2017, 01:22 PM | #20741 | |
drill and tap a hole into the outlet and screw in a brass fitting. |
02-02-2017, 01:38 PM | #20742 |
02-02-2017, 02:30 PM | #20745 | |
If you're referring to the oem vacuum diagrams, this line would actually be connected to the factory boost pressure solenoid, which would then go to the factory charge piping right after the compressor outlet. However since you most likely don't have or use the factory boost solenoid or have the oem charge piping, you'd have to install a fitting in either the compressor housing or the charge piping. Or run the line to the throttle body if you have to. |
02-02-2017, 04:00 PM | #20747 | |
ITS LISA'S FAULT!!!
Trader Rating: (41)
Feedback Score: 41 reviews
besides, investing $30 into a tap set from autozone or sears is just a great idea to begin with... ive used mine countless of times over the years due to the former owner of my car (as well as my previous chassis) using incorrect torque or threads just wearing out due to age/heat/thread lock. |
02-05-2017, 07:23 AM | #20751 | ||
You can mock up chicken wire and make your own with fiberglass or carbon fiber or kydex. If it's for looks only, you will have to trim and fit the bottom to the kouki spoiler. If you have friends with an R32 and a 240 with a kouki wing, just get them together to compare
02-06-2017, 10:41 AM | #20752 |
Any place to get the S15 silvia "Silvia" badge/emblem cheaper than $50 on ebay? Doesn't have to be OEM or from a dealer. Need it to make an impression into fiberglass
02-06-2017, 06:03 PM | #20753 |
Going to piece together a ka exhaust. Was thinking 2.5in piping. And i want a cat.
Other than that im clueless. Dont want it loud and sound like a raspy fart. Any ideas? Suggestions on muffler selection? Resonater selection? I dont want a fart can either and a straight pipe is gross too. Help!
https://www.instagram.com/jdpowersport_/ |
02-06-2017, 06:09 PM | #20754 | |
http://www.nissanraceshop.com/produc...lem-nameplate/ |
02-06-2017, 07:07 PM | #20755 |
Anyone know their way around a pre powerstroke (international IDI 6.9) ford diesel?
Getting intermittent (in presence and intensity - sometimes, especially when cold, none, generally moderate to heavy when hot) white smoke, turns on and off abruptly, often accompanied by engine rocking as though missing, though even during decel. I assume I have a sticking injector and/or damaged injection pump thats dumping fuel - anyone have any diesel diagnostic tips for isolating this? It's 2wd 86 250 auto. |
02-07-2017, 04:57 AM | #20756 | |
You will have a very mellow sounding exhaust that will not be raspy, and will idle quit, and at wfo will not be obnoxious. Or you can contact OBX Racing and just get the whole system
02-07-2017, 09:35 AM | #20757 |
Thank you redline !
02-07-2017, 09:29 PM | #20758 |
Trader Rating: (53)
Feedback Score: 53 reviews
Small Questions Thread (SEARCH FIRST! Use this instead of making NEW threads)
Help me ID these connectors please. I'm trying to trim out unnecessary functions.
For number 1, I know that it's the harness for the rear speakers, what is that lone wire though? Is that a trigger or power wire for the OEM amplifier system? Number 2 is part of the harness running along the driver's side withe the tail lights and stuff. Number 3 was taped under the center console not attached to anything. Number 4 is passenger side under dash area.
: @e_lemonation |
02-08-2017, 07:00 AM | #20759 |
So I just did a HG on my SR. It was not blown or anything but had motor out anyway, I put in a fresh OEM HG and ARP studs in. I realized I did not put RTV on the front cover area on the HG?
Will that cause issues/leaks? (Used OEM gasket because motor is still stock) |
02-08-2017, 07:07 AM | #20760 | |
