01-01-2017, 05:49 PM | #20641 |
Yeah if it clears on that side. If they're the "angled" type like PBM etc, then you'll also have to swap passenger side for driver side so that it's still angled properly. I have mine in front of the coilover.
Sent from my iPhone using Tapatalk |
01-02-2017, 02:19 PM | #20644 | |
Trader Rating: (18)
Feedback Score: 18 reviews
http://forums.nicoclub.com/tips-s15-...n-t245320.html http://www.sr20forum.com/240sx/12359...fectively.html http://www.sr20forum.com/240sx/12454...installed.html http://www.sr20forum.com/240sx-s13-s...ll-thread.html |
01-02-2017, 03:38 PM | #20645 |
So I've been debating going sr20 and the only thing holding me back is keeping my ac. now normally with a simple Google search I found that if I had a dual cam engine, they make mounts to keep the dual cam KA's compressor on the sr20 with a modified bracket. there is a guy on here that makes them however im looking to see if someone makes one for a single cam compressor to mount on an sr20... reason being is my ac is cold as fuck and my car is clean and id rather not source out a ton of dual cam ac parts if id just be able to find someone to make me a bracket to solve this issue. thanks guys. any help is appreciated..
01-02-2017, 04:22 PM | #20646 | |
ITS LISA'S FAULT!!!
Trader Rating: (41)
Feedback Score: 41 reviews
you need BOTH output shafts from the S15 diff. ALL VLSD S13/S14/R200/R230 rear ends are 29 spline EXCEPT for S15 and R34 GTS-T R200 HLSDs which are 30 spline. if you have an S15 HLSD but are missing the output shafts, its basically useless! S15 diffs will fit just fine into any S13/S14 R200 pumpkin, the only concern is the driveshaft length with ABS equipped cars (not sure if S14s had this problem). i know for a fact you can reuse the S13 ring gear bolts on an S15 HLSD (did it on mine). S14 ring gear bolts may be slightly different, but they should work (any S14 guys wanna chime in?) also the ring gear and pinion in the S15 diff fit just fine into an R200 diff as well. |
01-02-2017, 05:30 PM | #20647 | |
Trader Rating: (18)
I bought mine here, best price I could find about 1-2 weeks shipping: http://www.rhdjapan.com/nismo-differ...gear-bolt.html |
01-02-2017, 05:36 PM | #20648 | |
Nobody makes a single cam compressor bracket for sr20. Sent from my iPhone using Tapatalk |
01-02-2017, 07:04 PM | #20650 | ||
01-03-2017, 05:47 AM | #20651 |
In that case why not get a complete s15 diff that has the speed signal sensor already in the snout of it, then you don't have to worry about fitting everything and shimming the carrier etc. bolt in and go.
01-03-2017, 10:14 AM | #20652 |
Usually much cheaper to ship the S15 HLSD, bolts, and output shafts (and even the 3.69 ring gear) alone than it is to send the whole pumpkin.
01-03-2017, 02:07 PM | #20653 |
Yeah, that's the exact reason, getting an s15 pumpkin over here doesn't seem to be worth the cost, and I also want to keep the 4.08 RP.
01-03-2017, 05:18 PM | #20654 |
Hey guys! My s14 is overheating I have a stock KA24DE. I have no idea why it's overheating. I've change thermostat(previous owner had no thermostat), radiator & checked the oil cap & oil dip stick & do not see coolant or milky residue on either. Coolant circulates through the system. My coworkers have been saying I may have a warped head. Any thoughts?
Last edited by Fernandoo14; 01-03-2017 at 05:20 PM.. Reason: Forgot to add more details |
01-03-2017, 05:20 PM | #20655 |
If you kept driving it while too hot it's probly warped, I had a bad headgasket causing my ka to overheat but couldn't see any evidence of it from oil/coolant, it was weird lol
01-04-2017, 04:16 PM | #20659 |
Has anyone installed gktech REAR knuckles on their car here before i make a new thread.
These things r horrible, nothing lines up ive been fucking with it for days and its just not cooperating. I have a couple questions regarding your setup if you have them on your car thanks!
https://www.instagram.com/jdpowersport_/ |
01-04-2017, 07:05 PM | #20661 | |
I have seen in person how shit the Chinese jigs for them are. Nothing ever lines up 100% on the opposite knuckle, some are even missing support tabs and the like. He got them sent back for a new set but even the set also has problems. Some bad welds here and there. Super sketch |
01-04-2017, 09:49 PM | #20663 |
It depends on where you will hook the sensor up. Is it a temp sensor or pressure sensor?
If its an oil temp sensor, the proper way to do it is weld a bung on your lower oil pan to get the proper temperature. An easy way is to get a t-fitting adapter where your oil light switch is at by the filter. That would need a 1/8bspt to 1/8npt adapter. Same goes for oil pressure sender. But I found putting it on a t-fitting on KA's are annoying as shit as the alternator or motor mount gets in the way. |
01-05-2017, 12:16 PM | #20665 |
I've wondered this myself but have seen others setup this way. Where do most people tap into for temperature short of welding a bung on the pan?
01-05-2017, 12:20 PM | #20666 |
Trader Rating: (24)
Feedback Score: 24 reviews
Aftermarket pans usually have an extra port. Not sure for stock pan.
I don't like any T fittings in the block, myself. Too nervous that they'll break. I run my oil pressure senders remote mounted on a piece of braided line and held in with a cushion clamp. I remove the stock dummy sender since I figure the motor is toast anyway at the point the light comes on. |
01-05-2017, 07:16 PM | #20667 | ||||
http://www.frsport.com/Blitz-19234-O..._p_497815.html
01-07-2017, 11:01 PM | #20669 |
Trader Rating: (25)
Feedback Score: 25 reviews
If I'm running a z32 trans w/ rb26 bellhousing on an rb25 in an s14, what does the length of the driveshaft need to be? Also, what shifter bracket do I need, or is stock the best/ only option?
01-08-2017, 12:08 PM | #20670 |
Trader Rating: (18)
Does anyone know if a greddy intake manifold on a s13sr will move the throttlebody close to where a stock s14 TB would be? trying to figure out a intercooler setup
