03-19-2018, 08:39 PM | #1 |
Trader Rating: (44)
Feedback Score: 44 reviews
01 gs 300 with lots of suspension upgrades
Selling my GS300. Car runs fine just needs a little body work and some paint. Has a lot of upgraded suspension and every piece of rubber has been changed or swapped for aluminum. The engine is out of a 05 IS and i replaced a lot pf parts before it went in i have receipts for it all, timing belts, tensioner, water pump, intake and exhaust manifold gasket, valve cover gasket, front and rear main seals, re sealed oil pan. Car does not leak a single drop of anything anywhere. I drove the car from riverside to Oc for months with no issues. Interior is in decent shape all door locks and windows work perfect.Please read below for more info
01 Gs 300 320K (engine has a little over half that amount) Salvage Title Pros: Megan Coil overs Battle Version Solid rear Subframe mounts Battle Version Solid Diff mounts (rear) Battle Version Solid diff mounts (front) Battle Version Inner tie rods Battle Version outer tie rods Battle Version rca blocks/ knuckles Battle Version Solid rack spacers Battle Version solid rack bushings Battle Version Rear toe arms Battle Version Rear traction links Battle Version rear upper control arms Moog oem replacement front lower ball joint moog oem replacement front upper ball joint Doreman rear lower control arm bearing/bushing Doreman knuckle rear knuckle bushings Roca Hardened rubber tension arm bushings Roca front sway bar bushings Roca rear sway bar bushings Megan racing hardened engine mounts N-style front and rear fender (50mm) qp have been cut properly and sealed Bc racing 1 piece forged aluminum wheels 18x9 +22 front 18x10 +10 rear Pioneer head unit with bluetooth speaker Pioneer front and rear speaker with tweeter Cons: Consumes about 1 qt of oil every 4-5weeks needs a new cat, its throwing a code windshield has a crack front driver seat has seen better days Again car runs perfectly fine and has never failed me. Asking 5200 obo if interested or you have any questions please contact me 951-544-8745 [/URL] |
03-21-2018, 07:28 AM | #3 |
Off topic, did you have any issues using the IS engine in the GS? Did you need to swap over anything, like the throttle body, maf, etc? GLWS!
Old School |
03-23-2018, 09:46 AM | #5 |
Super Moderator
Trader Rating: (73)
Feedback Score: 73 reviews
Better question is why are people still hosting pics on photobucket? After they long dicked the entire forum community almost 2 years ago, there's no excuse.
